Who's Online
2 registered (kankeL, Bunny), 111 Guests and 17 Spiders online.
Southern Weather comes North
Island of Muhu in the rain
65 Plus 4 Four Seater back seat Lift-a-dot studs
Fuel cap seal
Touring Scotland with Anglemog.
Rolls Royce Cullinan
by MJF
17/06/19 09:46 PM
Do you think I've achieved full penetration?
by Lowflyer
17/06/19 09:40 PM
"new" Top Gear
by MDS61
17/06/19 09:18 PM
Fitting wing beading to “sill”
by Phil4/4
17/06/19 08:10 PM
How reliable are current Three Wheelers.
by PaulJ
17/06/19 06:39 PM
Quarter Panel Protectors
by AndyA
17/06/19 03:26 PM
Mog19
by DaveW
17/06/19 10:53 AM
arnieb, BradB, PANTHRO, MarsdenRobinson, M500
6524 Registered Users
Shout Box
Forum Stats
6,524 Registered Members
33 Forums
35,386 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
Paperix
Page 3 of 3 < 1 2 3
Topic Options
#566440 - 15/03/19 03:57 PM Re: starting or not starting new +4 [Re: xc68anc]
Button Offline
Loc: Seattle, USA
My +8 Bitsa has an Odyssey PC680 (small motorcycle battery). I have a Lithium Battery car starter with flashlight. Quite small and does the job. $60U.S. found online.
_________________________
Button
Top
#566457 - 15/03/19 04:43 PM Re: starting or not starting new +4 [Re: xc68anc]
Ray Offline
Loc: Llanelli
I've got one of the power packs, great in an emergency.
Top
#566462 - 15/03/19 04:51 PM Re: starting or not starting new +4 [Re: xc68anc]
Stephen888 Offline
Loc: Cambridge UK
Eight/ten weeks dormant not an issue on my +8. Starts fine. Has a battery kill switch
1980 +8 Blue
Stephen
Top
#566465 - 15/03/19 04:55 PM Re: starting or not starting new +4 [Re: xc68anc]
meabh Offline
Loc: southwest France
My last three Morgans had that red kill switch between the seats ,on the saddle board. Can I use it on the Roadster? Step forward Dave and co.
Top
#566468 - 15/03/19 05:01 PM Re: starting or not starting new +4 [Re: xc68anc]
+8Rich Offline
Loc: Devonshire
The Red kill switch is the best one - I use it every time when I park up and the battery lasts for weeks and weeks.
I never use a battery charger on any of the Morgan's I've had over the 15 years by throwing the Red switch it works everytime.
Regards Richard
2009 4/4 Sport Green
1994 Connaught Green +8
Top
#566532 - 15/03/19 07:54 PM Re: starting or not starting new +4 [Re: xc68anc]
xc68anc Offline
Loc: Germany, Rhein-Main Area
There my "little specials":
The garage ist a little bit away from the house.
Than it is a typical german 1960ies one. Ten garages in a row with a steel concrete roof, with a special tarmac as a top layer.
To repair it is a little bit expensive, so I don't want to drill a hole for a solar in it.
And: when I'm the first, others will follow. Holes in a waterproof construction - water will find the way.
So no electric in or nearby, no solar option.
And: it's clear a 12.4V battery is not full powered by three turns around the corners. Most as possible car electric switched off, if the engine is warm turning up the revs for more power from the dyno (correct word?).
My main intention: don't be affraid about a low voltage, and enjoy every loading possibility ;-)
René
Top
#566540 - 15/03/19 08:23 PM Re: starting or not starting new +4 [Re: xc68anc]
Ray Offline
Loc: Llanelli
It's only a thin cable that can be run through joint or frame of doors to the soler panel.
Top
#566641 - 16/03/19 09:47 AM Re: starting or not starting new +4 [Re: xc68anc]
John V6 Offline
Loc: Suffolk
I mounted mine vertically on the outside wall. It doesn't need to be on the roof.
2006 Indigo Blue Roadster S1
Top
#566751 - 16/03/19 05:47 PM Re: starting or not starting new +4 [Re: xc68anc]
Ray Offline
Loc: Llanelli
Mines behind a perspex window.
Top
Page 3 of 3 < 1 2 3
