Morgan Aero 8
21 registered members (SCX358G, MR11MOG, Richard Wood, JMcL, Spanner Juggler, ChrisConvertible, NeilMB, John V6, nick w, John07, James B W, CooperMan, nippymog, Luddite, rockabilly john, TBM, P964, The Austrian, westgardronning, Heinz, TheRabbit), 188 guests, and 20 spiders.
+8Rich 403
John V6 328
Alistair 128
Hawki 120
Roadster Radiator leak
by mal. 10/08/20 10:07 AM
1990 +8 Rear Brakes
by jeremylparker. 09/08/20 11:43 PM
Stub Axles -?repaint
by NelsonG. 09/08/20 11:27 PM
Visitor Centre
by wigmog. 09/08/20 07:18 PM
Ginetta Juniors
by Budster. 09/08/20 01:30 PM
Key transponder issue
by The Austrian. 09/08/20 10:46 AM
Steering balljoint torque
by MOG42. 08/08/20 06:39 PM
riding through the montains
SNOWDONIA B4407/A543
GTN Soft top re-fitted
GTN Visors
A Great Escape to Orford & Snape Maltings
WLPM, Lilliput, Andrew1806, RBooth, Martien
7087 Registered Users
Topics39,022
Posts642,483
Members7,087
Most Online1,033
Dec 28th, 2019
No Birthdays
Ammonia smell.. #579062
31/05/19 07:41 PM
31/05/19 07:41 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
So curiously today I have started to smell Ammonia quite strongly under high load full throttle, i.e. 3rd/4th gear foot down at around 2.5/3k rpm.
I recall reading somewhere that this is often from old/broken catalytic convertors, however it is coming into the cabin from what smells like the engine bay so I am unsure as to what it is. Usually I get a bit of a strong petrol smell (like the engine is running rich), which I have been told is normal. I have had all fuel lines and connections checked by two Morgan dealers as I was paranoid about a fuel leak so I know it can only be the engine running rich..
Any thoughts/suggestions?
Don't want to poison my pregnant wife when driving ideally! hide
Aero 8 S1
M3W - Green Shark
Re: Ammonia smell.. [Re: NickCW] #579078
31/05/19 09:24 PM
31/05/19 09:24 PM
Hampton Hill, Middx.
DavidR Offline
DavidR  Offline
Nick, just a thought do you usually use the same brand of fuel?
A google search throws up either the effect a rich running engine has on the catalyst when the engine is cold or mould in the aircon, but I would expect that to be more constant rather than throttle sensitive.
David
Aero S4
Re: Ammonia smell.. [Re: NickCW] #579090
31/05/19 10:40 PM
31/05/19 10:40 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Interesting question as I usually always run on Shell V-Power 99ron, however currently I am on holiday in the Malverns and the local station is a BP, so have been running it on 97ron ultimate.
Air con was off and is clean so no smells there, how odd..
Aero 8 S1
M3W - Green Shark
Re: Ammonia smell.. [Re: NickCW] #579096
01/06/19 01:23 AM
01/06/19 01:23 AM
auckland new zealand
waikiore Offline
waikiore  Offline
Interesting stuff, as I often have a smell of burning - like a just lit match, very worrying when I first bought this car and thought the woodwork was on fire but after very thorough checking nothing has changed and it still occasionally does it ?
99 plus 8 indigo
Re: Ammonia smell.. [Re: NickCW] #579111
01/06/19 08:44 AM
01/06/19 08:44 AM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
There is a lot of cow poo on the roads in that region. Are you certain the locals have not left a deposit on your cat's which is being burnt off ?
I had that in the area around RAF Coningsby where I got a load of cwap on the exhaust/pipes. The smell was quite strong but made worse on full power moments as the pipes got hotter.
I ended up putting it up on axle stands and jet blasting (very very carefully!) down the pipes.
Just time to burn a little more petrol before dinner.
Re: Ammonia smell.. [Re: Alistair] #579125
01/06/19 12:09 PM
01/06/19 12:09 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Now this is an avenue I did not think about! Quite possible and would explain why it was worse on full throttle.
I shall have to get the hose out when I am back, to be honest it needs it with a week of bug splatter and rain! drive
Aero 8 S1
M3W - Green Shark
Re: Ammonia smell.. [Re: NickCW] #579205
02/06/19 07:25 AM
02/06/19 07:25 AM
Hampshire
Alistair Offline
Alistair  Offline
Hampshire
Stick it up on a kwik-twit ramp and walk under very carefully!
Re: Ammonia smell.. [Re: NickCW] #579404
03/06/19 12:58 PM
03/06/19 12:58 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Soft hat at the ready!
Aero 8 S1
M3W - Green Shark
Re: Ammonia smell.. [Re: NickCW] #579496
03/06/19 08:42 PM
03/06/19 08:42 PM
howard Offline
howard  Offline
A cat has been sleeping on your warm bonnet and has peed on the engine.
Re: Ammonia smell.. [Re: howard] #579508
03/06/19 09:40 PM
03/06/19 09:40 PM
Kent & Dorset, UK
twotribes Offline
twotribes  Offline
Kent & Dorset, UK
Is that what your Lotus dealer used to tell you? - do Elises still smell of trimethylamine/urea - or as a boat owner, did you not notice the smell of fibreglass? boat
Stuart
Moderated by  Aeroman, Simon
