16 registered members (Clipper, Malcolm T, +8Rich, DCH, AZJowett, Doug J, Gordon D, David_E, P964, Ray, lord-richfield, Tresco, Bluebricked, planenut, DJC, Mark H), 145 guests, and 31 spiders.
+8Rich 259
John V6 122
Peter J 118
Hamwich 110
Wiper end caps
by David_E. 25/01/20 10:19 PM
Speedometer Calibration
by planenut. 25/01/20 09:02 PM
Easy-Up Hood stay
by Themorganeer. 25/01/20 07:37 PM
Aerial Fitting "HELP"
by Nostalgiajohn. 25/01/20 07:19 PM
Germany - an aera of MORGAN thieves?
by xc68anc. 25/01/20 02:01 PM
Visit to Silverstone Experience
by minikeefy. 25/01/20 01:25 PM
water in the oil of an air cooled engine???
by Phil Bleazey. 25/01/20 10:54 AM
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
Bevel box oil leak
Hogmanay Run
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,079
Posts601,645
Members6,812
Most Online1,033
Dec 28th, 2019
No Birthdays
Very Heavy clutch pedal #576666
15/05/19 01:39 PM
15/05/19 01:39 PM
guernsey CI
sarnia Offline OP
sarnia  Offline OP
guernsey CI
I have a 1994 Morgan 4/4 with 1800 Ford Zetec with milage of 21000.
It has always had a very hard to press clutch pedal, but lately seems to be even harder. ( It may be my age). The clutch is cable not hydraulic, I have lubricated the pedal box and wonder if it could be the cable being worn. If I don't fully press the clutch pedal sometimes I can crunch the gears. Any advise would be appreciated. Regards Sarnia
Re: Very Heavy clutch pedal [Re: sarnia] #576671
15/05/19 02:18 PM
15/05/19 02:18 PM
Luxembourg
mich Offline
mich  Offline
Luxembourg
Hi Sarnia,
I had exactly the same issue when I bought mine a few years ago. I went for the pedal box, over-greased every possible part of the system to zero effect. In my case it all came down to an originally badly guided clutch cable of more than a a meter which went all the way from the drivers side (left on my car) passing far in front of the sump to the bellhouse clutch fitment on the other side. That long and wobbly cable eventually wore out until the clutch pedal showed the symptoms you describe. I went through some very poor attempts by a local garage to fix it- resulting in a general overhaul of the gearbox, a new clutch set a.s.o. I learned quite something about Morgan mechanics over a few months.
In hindsight a new, shorter, properly guided clutch cable would have been the end of all trouble. My new shorter cable now runs behind the sump. Clutch works perfectly.
Cheers, Mich
4/4 1996 1.8 ZETEC It has Swivel Pivots and an amazing Umbrella Holder!
Re: Very Heavy clutch pedal [Re: sarnia] #576676
15/05/19 03:16 PM
15/05/19 03:16 PM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
Here's what I think may be happening.
The cars of this era that have a cable-operated clutch use a bell-crank type arrangement to transfer the thrust of the clutch push rod to the pull on the cable to operate the clutch. It is mounted low down on the forward face of the engine bulkhead just next to the brake master cylinder.
The bell crank comprises two arms arranged at 90 degrees to each other, the arms are brazed to the ends of a tube. Over time, the brazing weakens and the angle between the two arms reduces from 90 degrees. This has the effect of reducing both the mechanical advantage and the length of throw, causing the clutch to become heavier and more difficult to disengage.
The cure is to remove the crank, realign the arms to 90 degrees, and weld in a bit more stiffening.
The picture below is of my car at Kevin Vernon's, showing the beefed-up version that he did for my car when he put the new chassis on. The finger pointing at it belongs to none other than SpannerJuggler.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: Very Heavy clutch pedal [Re: Hamwich] #576680
15/05/19 03:45 PM
15/05/19 03:45 PM
London
MOG 615 Offline
MOG 615  Offline
London
Thought I recognised those dainty fingers . Looks like a good mod from Kevin there Tim
Andy G
1999 +8 , Indigo Blue.
Re: Very Heavy clutch pedal [Re: sarnia] #576683
15/05/19 04:00 PM
15/05/19 04:00 PM
Seattle, USA
Button Online content
Button  Online Content
Seattle, USA
Rather than engineer a method of clutch release I opted for an internal slave system for My +8 Bitsa and ZETEC powered DHC. The downside of this is I must pull the engine/trans if I have problems with the slave. The upside is an easy design and by changing the size of the clutch MC I can very the effort required. Another downside may be cost???
Button
Re: Very Heavy clutch pedal [Re: Hamwich] #576685
15/05/19 04:40 PM
15/05/19 04:40 PM
SteveT Offline
SteveT  Offline
Those nails look far too clean to me..
110th +4 AM Chiltern Green
1939 Cammy Velo
1959 BSA GS DBD34
LR 90 SW
Fellow of the Wild Mogs
Re: Very Heavy clutch pedal [Re: sarnia] #576686
15/05/19 04:44 PM
15/05/19 04:44 PM
cerealsurfer Offline
Seconded on the swap to Hydraulic - Retroford do a kit for T5 box and also Type9/Rocket box.
They may be able to supply a kit for you:
http://www.retro-ford.co.uk/shop/content/type-9-rocket-hydraulic-clutch-release-bearing-kit-bc002
Re: Very Heavy clutch pedal [Re: mich] #576689
15/05/19 04:56 PM
15/05/19 04:56 PM
guernsey CI
sarnia Offline OP
sarnia  Offline OP
guernsey CI
thankyou Mich i will try and purchase a shorter cable ,if i can find a supplier .thanks again. Sarnia
Re: Very Heavy clutch pedal [Re: MOG 615] #576696
15/05/19 05:32 PM
15/05/19 05:32 PM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
I've just remembered - that's actually my hand, Colin was taking the pictures. I was far too excited to remember to take any photographs myself.
Re: Very Heavy clutch pedal [Re: sarnia] #576724
15/05/19 07:28 PM
15/05/19 07:28 PM
UK (up north)
Dean-Royal Offline
Dean-Royal  Offline
UK (up north)
Clutch Diaphram plate hardened, replace full Clutch Kit
Moderated by  Aeroman, Simon
