Topics43,595
Posts733,725
Members8,033
Most Online1,033 Dec 28th, 2019
Re: Aero progress.. and a new roof!
[Re: KevinMcR]
#712173
30/07/21 10:04 PM
30/07/21 10:04 PM
Posts: 1,641 Newcastle Upon Tyne
James B W
Newcastle Upon Tyne
Looked up the bill for mine and in July 2019 one wishbone was 344 including VAT and looks like 3 hours labour to fit so all in was 560 quids! Times 2 that if being on the safe side which I was. Seemed like a lot of money until the next bill of 2.5k which included so much it was like reading a book!
Still I’m sure the next custodian will thank me even if the wife thought divorce was a cheaper option.😁 - Ouch...  James
Aero8 , Series 1 - Boston Green Range Rover Evoque S Smart Brabus Convertible Honda Monkey Z125
[Re: Viper]
#712453
02/08/21 08:30 AM
02/08/21 08:30 AM
Posts: 1,835 Buckinghamshire
NickCW
Buckinghamshire
I've only seen the Series 1 wishbones fail, but that doesn't mean it wont happen on the later cars The lower front wishbone typically fails where the caster rod bracket is welded on (circled in red) with the crack rotating around the tube These are a set I reinforced for racing years ago in the same way we did for the British GT car, by welding in additional sheet metal to prevent the wishbone from lozenging. ![[Linked Image]](https://tm-img.com/images/2021/07/29/InkedDSCN0451_LI.jpg) The top rocker arm fails around the pivot tube boss ![[Linked Image]](https://tm-img.com/images/2021/07/29/DSCN0448.jpg) ![[Linked Image]](https://tm-img.com/images/2021/07/29/DSCN0441.jpg) The rear lower wishbone likes to bend where the coilover is fixed to it Thanks for the info Simon, do you supply and dare I ask the cost? Sounds about right!
Aero 8 S1
[Re: NickCW]
#712712
04/08/21 12:46 PM
04/08/21 12:46 PM
NickCW
Buckinghamshire
Not much to update other than work is progressing, I have ordered weatherstrips to replace all the different ones over the car - as makes sense to do so now.
I am also having a specialist aluminium fabricator work on something custom for me (not as exciting as it sounds!), and just trying to source some new bits and pieces such as headlights.
Once all done it will need to go off for PPF, but I might sort the wheels, tyres and brakes whilst the paint is "curing" so to speak.
Aero 8 S1
[Re: NickCW]
#712852
05/08/21 01:13 PM
05/08/21 01:13 PM
Posts: 461 Oxted
PJC
Oxted
I can recommend a good couple of places (one in Surrey and one in Kent) for PPF if you don't already have a trusted installer.
Cheers, Paul
[Re: PJC]
#712906
05/08/21 06:46 PM
05/08/21 06:46 PM
Posts: 1,819 Sevenoaks,Kent
Viper
Sir S1'a'lot
Sir S1'a'lot
Sevenoaks,Kent
I can recommend a good couple of places (one in Surrey and one in Kent) for PPF if you don't already have a trusted installer. I’ve put snuck in touch with the guys I’ve always used in Kent, possibly sane people you’re thinking of. Super car paint protection
2000 Plus 8 4.6 2002 Aero 8 S1
[Re: PJC]
#712912
05/08/21 07:40 PM
05/08/21 07:40 PM
NickCW
Buckinghamshire
I can recommend a good couple of places (one in Surrey and one in Kent) for PPF if you don't already have a trusted installer. Thanks Paul - as Lee said might be the same place!
Aero 8 S1
[Re: NickCW]
#713040
06/08/21 04:55 PM
06/08/21 04:55 PM
Posts: 461 Oxted
PJC
Oxted
REEP in Dunsfold, Surrey is the other one.
Cheers, Paul
[Re: NickCW]
#713765
12/08/21 06:46 AM
12/08/21 06:46 AM
NickCW
Buckinghamshire
Thanks Paul. Been keeping the postman busy recently.. ![[Linked Image]](https://i.imgur.com/0cj76my.jpg)
Aero 8 S1
