6 registered members (JMD, pandy, Tresco, Dada, Malcolm T, RedThree), 144 guests, and 12 spiders.
+8Rich 437
John V6 423
TBM 233
Heinz 191
Morgan 100 Programme 10
by Hotwells. 05/06/20 07:09 PM
Steel Sprocket
by Dutch. 05/06/20 07:07 PM
1981 +8 water pipes
by GARYMYNARD. 05/06/20 04:54 PM
Plus 4 Push Button Start?
by Nostalgiajohn. 05/06/20 02:45 PM
vdo speedo
by milliemollie. 05/06/20 12:50 PM
Interesting new hardtop
by +8Rich. 05/06/20 12:43 PM
the classic / collectors car market
by howard. 05/06/20 09:53 AM
Hard Top Badge
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,425
Posts629,871
Members6,938
Most Online1,033
Dec 28th, 2019
DaveK, James Nolan
starting or not starting new +4 #566196
14/03/19 09:01 PM
14/03/19 09:01 PM
Germany, Rhein-Main Area
X
xc68anc Offline OP
xc68anc  Offline OP
X
Since november 2018 I'm a happy owner of a new +4
To be prepared I read a lot of stuff... The most I read, I think, bad idea - I' ve got a garage without any electrical possibilities.
The stuff was:
here in TM non starting new +4
Misscellany January 2019 Deve W. page 18
Owner's Handbook version III page 94
Summary: "get your battery loaded" or the handbook: "if the vehicle is left standing for more than 3 days...." THREE DAYS!!!
Ups, the good thing: nice - go a little out in the MOG twice a week... The bad: no time, much rain, a little deep temperatures.
Now the good news: not out in her for more than a week (eight days). The display in the speedo shows 12.4 Volts... Key in, turn and: vrooom...
A good (and not only nice) girl
René
Re: starting or not starting new +4 [Re: xc68anc] #566197
14/03/19 09:03 PM
14/03/19 09:03 PM
North of Stamford, UK
HeadlessBlue Offline
Glad you got going ok René
HB
Re: starting or not starting new +4 [Re: xc68anc] #566209
14/03/19 09:17 PM
14/03/19 09:17 PM
Luton, Bedfordshire
Fox Terrier Offline
Fox Terrier  Offline
Luton, Bedfordshire
Worth getting a C-Tek battery charger and keeping it plugged in through the 12v socket all the time. Keeps the battery in optimum condition all the time.
Morgan Plus 4
Brompton M6L
Giant TCX Advanced
Re: starting or not starting new +4 [Re: xc68anc] #566230
14/03/19 10:23 PM
14/03/19 10:23 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
Hello Rene,
I have a workshed that has no possibility for electricity and use a solar power system. Works very well for lights and also charges batteries that operate tools,etc. I would look into a solar system, assuming you have a south facing aspect. You can also purchase solar car battery charging systems that will keep your battery at optimum charge.
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: starting or not starting new +4 [Re: xc68anc] #566266
15/03/19 05:09 AM
15/03/19 05:09 AM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
In my experience I have had no problem with the car left for 2 weeks in summer. I believe cold weather is hard on batteries however and I have always put it on the "battery conditioner" in winter.
Our car has now done over 65,000 km and I believe the fact that I nearly always have the battery conditioner (trickle charger) plugged in has kept the now 7 year old battery in good condition.
I can't even remember what brand it is. I ordered it from the factory with the car.
There are solar battery charger kits available to keep boat batteries charged. One of these would be a good idea if no power is available in the garage. Provided of course that the garage is not underground smile
Re: starting or not starting new +4 [Re: xc68anc] #566284
15/03/19 07:10 AM
15/03/19 07:10 AM
X
xc68anc Offline OP
xc68anc  Offline OP
X
The thing is: there is no possibility for electric systems in the garage. Also something with solar is no option.
About the car: they changed something in the wiring or/and the immobilizer, so the batterie runs flat quickly. As I parked the car the batterie was well over 13V (13.4 or more), after six days it shows only 12.4V.
If I remember right, I read somewhere there would be problems in the communication between key and immobilizer if the power went down under 13V.
So I was very glad, that it also work with only 12.4V. A good car ;-)
René
Re: starting or not starting new +4 [Re: xc68anc] #566288
15/03/19 07:28 AM
15/03/19 07:28 AM
Northern England
Northernmorgan Offline
Northern England
Fit an immobiliser switch to disconnect the battery if you are not using the car for sometime. A pain in someways as you’ll need to reset the clock etc but in the absence of power or the inability to use solar panels I don’t see what other options you have.
I’ve akways been a sceptical about solar panels but last year we rigged up one...about A3 in size to the battery on our boat.....it really did trickle charge it well!
I’m a convert.
1936 Austin Seven Ulster Replica
Re: starting or not starting new +4 [Re: xc68anc] #566293
15/03/19 07:54 AM
15/03/19 07:54 AM
auckland new zealand
waikiore Offline
waikiore  Offline
Yes I put a small solar panel on the boat we use most and amazingly it keeps the house and engine batteries so well topped up that I have not had to plug in to shore power ever since , absolutely fantastic .
99 plus 8 indigo
Re: starting or not starting new +4 [Re: xc68anc] #566307
15/03/19 08:46 AM
15/03/19 08:46 AM
howard Offline
howard  Offline
Allo, allo René. smile 12.4v is a bit less than half capacity so you maybe have 12 days before its so low the engine wont start. However, getting the car to start is one thing - it takes far more running than you might think to fully charge the battery. On my boat, it takes more than 6 hours because of course the current flow into the battery falls rapidly as the back emf builds up.
Use some thing like an Optimate. I use a solar panel on my boat as well as a wind generator. But the latter wont look good on the car.
The simplest solution is a swithch on the battery terminal but I dont know whether that would be accessible on a Morgan.
Re: starting or not starting new +4 [Re: howard] #566310
15/03/19 08:52 AM
15/03/19 08:52 AM
Germany
Fullhoza Offline
Fullhoza  Offline
Germany
Rene, in the absence of a power outlet and sunlight, I would also recommend the battery kill switch. My father uses it on his 2001 +8 (a lot of Kriechstroeme...) whenever he gets out of the car. Also a great theft protection! However, I have a Jan 2018 Plus 4, and only after six weeks in very cold winter has it left me standing.
Something like this: Battery switch
Moderated by  Aeroman, Simon
