3 registered members (kankeL, atalante83, Bitsobrits), 93 guests, and 14 spiders.
+8Rich 287
John V6 182
CooperMan 102
The "idling engine fine"
by MDS61. 20/08/19 07:57 PM
TG review 110 edition +4
by Carrotious. 20/08/19 06:20 PM
Aero 8 investigating to buy.
by Lancman. 20/08/19 04:24 PM
What the brake pedal modification kit looks like
by WilsonLaidlaw. 20/08/19 10:48 AM
Half Aero to sell ;-)
by Chrisa8. 20/08/19 07:50 AM
North Coast 500
4/4 visiting the lighthouse at Närsholmen
My 65 Plus 4 Four Seater won a trophy
1978 450SL
+6 Test drive at Krazy Horse
Graeme1950, Trev55, Slacker, RogerT, tigertom
6640 Registered Users
Forums33
Topics35,920
Posts579,975
Members6,640
Most Online459
Aug 3rd, 2019
kingsley mkh
New fuel leak #576624
15/05/19 08:30 AM
15/05/19 08:30 AM
Leicestershire, UK
Bunny Offline OP
Bunny  Offline OP
Leicestershire, UK
Yesterday, after filling up with fuel, there was a noticable whiff of petrol while driving along. There followed a forensic inspection of all the usual places leaks may occur: hoses around injectors; hoses behind engine; hoses on fuel tank link pipe; fuel tank brackets; etc. In the end, I noticed signs of fuel weeping from where the filler pipe meets the left hand fuel tank. It appears that the weld has cracked where it meets the tank.
In retrospect, this is not too surprising because we know that the tanks move up and down and we also know that aluminium is fairly brittle and doesn't flex too well.
My plan is to seal the area with fuel compatible PU sealant but I couldn't help wondering if a flexible section of pipe in the region shown might have prevented the problem in the first place.
My car has covered just over 10,000 miles. It's possible that the crack may have been there for some time and I've only just noticed it. I did give the car a particularly generous fuel fill on this occasion!
Andy
Re: New fuel leak [Re: Bunny] #576637
15/05/19 10:46 AM
15/05/19 10:46 AM
Lancaster
Phil Bleazey Offline
Lancaster
Seems to be another case of the convenience of " just weld it all together" being overpowered by the reality of needing less stress on the welds. Yes, your flexible connection near the tank will do the trick - good luck.
Phil
2013 M3W www.bleazey.co.uk - Builder of upgrade kits for the Centa coupling and BB mounts for M3W
Re: New fuel leak [Re: Bunny] #576641
15/05/19 11:12 AM
15/05/19 11:12 AM
Nr Haverhill UK
PaulR Offline
PaulR  Offline
Nr Haverhill UK
Hi
Looks like bad weld penetration at that start and stop point,
maybe grounds for a no charge replacement
PaulR
2016 M3W
Re: New fuel leak [Re: PaulR] #576644
15/05/19 11:30 AM
15/05/19 11:30 AM
West of Seattle, USA
LightSpeed Online content
LightSpeed  Online Content
Originally Posted By PaulR
Hi
+1 for the very poor weld. I too think it should be replaced for free.
Your idea of adding a flexible section seems reasonable, but why not just replace the entire metal tube with a flex tube?
Stephen
M3W 2019
Re: New fuel leak [Re: Bunny] #576653
15/05/19 12:25 PM
15/05/19 12:25 PM
O'Fallon, Missouri USA
Dan_Lockwood Offline
Just a word to the wise, it takes a special rubber tube for petrol/gas. Using radiator type hose will not last long for petrol.
So just make sure you purchase the correct hose and you should be good to go.
Re: New fuel leak [Re: Bunny] #576654
15/05/19 12:29 PM
15/05/19 12:29 PM
MiniCooper has twin tanks and a long path from the cap to the tank. Worth checking out.
Stephen
M3W 2019
Re: New fuel leak [Re: Bunny] #576688
15/05/19 04:53 PM
15/05/19 04:53 PM
Leicestershire, UK
Bunny Offline OP
Bunny  Offline OP
Leicestershire, UK
Thanks for everyone's thoughts on this. If the car was under warranty then the tank may have been replaced f.o.c., however at seven years old (and with the benefit of past experience) I don't even think it's worth asking! What worries me is that, as far as we know, they are still fitting the same design of fuel tanks to new cars, design faults & all.
Oh, and remember to double check the tension of your fuel tank webbing straps folks! If you can move the rear of the tanks up and down by hand the straps are too loose. soapbox
Andy
Re: New fuel leak [Re: Bunny] #576690
15/05/19 05:03 PM
15/05/19 05:03 PM
New River Valley, VA
rcmatt Offline
rcmatt  Offline
It sure looks like a poor weld. But I agree with everyone. A short pipe and then flex hose would have been better.... of course then I remember I have occasionally filled to the tip top of the piping pantsdown
Rodger
2004 Plus 8 (wife's)
Moderated by  Aeroman
