1 registered members (NelsonG), 146 guests, and 20 spiders.
John V6 444
+8Rich 411
Hawki 180
TBM 160
Charles @ Britishvolt
by Alistair. 10/07/20 09:40 PM
Hi from Hereford
by Tally Ho. 10/07/20 04:33 PM
Another Oxfordshire newbie
by Aeromax76. 10/07/20 03:58 PM
Electric digger
by TimG. 10/07/20 08:08 AM
Forever Cars -Tiking
by TimG. 10/07/20 08:00 AM
Sweet Painted Lady
by +8Rich. 09/07/20 09:15 PM
door handle cylinder barrels
by BigLes. 09/07/20 07:19 PM
Another Great Escape. Caister Motor Museum
RUY255 on Autosport Cover
why we love living in the mountains
Our 2020 Morgan Plus 4   110 Anniversary Model
My new Plus Four
Saxonian, GlenB 4475, Simon m wright, dominicalbarn, Sib8292
7053 Registered Users
Topics38,751
Posts637,090
Members7,053
Most Online1,033
Dec 28th, 2019
Freewheeling
Page 1 of 5 1 2 3 4 5
Moving the pedal box #576597
15/05/19 01:24 AM
15/05/19 01:24 AM
Logan, Ohio USA
Dutch Online content OP
Dutch  Online Content OP
Logan, Ohio USA
Is there anyway to move the pedal box assembly in a 2012 left hand drive forward ? My legs are a little long and I can't seem to find a way to straighten them out and keeping my foot off the clutch.
Dutch Junge
194 Mound St
Logan, OH USA 43138
Re: Moving the pedal box [Re: Dutch] #576598
15/05/19 01:46 AM
15/05/19 01:46 AM
Southern Vermont
Michael H Offline
Michael H  Offline
Southern Vermont
No. If it is the 2012 configuration then it won't go.
It is asymmetric and works quite well on right handed drive so it will float quite easily in Britain.
Sad. One easy solution is to get a spacer for the steering wheel that extends the length of it about an inch or more. That helps tremendously.
Re: Moving the pedal box [Re: Dutch] #576605
15/05/19 05:48 AM
15/05/19 05:48 AM
Austria, Vienna area
The Austrian Offline
I improved leg space by elevating the front end of the lower seat cushion.
For testing purpose you may put a piece of wood under the front end and check if that fits your needs.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Re: Moving the pedal box [Re: Dutch] #582275
20/06/19 05:38 PM
20/06/19 05:38 PM
Belgium
E
Erwin G Offline
Erwin G  Offline
E
Belgium
My pedels are moved more backwards because of my long legs but they had to install New attachments for the hydrolic pipes.
Re: Moving the pedal box [Re: Dutch] #582284
20/06/19 06:35 PM
20/06/19 06:35 PM
New River Valley, VA
rcmatt Offline
rcmatt  Offline
raising the seat (or adding a cushion) has the effect of moving you further back. I added a cushion because I am vertically challenged and as a result had to move my pedals as well or I could not reach them
Rodger
2004 Plus 8 (wife's)
Re: Moving the pedal box [Re: Dutch] #583241
01/07/19 02:01 PM
01/07/19 02:01 PM
Sweden
Swedewheeler Offline
Sweden
Hi!!
I am new to this forum so a bit of a newbie when it comes to how everything here works....but I will give it a try!
I guess that your pedal box is already placed in the forward position? I am 192 cm and there was no way I could drive the car as standard even with the pedals in the forward position. First I opted for a smaller steering wheel and then I also rebuilt the pedal box. As standard the pedals are actually angled towards you and I found by adjusting them forward as much as possible you could get another 5-6 cm of legroom. I also made the pedal surface smaller so that they do not get in contact with the wall. The throttle was a bit more work as I had to fabricate a new linkage to get it in line with the clutch and brake pedal. I did this when I bought my car (used) in 2015 and everything has been working great. I had some pictures of the whole rebuild process but of course that was on my previous crashed Iphone...But I can post a picture of how the pedals look now?
Re: Moving the pedal box [Re: Dutch] #583242
01/07/19 02:08 PM
01/07/19 02:08 PM
Sweden
Sweden
If only I knew how to post a picture...:-)
Re: Moving the pedal box [Re: Dutch] #583243
01/07/19 02:08 PM
01/07/19 02:08 PM
Sweden
Sweden
/Users/dlowgren/Desktop/rebuilt pedal box.jpeg
Re: Moving the pedal box [Re: Swedewheeler] #583249
01/07/19 03:07 PM
01/07/19 03:07 PM
Port Orchard, WA.
LightSpeed Online content
LightSpeed  Online Content
Port Orchard, WA.
It is a pretty steep learning curve. Saving the photos to your desktop or another folder (NOT IN THE PHOTO PROGRAM) and make sure when you save them they are not a large file size. THEN, transfer them to TM Images photo service. Once in there you can go to the bottom of each photo where the codes are located and find the BBcode and copy it. Then paste it into the Post you are using. About as simple as a blind man trying to ride a motorcycle.
Stephen
2019 M3W piling on the Covid miles
Re: Moving the pedal box [Re: Dutch] #583251
01/07/19 03:28 PM
01/07/19 03:28 PM
rcmatt Offline
rcmatt  Offline
as said by Saint Augustine, it is a "termendum mysterium"
Rodger
Moderated by  Aeroman
