5 registered members (Graham, G4FUJ, John Winn, JMD, MiltonMan, OZ 4/4), 170 guests, and 14 spiders.
John V6 321
TBM 215
+8Rich 198
Tyre age and renewal
by Neil49. 28/11/20 09:54 PM
Oil pressure
by M2AERO. 28/11/20 06:46 PM
1997 Plus 8 tickover
by Phil+8. 28/11/20 04:22 PM
Iridium spark plugs
by Jads. 28/11/20 03:42 PM
Whisky
by donaldosaurus. 28/11/20 03:07 PM
3.7 l Roadster throttle peddle
by John V6. 28/11/20 11:06 AM
re 4/4 fuel gauge
by bruce. 28/11/20 01:49 AM
More November Sun...
November Sun
Is this a 4 to 3 wheeler conversion?
Sunday Trip Out
New member
E.Gumiero, Grump, Fjmorgan, KJD, Mike Woodroffe
7255 Registered Users
Topics39,948
Posts662,407
Members7,255
Most Online1,033
Dec 28th, 2019
Nicko
starting or not starting new +4 #566196
14/03/19 09:01 PM
14/03/19 09:01 PM
Germany, Rhein-Main Area
X
xc68anc Offline OP
xc68anc  Offline OP
X
Since november 2018 I'm a happy owner of a new +4
To be prepared I read a lot of stuff... The most I read, I think, bad idea - I' ve got a garage without any electrical possibilities.
The stuff was:
here in TM non starting new +4
Misscellany January 2019 Deve W. page 18
Owner's Handbook version III page 94
Summary: "get your battery loaded" or the handbook: "if the vehicle is left standing for more than 3 days...." THREE DAYS!!!
Ups, the good thing: nice - go a little out in the MOG twice a week... The bad: no time, much rain, a little deep temperatures.
Now the good news: not out in her for more than a week (eight days). The display in the speedo shows 12.4 Volts... Key in, turn and: vrooom...
A good (and not only nice) girl
René
2018 plus4
Re: starting or not starting new +4 [Re: xc68anc] #566197
14/03/19 09:03 PM
14/03/19 09:03 PM
North of Stamford, UK
HeadlessBlue Offline
Glad you got going ok René
HB
Awaiting Plus Four, prev 110 Plus 4 - “Florence”
Tesla Model 3 AWD LR - “Ernie”
A3 S Line
Re: starting or not starting new +4 [Re: xc68anc] #566209
14/03/19 09:17 PM
14/03/19 09:17 PM
Luton, Bedfordshire
Fox Terrier Offline
Fox Terrier  Offline
Luton, Bedfordshire
Worth getting a C-Tek battery charger and keeping it plugged in through the 12v socket all the time. Keeps the battery in optimum condition all the time.
Morgan Plus 4
Brompton M6L
Giant TCX Advanced
Re: starting or not starting new +4 [Re: xc68anc] #566230
14/03/19 10:23 PM
14/03/19 10:23 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
Hello Rene,
I have a workshed that has no possibility for electricity and use a solar power system. Works very well for lights and also charges batteries that operate tools,etc. I would look into a solar system, assuming you have a south facing aspect. You can also purchase solar car battery charging systems that will keep your battery at optimum charge.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Re: starting or not starting new +4 [Re: xc68anc] #566266
15/03/19 05:09 AM
15/03/19 05:09 AM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
In my experience I have had no problem with the car left for 2 weeks in summer. I believe cold weather is hard on batteries however and I have always put it on the "battery conditioner" in winter.
Our car has now done over 65,000 km and I believe the fact that I nearly always have the battery conditioner (trickle charger) plugged in has kept the now 7 year old battery in good condition.
I can't even remember what brand it is. I ordered it from the factory with the car.
There are solar battery charger kits available to keep boat batteries charged. One of these would be a good idea if no power is available in the garage. Provided of course that the garage is not underground smile
Re: starting or not starting new +4 [Re: xc68anc] #566284
15/03/19 07:10 AM
15/03/19 07:10 AM
X
xc68anc Offline OP
xc68anc  Offline OP
X
The thing is: there is no possibility for electric systems in the garage. Also something with solar is no option.
About the car: they changed something in the wiring or/and the immobilizer, so the batterie runs flat quickly. As I parked the car the batterie was well over 13V (13.4 or more), after six days it shows only 12.4V.
If I remember right, I read somewhere there would be problems in the communication between key and immobilizer if the power went down under 13V.
So I was very glad, that it also work with only 12.4V. A good car ;-)
René
2018 plus4
Re: starting or not starting new +4 [Re: xc68anc] #566288
15/03/19 07:28 AM
15/03/19 07:28 AM
Northern England
Northernmorgan Offline
Northern England
Fit an immobiliser switch to disconnect the battery if you are not using the car for sometime. A pain in someways as you’ll need to reset the clock etc but in the absence of power or the inability to use solar panels I don’t see what other options you have.
I’ve akways been a sceptical about solar panels but last year we rigged up one...about A3 in size to the battery on our boat.....it really did trickle charge it well!
I’m a convert.
1936 Austin Seven Ulster Replica
Re: starting or not starting new +4 [Re: xc68anc] #566293
15/03/19 07:54 AM
15/03/19 07:54 AM
auckland new zealand
waikiore Offline
waikiore  Offline
Yes I put a small solar panel on the boat we use most and amazingly it keeps the house and engine batteries so well topped up that I have not had to plug in to shore power ever since , absolutely fantastic .
99 plus 8 indigo
Re: starting or not starting new +4 [Re: xc68anc] #566307
15/03/19 08:46 AM
15/03/19 08:46 AM
howard Offline
howard  Offline
Allo, allo René. smile 12.4v is a bit less than half capacity so you maybe have 12 days before its so low the engine wont start. However, getting the car to start is one thing - it takes far more running than you might think to fully charge the battery. On my boat, it takes more than 6 hours because of course the current flow into the battery falls rapidly as the back emf builds up.
Use some thing like an Optimate. I use a solar panel on my boat as well as a wind generator. But the latter wont look good on the car.
The simplest solution is a swithch on the battery terminal but I dont know whether that would be accessible on a Morgan.
Re: starting or not starting new +4 [Re: howard] #566310
15/03/19 08:52 AM
15/03/19 08:52 AM
Germany
Fullhoza Offline
Fullhoza  Offline
Germany
Rene, in the absence of a power outlet and sunlight, I would also recommend the battery kill switch. My father uses it on his 2001 +8 (a lot of Kriechstroeme...) whenever he gets out of the car. Also a great theft protection! However, I have a Jan 2018 Plus 4, and only after six weeks in very cold winter has it left me standing.
Something like this: Battery switch
Moderated by  Aeroman, Simon
