Morgan Aero 8
11 registered members (The Austrian, flyfisher, JoeSpeetjens, Sir Percival, bmgermany, CooperMan, tmg513, M3W55, petebishop, rcmatt, John Robie), 219 guests, and 46 spiders.
+8Rich 261
John V6 138
Peter J 126
Hamwich 96
Off the Road
by PhilRoyle. 21/01/20 05:49 PM
M3W gathering southern Virginia June 12-14
by rcmatt. 21/01/20 05:06 PM
New Tyres
by Spanner Juggler. 21/01/20 04:00 PM
Grease is the word
by Fat Wolfie. 21/01/20 03:58 PM
Glassware Aero 8
by Flipsterbaby. 21/01/20 03:58 PM
Door Roundels
by RobCol. 21/01/20 03:22 PM
Bonnet Stays
by RobCol. 21/01/20 03:19 PM
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
Bevel box oil leak
Hogmanay Run
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,056
Posts601,206
Members6,812
Most Online1,033
Dec 28th, 2019
Graeme Morrison, Kaou
Ammonia smell.. #579062
31/05/19 07:41 PM
31/05/19 07:41 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
So curiously today I have started to smell Ammonia quite strongly under high load full throttle, i.e. 3rd/4th gear foot down at around 2.5/3k rpm.
I recall reading somewhere that this is often from old/broken catalytic convertors, however it is coming into the cabin from what smells like the engine bay so I am unsure as to what it is. Usually I get a bit of a strong petrol smell (like the engine is running rich), which I have been told is normal. I have had all fuel lines and connections checked by two Morgan dealers as I was paranoid about a fuel leak so I know it can only be the engine running rich..
Any thoughts/suggestions?
Don't want to poison my pregnant wife when driving ideally! hide
Aero 8 S1
Re: Ammonia smell.. [Re: NickCW] #579078
31/05/19 09:24 PM
31/05/19 09:24 PM
Hampton Hill, Middx.
DavidR Offline
DavidR  Offline
Nick, just a thought do you usually use the same brand of fuel?
A google search throws up either the effect a rich running engine has on the catalyst when the engine is cold or mould in the aircon, but I would expect that to be more constant rather than throttle sensitive.
David
Aero S4
Re: Ammonia smell.. [Re: NickCW] #579090
31/05/19 10:40 PM
31/05/19 10:40 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Interesting question as I usually always run on Shell V-Power 99ron, however currently I am on holiday in the Malverns and the local station is a BP, so have been running it on 97ron ultimate.
Air con was off and is clean so no smells there, how odd..
Aero 8 S1
Re: Ammonia smell.. [Re: NickCW] #579096
01/06/19 01:23 AM
01/06/19 01:23 AM
auckland new zealand
waikiore Offline
waikiore  Offline
Interesting stuff, as I often have a smell of burning - like a just lit match, very worrying when I first bought this car and thought the woodwork was on fire but after very thorough checking nothing has changed and it still occasionally does it ?
99 plus 8 indigo
Re: Ammonia smell.. [Re: NickCW] #579111
01/06/19 08:44 AM
01/06/19 08:44 AM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
There is a lot of cow poo on the roads in that region. Are you certain the locals have not left a deposit on your cat's which is being burnt off ?
I had that in the area around RAF Coningsby where I got a load of cwap on the exhaust/pipes. The smell was quite strong but made worse on full power moments as the pipes got hotter.
I ended up putting it up on axle stands and jet blasting (very very carefully!) down the pipes.
Just time to burn a little more petrol before dinner.
Re: Ammonia smell.. [Re: Alistair] #579125
01/06/19 12:09 PM
01/06/19 12:09 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Now this is an avenue I did not think about! Quite possible and would explain why it was worse on full throttle.
I shall have to get the hose out when I am back, to be honest it needs it with a week of bug splatter and rain! drive
Aero 8 S1
Re: Ammonia smell.. [Re: NickCW] #579205
02/06/19 07:25 AM
02/06/19 07:25 AM
Hampshire
Alistair Offline
Alistair  Offline
Hampshire
Stick it up on a kwik-twit ramp and walk under very carefully!
Re: Ammonia smell.. [Re: NickCW] #579404
03/06/19 12:58 PM
03/06/19 12:58 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Soft hat at the ready!
Aero 8 S1
Re: Ammonia smell.. [Re: NickCW] #579496
03/06/19 08:42 PM
03/06/19 08:42 PM
howard Offline
howard  Offline
A cat has been sleeping on your warm bonnet and has peed on the engine.
Re: Ammonia smell.. [Re: howard] #579508
03/06/19 09:40 PM
03/06/19 09:40 PM
Kent & Dorset, UK
twotribes Offline
twotribes  Offline
Kent & Dorset, UK
Is that what your Lotus dealer used to tell you? - do Elises still smell of trimethylamine/urea - or as a boat owner, did you not notice the smell of fibreglass? boat
Stuart
Moderated by  Aeroman, Simon
