16 registered members (paulmog, Image, Black Adder, jimmyw, John V6, IcePack, John07, howard, kankeL, Graham, G4FUJ, DJC, TBM, M3W55, KEVFITZ, AndyC60, m3w_golden_co), 178 guests, and 14 spiders.
John V6 366
+8Rich 236
TBM 162
CooperMan 121
Three wheelers galore
by Richard Wood. 21/10/20 03:42 PM
Another Configurator
by Jon G4LJW. 21/10/20 03:23 PM
For all you Landie buffs
by athelstan. 21/10/20 09:26 AM
Anyone used Colourlock on leather?
by Andrew1806. 20/10/20 08:53 PM
Magnecor leads
by thelastgizmo. 20/10/20 07:27 PM
Historic Vanwall to return
by DirkM. 20/10/20 05:01 PM
Westovers
by Viper. 20/10/20 04:52 PM
Malvern Show 2
Malvern Show 1
MGB`s can corrode..?
Winter Project
How now brown cow
Ingenious, JMT, Brian G, beetle back, Apple58
7185 Registered Users
Topics39,632
Posts655,389
Members7,185
Most Online1,033
Dec 28th, 2019
paul
Page 3 of 3 1 2 3
Re: Main Fuse [Re: IcePack] #559657
13/02/19 07:54 PM
13/02/19 07:54 PM
I
IcePack Online content OP
IcePack  Online Content OP
I
Found it, same place as Rog found his. But having cut the cable tie attaching it to the other +ve cables, their is still very little slack to allow access to the fuse.
Cleaned it up with some ACF 50 & put a cable tie around it to hold it together & returned it to it’s original position with a new cable tie. (Stops it contacting the frame)
4/4 Ivory 4.1:1 axle, Jaguar XE R-Sport.
Re: Main Fuse [Re: IcePack] #559852
14/02/19 10:27 PM
14/02/19 10:27 PM
north yorkshire
Lowflyer Offline
Lowflyer  Offline
north yorkshire
I've wrapped a plastic bag around my maxi fuse with a bag of silica gel inside (oh, and a spare fuse) Wether or not i ever remember to dry out the silica gel or not is another question....thjs post has just reminded me !!!!
Re: Main Fuse [Re: IcePack] #559930
15/02/19 11:14 AM
15/02/19 11:14 AM
E
Esprit Offline
Esprit  Offline
E
Quote:
I'm reasonably relaxed about this Tom. My Roadster has the main bank of fuses on the bulkhead. Recently I pulled them (eight) and just polished the contacts, which were slightly tarnished.
The bank of twenty fuses under the dash is hard to get at so I only go there when I have to, such as when the horns stopped working.
The single main fuse in the rear cavity I would only check if I was in there.
Thanks Dave. I just realised I hadn't acknowledged your response so apologies for my bad manners. I've realised that this is probably also a feature of my other cars so the only issue is that the fuse may be less protected in the Morgan due to it's traditional construction. I would worry about completely covering it in any way that might trap condensation, so I think the preventative measures are to ensure it is reasonably shielded from dirt and water and then inspect it once or twice a year. Interesting though that protecting the car's electrical circuit might put the occupants at risk if the fuse pops at the wrong time and place!
Tom
2018 Plus 4
Re: Main Fuse [Re: IcePack] #560026
15/02/19 06:07 PM
15/02/19 06:07 PM
South West France
CBY Offline
CBY  Offline
South West France
For remote boat (models) we insert the receiver in a small balloon (like used for birthday by exemple) in order to avoid water inflow.
Regards
2005 PLUS 4
Page 3 of 3 1 2 3
Moderated by  Aeroman, Simon
