5 registered members (Ricardo, JohnMat, AndyN, LightSpeed, PeterG), 153 guests, and 17 spiders.
John V6 444
+8Rich 418
Hawki 186
TBM 158
Buy in haste, repent at leisure...
by Aeromax76. 11/07/20 08:47 PM
Check your wiring..
by SteveT. 11/07/20 07:06 PM
Live US auction
by Luddite. 11/07/20 03:09 PM
Castle nut adjustment or king pin ?
by meabh. 11/07/20 11:42 AM
Graham, G4FUJ - look away NOW!!
by James B W. 11/07/20 10:57 AM
Charles @ Britishvolt
by Alistair. 10/07/20 09:40 PM
Hi from Hereford
by Tally Ho. 10/07/20 04:33 PM
American Beauty
New Aeromax in Oxford
Another Great Escape. Caister Motor Museum
RUY255 on Autosport Cover
why we love living in the mountains
Saxonian, GlenB 4475, Simon m wright, dominicalbarn, Sib8292
7053 Registered Users
Topics38,758
Posts637,264
Members7,053
Most Online1,033
Dec 28th, 2019
Freewheeling
Page 3 of 3 1 2 3
Re: Turbo Plus 4 Plus -- final report [Re: griffo] #573632
25/04/19 10:48 AM
25/04/19 10:48 AM
Somerset, UK
PaulJ Offline
PaulJ  Offline
Somerset, UK
Thanks for the suggestion Peter, but Heinz is absolutely right. I did do quite a bit of research into a blower early on in my tenure, including having a long to to a guy at Cosworth, and the general advice was that it just is not worth the trouble and expense. It would probably end up costing the same as Griffos conversion once all the extra bits and pieces plus work in getting it all to function have been added.
The answer is to forget torque and buzz along in one gear lower than normal. As it happens after 7000 odd miles, it seems to be getting torquier in the low and mid range, but nowhere near what a modern Ecotec engine is giving.
[Beginning to get the best out of the ARP4]
Re: Turbo Plus 4 Plus -- final report [Re: griffo] #573651
25/04/19 03:00 PM
25/04/19 03:00 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
I'm just getting used to the 2.0L turbo 4 engine in my new Mercedes A35. It has a twin scroll turbo, develops 302bhp and 295 ft lbs torque from 2500 rpm.
There is no detectable turbo lag, the engine spins up to the running in rev limit of 4500 rpm.
Based on Griffo's report and my experience with the A35 the Turbo +4, when it appears, will be magnificent! The BMW B48 motor, which I guess will be used, develops about 300 bhp and 300 ft lbs torque, depending on the installation.
Tarka the 'Otter Mog
2014 Plus 8
Re: Turbo Plus 4 Plus -- final report [Re: griffo] #573656
25/04/19 03:19 PM
25/04/19 03:19 PM
Rovert Offline
Rovert  Offline
I find the concept of a 2 litre, 4 pot producing 300 bhp for use in a hefty road car a bit unreal. It would take a lot of money to make my 4 litre V8 produce that!
Brian
Jersey and Spain
Re: Turbo Plus 4 Plus -- final report [Re: Rovert] #573663
25/04/19 04:22 PM
25/04/19 04:22 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
Perhaps the 185 kW (248 hp) version would be more realistic. 350 N⋅m (258 lb⋅ft)at 1,450–4,800 rpm would be more than enough and you would need some difference in both performance and price when compared to the Plus 6.
Then there would be the Plus 3 wink with the B38A15M0 1,500 cc 100 kW (134 bhp)at 4,400-6,000 rpm 220 N⋅m (162 lb⋅ft)at 1,250-4,300 rpm.
To put that in context the current (or outgoing) Roadster develops Max Torque 380Nm (280lb/ft) but does not do so across such a wide range. The GDI Plus 4 develops Max Torque 201 Nm (148 lb/ft), again only at high RPM.
Re: Turbo Plus 4 Plus -- final report [Re: Gambalunga] #573688
25/04/19 07:09 PM
25/04/19 07:09 PM
Shropshire
MDS61 Offline
MDS61  Offline
Shropshire
Is there a market for taking an old Plus Four worth £25kish and updating it with a 4 pot turbo (plus brakes, suspension and chassis tweaks) and having a great car for £32kish...blowing most things on the road into the weeds? cheers
2004 Roadster S1 3.0 V6 - "Seve"
Mark
Re: Turbo Plus 4 Plus -- final report [Re: MDS61] #573704
25/04/19 09:00 PM
25/04/19 09:00 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
If it is legally feasible in the UK I see an interesting market here. Buy a Plus 4 Duratec from about 2005 if possible with an engine failure to drop the price even more (which is unlikely due to the robust engines and the often low mileage). Anyway it should be possible and result in a cool car.
Re: Turbo Plus 4 Plus -- final report [Re: griffo] #573705
25/04/19 09:05 PM
25/04/19 09:05 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
Doing it when no one is looking would definitly be best in Italy. And honestly you would never get it past the Department of Motorizzazione (the Italian equivalent of the DVLA). This is one area where the UK has a long and liberal tradition.
Here the red tape, engineers certificates and the bureaucracy would block you at every move.
Re: Turbo Plus 4 Plus -- final report [Re: griffo] #573708
25/04/19 09:14 PM
25/04/19 09:14 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
A morgan has the big advantage of being a morgan. With a Morgan I would risk the engine conversion because hardly anyone knows about it. The car is so exotic that it enjoys great levels of freedom. Even my exhaust manifold would not be considered doubtful in a traffic control. It can also be a little louder.
All these changes on a VW Polo and the young owner would have problems immediately.
Re: Turbo Plus 4 Plus -- final report [Re: Gambalunga] #573719
25/04/19 11:04 PM
25/04/19 11:04 PM
West Dorset
rid967 Offline
rid967  Offline
West Dorset
[quote=Gambalunga]Perhaps the 185 kW (248 hp) version would be more realistic. 350 N⋅m (258 lb⋅ft)at 1,450–4,800 rpm would be more than enough and you would need some difference in both performance and price when compared to the Plus 6.
Agree entirely. This would be, in my opinion, the ideal modern Morgan and a worthy continuation of the heritage allied to sensible compliance with the tightening regulatory environment.
Cheque book at the ready for deposit!
3.7 Roadster
Porsche 964 C2
JCW Mini Cooper S Cab
BMW 1200 GS
+4 4 1995-2002 / LM 62 +8 2002-07
Re: Turbo Plus 4 Plus -- final report [Re: Gambalunga] #575672
08/05/19 08:29 AM
08/05/19 08:29 AM
Reading
A11OGE Offline
A11OGE  Offline
Reading
I have just quoted this to my son this morning. We both agree.
This could be the quote of the day.
as is "“Worrying is like sitting in a rocking chair. It gives you something to do, but it doesn’t get you anywhere. “ Erma Bombeck, 1927–1996.
Page 3 of 3 1 2 3
Moderated by  Aeroman, Simon
