16 registered members (Paul F, DCH, Kevcaster, HalfFull, Spanner Juggler, TBM, dogmog, M3W55, Mike D, John07, lowebird, petemog, AndyrIch, Morph, mise303, RobNW), 88 guests, and 17 spiders.
John V6 445
+8Rich 415
Hawki 180
MORGAN BIDS FAREWELL TO THE STEEL CHASSIS
by Morph. 07/07/20 11:45 AM
Help - Fitting Leaf Springs Post 2006 4 Seater
by flyfisher. 06/07/20 07:43 PM
Caister Castle Motor Museum. Wed 8/7/20
by John V6. 06/07/20 04:25 PM
Protune 2 communication
by Marmota. 06/07/20 01:13 PM
Mr Microsoft & Edge
by John V6. 06/07/20 11:56 AM
This could save you a few quid
by athelstan. 06/07/20 10:16 AM
Another Auction
by Treesurveyor. 05/07/20 10:31 PM
My new Plus Four
Back from professional washing and waxing
A trip to Essex
Illuminated Morgan wings homemade
FORGAN/MORRARI
The Alternator, m3wofl, Klaus-Peter K, dbl19, motorcar garage
7047 Registered Users
Topics38,721
Posts636,418
Members7,047
Most Online1,033
Dec 28th, 2019
No Birthdays
Re: starting or not starting new +4 [Re: xc68anc] #566320
15/03/19 09:15 AM
15/03/19 09:15 AM
East Harling, Norfolk UK
Richard Wood Offline
If a car with fully charged battery won't start after just two weeks then the battery needs replacing due to its diminished capacity.
Smart battery chargers/conditioners left on float charge 24/7 will help prolong battery life but will eventually mask the reduced capacity - being the usual form of battery degradation. You could then become stranded following the first overnight away from home and charger.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: starting or not starting new +4 [Re: xc68anc] #566322
15/03/19 09:33 AM
15/03/19 09:33 AM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
The good ladies Mini Cooper often sits as I do the driving when we are together. We fitted an AA solar panel on the dash and it keeps power well now. If you cannot get light or power then the only thing I can think of is a small battery cart like F1 teams use. Don’t underestimate the weight of them and under spec the cart strength. Get a couple of low cost batteries and wire them in parallel for more grunt. Use heavy cable, ask a local motor factor for some cables from a car as they will have something practical. Roll it in and leave it to charge for a couple of days then take it away and give it a boost?
Just time to burn a little more petrol before dinner.
Re: starting or not starting new +4 [Re: xc68anc] #566361
15/03/19 11:51 AM
15/03/19 11:51 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Are you really sure you can't get a solar panel out side?
On my shed the panel is literally screwed onto the vertical side of the shed with a hole drilled through. It keeps the battery topped up for lights.
Prior to that at our old house the same panel screwed to the wall kept the Mog battery topped up till I bought a CTEK.
2006 Indigo Blue Roadster S1
Re: starting or not starting new +4 [Re: xc68anc] #566370
15/03/19 12:51 PM
15/03/19 12:51 PM
Yorkshireman living in Surrey
Bonesie Offline
Bonesie  Offline
What am I missing here ? I read that in my manual and thought it was a printing error
A modern mog has a modern electrical system. Im no auto leccy but really, three days ?
In car with modern electrics and a healthy battery there surely should be no way you need to 'top up' after three days sitting.
Ive left cars for weeks before and they have fired right up. Is there something inherent in Morgans that drains batteries ?
Bonesie
Re: starting or not starting new +4 [Re: Bonesie] #566382
15/03/19 01:31 PM
15/03/19 01:31 PM
Renfrewshire
BobtheTrain Offline
BobtheTrain  Offline
Renfrewshire
It's the Flux Capacitor that takes the cars back in time.
Best Regards
Lang may yer lum reek
Re: starting or not starting new +4 [Re: Bonesie] #566387
15/03/19 01:47 PM
15/03/19 01:47 PM
Newcastle Upon Tyne
James B W Offline
James B W  Offline
Newcastle Upon Tyne
- in short, YES!!
to be fair, there appear to be as many opinions on the cause as there are commentators.
Certainly on the Aero8, the major suspect seems to be the BMW/Morgan ECU interface which ( I suspect) has a minor but constant drain.
Also, the Aero8 should (in my opinion) really have a larger battery - but there is not the room for one. swear
A CTEK charger or similar is the solution for me - but this can have issues with the Odyssey Gel battery (as I have posted on before).
A compact lithium jump starter pack is my back-up plan normally....
James
Range Rover Evoque S
Smart Brabus Convertible
Re: starting or not starting new +4 [Re: BobtheTrain] #566390
15/03/19 01:50 PM
15/03/19 01:50 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
If fitted then immobilisers and alarms will drain the battery. Many modern cars will only last a few weeks before being unable to start.
If there's no outside power source then a battery disconnect switch is the solution.
I use a Battery Brain on my M3W so I can disconnect/reconnect without having to take the front cowl off.
https://www.batterybrain.co.uk/
Red Leader drive
Re: starting or not starting new +4 [Re: xc68anc] #566396
15/03/19 02:16 PM
15/03/19 02:16 PM
PHZI Offline
PHZI  Offline
Well if all else fails, keep a fully charged battery booster/starting pack in the house.
Re: starting or not starting new +4 [Re: Chris99] #566413
15/03/19 03:03 PM
15/03/19 03:03 PM
Bonesie Offline
Bonesie  Offline
I have an immobiliser. I shall monitor the situation !
Bonesie
Re: starting or not starting new +4 [Re: xc68anc] #566426
15/03/19 03:24 PM
15/03/19 03:24 PM
Llanelli
Ray Offline
Ray  Offline
Llanelli
Solar has worked for me this winter, while car was off road for two months. It is a small caravan type,from maplins.,.. sadly no more.
Moderated by  Aeroman, Simon
