10 registered members (Sir Percival, IcePack, N22MOG, B3MOG, Spanner Juggler, SimonH, Graham, G4FUJ, Nickplus4, Q8morgan, Aeromax51), 50 guests, and 11 spiders.
+8Rich 256
John V6 120
Peter J 118
Hamwich 111
Radio reception
by Riverstar. 26/01/20 12:51 PM
Coronavirus / Corona Virus
by Cat302. 26/01/20 01:54 AM
Wiper end caps
by David_E. 25/01/20 10:19 PM
Speedometer Calibration
by planenut. 25/01/20 09:02 PM
Easy-Up Hood stay
by Themorganeer. 25/01/20 07:37 PM
Aerial Fitting "HELP"
by Nostalgiajohn. 25/01/20 07:19 PM
Germany - an aera of MORGAN thieves?
by xc68anc. 25/01/20 02:01 PM
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
Bevel box oil leak
Hogmanay Run
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,081
Posts601,726
Members6,812
Most Online1,033
Dec 28th, 2019
No Birthdays
Page 3 of 3 1 2 3
Re: Main Fuse [Re: IcePack] #559657
13/02/19 07:54 PM
13/02/19 07:54 PM
I
IcePack Online content OP
IcePack  Online Content OP
I
Found it, same place as Rog found his. But having cut the cable tie attaching it to the other +ve cables, their is still very little slack to allow access to the fuse.
Cleaned it up with some ACF 50 & put a cable tie around it to hold it together & returned it to it’s original position with a new cable tie. (Stops it contacting the frame)
4/4 Ivory 4.1:1 axle, Jaguar XE R-Sport.
Re: Main Fuse [Re: IcePack] #559852
14/02/19 10:27 PM
14/02/19 10:27 PM
north yorkshire
Lowflyer Offline
Lowflyer  Offline
north yorkshire
I've wrapped a plastic bag around my maxi fuse with a bag of silica gel inside (oh, and a spare fuse) Wether or not i ever remember to dry out the silica gel or not is another question....thjs post has just reminded me !!!!
Re: Main Fuse [Re: IcePack] #559930
15/02/19 11:14 AM
15/02/19 11:14 AM
E
Esprit Offline
Esprit  Offline
E
Quote:
I'm reasonably relaxed about this Tom. My Roadster has the main bank of fuses on the bulkhead. Recently I pulled them (eight) and just polished the contacts, which were slightly tarnished.
The bank of twenty fuses under the dash is hard to get at so I only go there when I have to, such as when the horns stopped working.
The single main fuse in the rear cavity I would only check if I was in there.
Thanks Dave. I just realised I hadn't acknowledged your response so apologies for my bad manners. I've realised that this is probably also a feature of my other cars so the only issue is that the fuse may be less protected in the Morgan due to it's traditional construction. I would worry about completely covering it in any way that might trap condensation, so I think the preventative measures are to ensure it is reasonably shielded from dirt and water and then inspect it once or twice a year. Interesting though that protecting the car's electrical circuit might put the occupants at risk if the fuse pops at the wrong time and place!
Tom
2018 Plus 4
Re: Main Fuse [Re: IcePack] #560026
15/02/19 06:07 PM
15/02/19 06:07 PM
South West France
CBY Offline
CBY  Offline
South West France
For remote boat (models) we insert the receiver in a small balloon (like used for birthday by exemple) in order to avoid water inflow.
Regards
2005 PLUS 4
Page 3 of 3 1 2 3
Moderated by  Aeroman, Simon
