8 registered members (John Winn, Eurosystem0, TBM, Morph, +8Rich, thelastgizmo, kankeL, flyfisher), 155 guests, and 9 spiders.
John V6 436
+8Rich 409
TBM 243
Heinz 195
A Morgan meet?
by sospan. 02/06/20 10:58 AM
rands Foot Lockers-Any thoughts?
by Nostalgiajohn. 01/06/20 08:45 PM
Sidescreen restoration
by Phil4/4. 01/06/20 08:25 PM
Exhaust manifold temperatures - misfiring
by thelastgizmo. 01/06/20 06:15 PM
May be worth watching
by CooperMan. 01/06/20 05:27 PM
Morgan 4/4 1992 CVH efi
by Adrian Bott. 01/06/20 03:35 PM
393 km, from one end to the other.
Back of the Dragon near Tazewell VA
Auchindoir Church, Lumsden
Plus four Test Drive
Engine running!
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,389
Posts629,147
Members6,938
Most Online1,033
Dec 28th, 2019
DirkM
Exhaust fumes 1968 +4 DHC #578652
29/05/19 05:00 AM
29/05/19 05:00 AM
Lindsay B Offline OP
Hi,
my friend commented recently, after a drive with the top down, in my 1968 +4 DHC, that exhaust fumes were very evident in the car at low speeds, and he thought we were being gassed.
The exhaust is a standard Plus 4 type with muffler, and the tailpipe exits at the rear of the car, just past the bumper bar level. The exhaust fumes are being sucked or swirled back in at the rear, as there are no leaks forward of the firewall.
Have any members noticed this in their cars, or can suggest any solution, other than driving faster.
Regards,
Lindsay.
Re: Exhaust fumes 1968 +4 DHC [Re: Lindsay B] #578654
29/05/19 05:41 AM
29/05/19 05:41 AM
Austria, Vienna area
The Austrian Offline
Replace windshield with aero screens! That should do the trick. oops
Most Morganians have survived these fumes so far.
Perhaps your carburetor or ignition settings are not perfect, so your engine produces more exhaust fumes due to inefficient fuel combustion?
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Re: Exhaust fumes 1968 +4 DHC [Re: Lindsay B] #578658
29/05/19 06:36 AM
29/05/19 06:36 AM
Powick
tmg513 Offline
tmg513  Offline
Powick
I can't say I've ever heard of that. Do you notice it yourself? Is the exhaust on your side or the passenger side?
1972 4/4 2 Seater
Re: Exhaust fumes 1968 +4 DHC [Re: Lindsay B] #578659
29/05/19 06:38 AM
29/05/19 06:38 AM
YORK
KEVFITZ Offline
KEVFITZ  Offline
YORK
Aeroscreens would do it for sure !!! ….
but on my +4 Supersports I found I was being gassed at low speeds before the cat got hot and the cockpit filled up with hydro carbons
with the roof down.
The 100% effective cure was to fit a side exit tail pipe made up in stainless by local firm for £75..problem solved !!!
Re: Exhaust fumes 1968 +4 DHC [Re: Lindsay B] #578662
29/05/19 06:59 AM
29/05/19 06:59 AM
Cornwall
griffo Offline
griffo  Offline
Cornwall
Rather than changing the windshield you might try a far less drastic solution which worked for me:
Just extend the tailpipe by a few inches. You will have to experiment but try to make it about four inches longer so the exhaust gas exits a little further behind the car in the air flow rather than being drawn back in.
Re: Exhaust fumes 1968 +4 DHC [Re: Lindsay B] #578672
29/05/19 07:30 AM
29/05/19 07:30 AM
Seamill, Ayrshire
Max5 Offline
Max5  Offline
Seamill, Ayrshire
I had this problem on a Booklands Roadster and a cheap local mod. to side exits on the exhaust saved the problem permanently.
Re: Exhaust fumes 1968 +4 DHC [Re: Lindsay B] #578677
29/05/19 07:44 AM
29/05/19 07:44 AM
Purton, nr Swindon UK
rainbowj Offline
rainbowj  Offline
I get fumes in my '92 plus4, especially with the side screens on. I need a new exhaust and was looking at Librands. They have a choice of different terminations. Will this help.
1992 plus4 connaught green
Re: Exhaust fumes 1968 +4 DHC [Re: Lindsay B] #578686
29/05/19 08:41 AM
29/05/19 08:41 AM
Cornwall
griffo Offline
griffo  Offline
Cornwall
John,
I don't believe different styles of tail trim are the issue. It seems to me that if the pipe exits right under the bumper (as my 2014 Plus 4 did) the fumes can, particularly with sidescreens on, be sucked forward by the vortex. Just try a slightly extended tailpipe. For me it completely cured the fumes issue.
Re: Exhaust fumes 1968 +4 DHC [Re: Lindsay B] #578698
29/05/19 10:44 AM
29/05/19 10:44 AM
Thank you all for your suggestions, I think I will try the side exhaust pipe method.
Regards,
Lindsay.
Re: Exhaust fumes 1968 +4 DHC [Re: Lindsay B] #578708
29/05/19 11:39 AM
29/05/19 11:39 AM
Wiltshire
RJW Offline
RJW  Offline
Wiltshire
I also get fumes on start up in my 2013 Plus 4. This problem is helped by
keeping both the side screen windows open by about one inch with the hood down. Once the engine has warmed up, the fumes are less noticeable.
Bob.
Moderated by  Aeroman, Simon
