Morgan Aero 8
4 registered members (Dave Collis, Gambalunga, M3W55, SimonH), 138 guests, and 11 spiders.
+8Rich 514
John V6 455
TBM 180
Hamwich 172
Storage during Coronvirus
by johncc. 28/03/20 02:40 PM
Ford V8 video
by John V6. 28/03/20 12:41 PM
+8 at the petrol station
by Ivo. 27/03/20 11:20 PM
by Alan Patterson. 27/03/20 06:20 PM
Bolshoi live stream
by Heinz. 27/03/20 05:22 PM
Workshop Note - Bump Stop assists
by DaveW. 27/03/20 03:46 PM
Whart have you bodged up today
by John V6. 27/03/20 02:50 PM
Suffolk in the sun
Ver.2 Morgans at Knockhill
Mogs at Knockhill Aug 2006
Social distancing over the weekend
Social distancing to Ladybower
Andrew007, H. Tomasson, GrandadC, Adrian777, stev325
6864 Registered Users
Topics37,639
Posts614,046
Members6,864
Most Online1,033
Dec 28th, 2019
No Birthdays
Ammonia smell.. #579062
31/05/19 07:41 PM
31/05/19 07:41 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
So curiously today I have started to smell Ammonia quite strongly under high load full throttle, i.e. 3rd/4th gear foot down at around 2.5/3k rpm.
I recall reading somewhere that this is often from old/broken catalytic convertors, however it is coming into the cabin from what smells like the engine bay so I am unsure as to what it is. Usually I get a bit of a strong petrol smell (like the engine is running rich), which I have been told is normal. I have had all fuel lines and connections checked by two Morgan dealers as I was paranoid about a fuel leak so I know it can only be the engine running rich..
Any thoughts/suggestions?
Don't want to poison my pregnant wife when driving ideally! hide
Aero 8 S1
Re: Ammonia smell.. [Re: NickCW] #579078
31/05/19 09:24 PM
31/05/19 09:24 PM
Hampton Hill, Middx.
DavidR Offline
DavidR  Offline
Nick, just a thought do you usually use the same brand of fuel?
A google search throws up either the effect a rich running engine has on the catalyst when the engine is cold or mould in the aircon, but I would expect that to be more constant rather than throttle sensitive.
David
Aero S4
Re: Ammonia smell.. [Re: NickCW] #579090
31/05/19 10:40 PM
31/05/19 10:40 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Interesting question as I usually always run on Shell V-Power 99ron, however currently I am on holiday in the Malverns and the local station is a BP, so have been running it on 97ron ultimate.
Air con was off and is clean so no smells there, how odd..
Aero 8 S1
Re: Ammonia smell.. [Re: NickCW] #579096
01/06/19 01:23 AM
01/06/19 01:23 AM
auckland new zealand
waikiore Offline
waikiore  Offline
Interesting stuff, as I often have a smell of burning - like a just lit match, very worrying when I first bought this car and thought the woodwork was on fire but after very thorough checking nothing has changed and it still occasionally does it ?
99 plus 8 indigo
Re: Ammonia smell.. [Re: NickCW] #579111
01/06/19 08:44 AM
01/06/19 08:44 AM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
There is a lot of cow poo on the roads in that region. Are you certain the locals have not left a deposit on your cat's which is being burnt off ?
I had that in the area around RAF Coningsby where I got a load of cwap on the exhaust/pipes. The smell was quite strong but made worse on full power moments as the pipes got hotter.
I ended up putting it up on axle stands and jet blasting (very very carefully!) down the pipes.
Just time to burn a little more petrol before dinner.
Re: Ammonia smell.. [Re: Alistair] #579125
01/06/19 12:09 PM
01/06/19 12:09 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Now this is an avenue I did not think about! Quite possible and would explain why it was worse on full throttle.
I shall have to get the hose out when I am back, to be honest it needs it with a week of bug splatter and rain! drive
Aero 8 S1
Re: Ammonia smell.. [Re: NickCW] #579205
02/06/19 07:25 AM
02/06/19 07:25 AM
Hampshire
Alistair Offline
Alistair  Offline
Hampshire
Stick it up on a kwik-twit ramp and walk under very carefully!
Re: Ammonia smell.. [Re: NickCW] #579404
03/06/19 12:58 PM
03/06/19 12:58 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Soft hat at the ready!
Aero 8 S1
Re: Ammonia smell.. [Re: NickCW] #579496
03/06/19 08:42 PM
03/06/19 08:42 PM
howard Offline
howard  Offline
A cat has been sleeping on your warm bonnet and has peed on the engine.
Re: Ammonia smell.. [Re: howard] #579508
03/06/19 09:40 PM
03/06/19 09:40 PM
Kent & Dorset, UK
twotribes Offline
twotribes  Offline
Kent & Dorset, UK
Is that what your Lotus dealer used to tell you? - do Elises still smell of trimethylamine/urea - or as a boat owner, did you not notice the smell of fibreglass? boat
Stuart
Moderated by  Aeroman, Simon
