0 registered members (), 252 guests, and 16 spiders.
+8Rich 382
John V6 199
TBM 136
CooperMan 112
Hamwich 103
Bill Box, John H, Colin McFadden, N2S3, Davetherave
7656 Registered Users
Lubing the beading strip
by SALMO. 27/09/21 02:52 PM
Dash panel colour matched stitching
by Lindo. 26/09/21 09:14 PM
Cracked screen
by TimG. 26/09/21 02:54 PM
Aero engined Behemoth
by Luddite. 25/09/21 10:40 PM
The first vehicle you drove ?
by +8Rich. 25/09/21 08:00 PM
How many of you have considered letting it go?
by HalfFull. 25/09/21 03:14 AM
2016 Roadster. Head light questions
by Davetherave. 24/09/21 05:21 PM
Lindo pics
FolkMog 25th anniversary bash at Hunstanton
Reinforced battery cradle for 2015 4/4
And for my next trick...
Guernsey Escape
Topics42,119
Posts706,370
Members7,656
Most Online1,033
Dec 28th, 2019
No Birthdays
Morgan Centrelock Trad wheels #561621
22/02/19 06:57 PM
22/02/19 06:57 PM
auckland new zealand
waikiore Offline OP
waikiore  Offline OP
Not sure if I have asked this before but what is the factory recommended tightening torque for these wheels fitted around 2000 as an option on the plus 8 ?
99 plus 8 indigo
Re: Morgan Centrelock Trad wheels [Re: waikiore] #561652
22/02/19 09:16 PM
22/02/19 09:16 PM
Taffmog Offline
Taffmog  Offline
Sorry no idea but tight!
Presumably they will have a grub screw to line up with the indentation in the hub a la series 1 Aero?
No doubt someone more knowledgeable that me will be along shortly with a definitive answer.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Re: Morgan Centrelock Trad wheels [Re: waikiore] #561677
23/02/19 12:08 AM
23/02/19 12:08 AM
waikiore Offline OP
waikiore  Offline OP
No grubby screw unlike club sport Porsches and series one Aeros that's why I would like to know , a couple of the English dealers said they use an 8' bar but I would rather utilise a torque wrench .
99 plus 8 indigo
Re: Morgan Centrelock Trad wheels [Re: waikiore] #561678
23/02/19 12:14 AM
23/02/19 12:14 AM
Llanelli
Ray Offline
Ray  Offline
Llanelli
Are you sure they said 8' that would be a huge force ?
Re: Morgan Centrelock Trad wheels [Re: waikiore] #561711
23/02/19 09:30 AM
23/02/19 09:30 AM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
I use the pressed steel MG style tool on my two eared spinners. It's just over 26" long and pleased to say with gloves I was comfortably able to undo the factory tightened wheels after a couple of nudges. I would imagine a three foot breaker bar the maximum to avoid damage.
Given the design nature of removal/fitting with a hammer and the self tightening effect, my view is the exact torque is not critical.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Morgan Centrelock Trad wheels [Re: waikiore] #561714
23/02/19 10:36 AM
23/02/19 10:36 AM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
If there are wheels with a single centernut, there is a good information on the wheel manufacturer MWS.
Centernuts are allways selffixing. Proved also by Keith at BHM yesterday.
René
http://www.mwsint.com/site/cms/contentCategoryView.asp?category=214
2018 plus4
Re: Morgan Centrelock Trad wheels [Re: waikiore] #561721
23/02/19 11:33 AM
23/02/19 11:33 AM
Reading
Rob Thornton Offline
Reading
If you mean the centre lock alloy wheels I know that it is important that these are tightened to the correct torque setting although I don't know what this is. The reason for my reply though is that in reading your post and the ones following yours I have a couple of observations from my own experience of these wheels which, incidentally, I think are the best looking wheels for the +8 but they have their drawbacks unlike the steel wire wheels.
It would seem that once the nuts are tightened to the correct torque they are almost impossible to get off even with a very extended lever. I think that this is the reference to the 8 foot long bar by the way. I certainly couldn't get one off with a similar length bar coupled to the special socket lever. A hydraulic gun as used at race meetings was the only solution to my predicament. The Plus 8 wheels didn't have the grub screw security found on the aeros, hence the importance of knowing the torque setting.
I have put my wire wheels back on as I know that the spinners behave differently to the alloy nuts and I wanted the reassurance that I could change a wheel if I was touring miles away from a garage with special apparatus and the right sized socket for the nut which, incidentally, is of a different external dimension to the steel nut used on the wires.
I know that this hasn't answered your question but if you are indeed referring to the centre lock alloys I think that the factory or your dealer may be best placed to answer this as I know that they are aware of the very specific issues regarding these wheels.
I would certainly be interested to know whether other owners with such wheels could offer their advice or recommendations based on their own experience.
Rob T
2001 Royal Ivory Plus 8
Re: Morgan Centrelock Trad wheels [Re: waikiore] #561732
23/02/19 01:14 PM
23/02/19 01:14 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
A 2' bar welded onto the MMC supplied socket delivers the right torque for tightening up, I have a 6' sleeve to fit over the bar for un tightening them and this has worked for the 5 years ownership.
When I did know the correct torque I worked out it required a 2' bar but I can't remember the figure now.
This is my ex 4/4 Sport bar and socket from Millers, which is spot on for loosening the nut when slid over the 2' bar.
Regards Richard
1994 Connaught Green +8 prev
Re: Morgan Centrelock Trad wheels [Re: waikiore] #561819
23/02/19 07:39 PM
23/02/19 07:39 PM
waikiore Offline OP
waikiore  Offline OP
Thanks for the replies but just to clarify I am referring to Centrelock alloys not wire wheels a very different thing, Richard has the type of socket I have, since I can't carry a race spec rattle gun around with me am looking to utilise a torque multiplier and would like to be accurate . They can't be undone with my 100kg on a 5' bar at present, which is what I was informed to expect by some knowledgeable uk dealers .
99 plus 8 indigo
Re: Morgan Centrelock Trad wheels [Re: waikiore] #561855
24/02/19 02:16 AM
24/02/19 02:16 AM
Taffmog Offline
Taffmog  Offline
Ring Mark Baldwin at the Factory service dept. I’m sure he’ll know the ‘official’ torque setting.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
