13 registered members (PaulJ, M3W55, Chris Shilton, LightSpeed, teifistar, westgardronning, Graham, G4FUJ, Luddite, RobNW, MJF, Budster, JohnS, griffo), 187 guests, and 19 spiders.
John V6 454
+8Rich 403
TBM 239
Peter J 199
Late 4/4 values
by andymot. 31/05/20 10:18 AM
Corran Ferry anyone ?
by +8Rich. 31/05/20 09:31 AM
Where to go first
by thelastgizmo. 31/05/20 05:52 AM
Fossilmog Hive Beach Picnic 2020 Cancelled
by rid967. 30/05/20 10:20 PM
Testing out a steering wheel spacer
by JohnMat. 30/05/20 10:04 PM
Wearing Face Masks
by Peter J. 30/05/20 06:03 PM
New toy
by Bonesie. 30/05/20 05:31 PM
Auchindoir Church, Lumsden
Plus four Test Drive
Engine running!
Slow progress
Social distancing
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,371
Posts628,793
Members6,938
Most Online1,033
Dec 28th, 2019
7024, hbatts
Longterm Storage #573716
25/04/19 09:57 PM
25/04/19 09:57 PM
Southern Vermont
Michael H Offline OP
Southern Vermont
Bailed my lovely out of storage and tried to fire her up. So much oil had seeped into the motor that it wouldn't fire upon turn over. It was coming out of the air cleaner and spludging all over the place. Pulled plugs and cleaned. Tried again and it fired and turned over. Oil kept coming out of the breather. I think I may have lost about a half a cup or so. Motor smelled like a two cycle engine for a time. All ok now. Next time, I will drain all the oil before storing!
Re: Longterm Storage [Re: Michael H] #573718
25/04/19 10:37 PM
25/04/19 10:37 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
See my post of "crank seal leaking oil". You don't need to drain all the oil before storage, just drain the "dry" sump through the plug on the bottom of the crankcase before starting it.
Re: Longterm Storage [Re: Michael H] #573839
26/04/19 04:33 PM
26/04/19 04:33 PM
O'Fallon, Missouri USA
Dan_Lockwood Offline
I know that this suggestion is a dollar late and a day short for "this" time around, but may be helpful next year.
On my old '76 Shovelhead I have nasty sumping when I let it sit for over a month. So I fire it up about once a month so I don't spit out oil all over my floor from the crankcase vent.
But when this is not an option, I purchased these. They work great.
Three Piece Lind Clamps
I just pinch off the line between my oil tank and the inlet to the oil pump on the motor. This stops any sumping, totally stops oil from the pump... PERIOD!
BUT... DO NOT START YOUR MOTOR WITH THE CLAMP STILL ON THE LINE.
I know that sounds easy enough to remember, but I always take a string/line from the clamp up to the handle bars and then down to the ignition switch to remind me to take off the clamp before firing up the bike.
It will leave a bit of a narrowing in the line where the clamp was, but just squeeze it on the narrow sides and it rounds out quickly and when warm it goes back to its original shape without any marks at all.
I understand that the S&S has a drain plug on the bottom of the crankcase, but I don't believe they're designed to be used on a regular basis.
So preventing the oil from sumping is by far the best way to go.
Good luck!
Re: Longterm Storage [Re: Michael H] #573869
26/04/19 06:26 PM
26/04/19 06:26 PM
Port Orchard, WA.
LightSpeed Online content
LightSpeed  Online Content
Port Orchard, WA.
Surgical forceps, but for the S&S style engines. Nice idea, but how long will the tubing last by crimping it that way? Ever had one split at that crimp location after a few years of doing it?
Stephen
2019 M3W , 2Kmiles
Re: Longterm Storage [Re: LightSpeed] #573891
26/04/19 09:00 PM
26/04/19 09:00 PM
Most every winter I do this to my Shovelhead and I've still got the same hose I put on it during my refurb back in '05. Not a problem where I clamp as I'm limited to hose length access.
I'll continue to do this as long as I own the bike.
Re: Longterm Storage [Re: Michael H] #573893
26/04/19 09:11 PM
26/04/19 09:11 PM
Port Orchard, WA.
Port Orchard, WA.
Thanks Dan👍
Stephen
2019 M3W , 2Kmiles
Re: Longterm Storage [Re: Michael H] #573939
27/04/19 09:43 AM
27/04/19 09:43 AM
Germany
Player99 Offline
Player99  Offline
Germany
I let the oil out of the tank before winter time begins. In the spring time I fill the oil back into the tank. That works fine.
During the summer I move the car every two or three weeks. That is enough to have no problem with to much oil in the engine.
_______________________________________
Player
Moderated by  Aeroman
