12 registered members (Image, Jep, sss6000, jackmorini, boxboxbox, Ricardo, Craig Jezz, Gambalunga, TBM, dogmog, Dean-Royal, Clipper), 190 guests, and 21 spiders.
John V6 374
+8Rich 213
TBM 153
Front suspension lubrication questions
by thelastgizmo. 25/10/20 07:46 PM
Half shaft problem and BTR axle.
by FrancisD. 25/10/20 05:48 PM
Fuel Tank Capacity. Again
by IvorMog. 25/10/20 04:55 PM
the definition of a classic sports car
by howard. 25/10/20 04:14 PM
Plastic steering column shroud
by SAE. 25/10/20 03:18 PM
My new Plus 8
by Gambalunga. 25/10/20 02:36 PM
OBD pinouts, wiring etc
by Cumbriankeith. 25/10/20 10:33 AM
Definition of a classic sports car
Another Lancastrian
For Sale: Luggage rack & front bumper
Malvern Show 2
Malvern Show 1
LOLO 04, sss6000, Dylan614, kbac, Gwyn D
7205 Registered Users
Topics39,673
Posts656,186
Members7,205
Most Online1,033
Dec 28th, 2019
Iancarey
Failed Smiths oil pressure gauge #580400
08/06/19 01:07 PM
08/06/19 01:07 PM
Newton Abbot, South Devon UK
Felix42 Offline OP
Felix42  Offline OP
The oil pressure gauge on my Roadster has stopped working. Seems an odd thing to happen. Anyone else had this experience?
Re: Failed Smiths oil pressure gauge [Re: Felix42] #580402
08/06/19 01:34 PM
08/06/19 01:34 PM
Felix42 Offline OP
Felix42  Offline OP
PS: Berrybrook say it is the gauge and not the sender or wiring etc
Re: Failed Smiths oil pressure gauge [Re: Felix42] #580429
08/06/19 04:16 PM
08/06/19 04:16 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
No but my fuel gauge has a life of it's own.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: Failed Smiths oil pressure gauge [Re: Felix42] #580498
09/06/19 08:07 AM
09/06/19 08:07 AM
South West France
CBY Offline
CBY  Offline
South West France
Hi,
Have a look to :
http://www.talkmorgan.com/ubbthreads.php/topics/189255/Re:_Oil_Pressures_Query#Post189255
Regards
2005 PLUS 4
Re: Failed Smiths oil pressure gauge [Re: Felix42] #580522
09/06/19 10:19 AM
09/06/19 10:19 AM
Felix42 Offline OP
Felix42  Offline OP
Very useful - thanks CBY.
Re: Failed Smiths oil pressure gauge [Re: Felix42] #580524
09/06/19 10:32 AM
09/06/19 10:32 AM
Llanelli
sospan Offline
sospan  Offline
Llanelli
Try Caerbont. They took over when Smiths closed the factory in Ystradgynlais.
www.caiguage.com
Red Plus8
Re: Failed Smiths oil pressure gauge [Re: Felix42] #580535
09/06/19 12:11 PM
09/06/19 12:11 PM
north yorkshire
Lowflyer Offline
Lowflyer  Offline
north yorkshire
I assumme that its one of those small gauges that is part of the 3 gauge set up as my 2011 plus 4.
The range of that gauge is 0 to 7Barg, the gauge requires a field resistance range of 10 ohms at 0 Barg to 180 ohms at 7Barg. If you have a suitable potentiometer you can substitute it in place of the pressure transmitter and vary the gauge reading, just connect one end to the spade you pull of the transmitter and one end to engine block (or suitable earth point). You will need a decent multimeter to read resistance.
Regarding the transmitter, ian at Caerbont told me that i required thier model number PTR - 3000 - BN - 10, the 10 indicating that it was 100PSIG transmitter (7 Barg in thier books!). I'm on my second one of these 7 barg transmitters and both have proved inaccurate by approx 1.0 barg at 4 to 5 barg, giving a reading of approx 6 to 6.5 barg which my engine does not kick out.
In furtherance to the above i ordered a transmitter from williams morgan and was sent a 4000 BN 160 which is a 160Psig transmitter. A conversation with Ian again revealed that Morgan always specify this transmitter, ie, the incorrect range for the gauge! However, it appears that the accracy of the 7Barg transmitter is questionable anyway, i tested against a small new bourden tube type gauge which i would assumme was more accurate than the electric transmitter and gauge set up that's on the car. Im not looking for National Physics Lab standards from this kit but would have thought that 5 to 10% accuracy was possible. My latest transmitter would appear to be reading around 25% high.
Re: Failed Smiths oil pressure gauge [Re: John V6] #580627
10/06/19 06:37 AM
10/06/19 06:37 AM
belgium
tom+4 Offline
tom+4  Offline
belgium
Moderated by  Aeroman, Simon
