7 registered members (Taffmog, planenut, Button, Scrambledsignals, skimog, MarioCP, Dr Dag), 151 guests, and 11 spiders.
+8Rich 262
John V6 148
Driving tonneau cover for bad weather
by Landy. 14/10/19 06:43 PM
Your fave holiday/destination
by Bonesie. 14/10/19 06:10 PM
The Queen's speech
by pandy. 14/10/19 05:29 PM
4/4 Zetec engine swap
by IvorMog. 14/10/19 03:54 PM
Family of 3 riding a sidecar through europe
by Jens. 14/10/19 09:29 AM
Club Run - Auckland to the coast (Kaiaua, NZ) for
by MossyfromNZ. 14/10/19 08:57 AM
Electric all wheel drive three-wheeler
by Soleng. 13/10/19 08:44 PM
Denis
Autumn Sunshine
TURBO TRAD..?
London Morgan today.
Black or Silver?
ThomasR, Rob71, cmhagy, SeaTacTom, Ulfheden
6722 Registered Users
Topics36,412
Posts588,358
Members6,722
Most Online569
Sep 8th, 2019
atalante83, roa
1984 +8 wiring diagram and need electrical advice #581651
16/06/19 09:13 AM
16/06/19 09:13 AM
United Kingdom
G Walker Offline OP
G Walker  Offline OP
United Kingdom
Just replaced the wiring loom on my 1984 +8, the new autosparks one is 99% the same as the old one. Inevitably there are some 'issues':
reversing lights on with ignition
gauge lights all on when battery connected
voltmeter has no reading
The loom is british wiring colour coded, I'm off to check all the live wires are appropriately connected (again!). Friends tell me current can flow both ways (I knew that), but didn't appreciate earth faults can make that happen in different circuits to where the fault is due to voltage differences at the earth.
I think I need a wiring diagram to check the wires go to the correct places
I've already checked GoMog and early 1980's +8s are not in their library, is a concurrent 4/4 diagram close enough to follow?
Any tips on fault tracing would be greatly appreciated.
Not completely bald yet so I still have some hair to tear out
G Walker
1983 +8, 2017 c3 aircross, 2011 jag XK, 1933 singer 9
Re: 1984 +8 wiring diagram and need electrical advice [Re: G Walker] #581657
16/06/19 10:31 AM
16/06/19 10:31 AM
north yorkshire
B3MOG Offline
B3MOG  Offline
north yorkshire
I have one for a 1985 +8 but it looks like it was printed some years previously, at the moment I am in-between moving houses but once I am in the new house and get my gear out of storage I will copy it if you still want it.
David Byrne
Re: 1984 +8 wiring diagram and need electrical advice [Re: G Walker] #581661
16/06/19 11:25 AM
16/06/19 11:25 AM
Sandhurst, Berks
teknome Offline
teknome  Offline
Sandhurst, Berks
I haven't seen a diagram specific to the point in time you require. You may be able to deduce some information from the following
1984 4/4
http://www.gomog.com/allmorgan/Wiring44Diagram1984.jpg
1988/1989
http://www.gomog.com/allmorgan/wiring88&89.jpg
Mike Smith
1995 +8
2007 +4
Re: 1984 +8 wiring diagram and need electrical advice [Re: B3MOG] #581719
16/06/19 06:46 PM
16/06/19 06:46 PM
United Kingdom
G Walker Offline OP
G Walker  Offline OP
United Kingdom
Brilliant, that would be great
Thanks
Graham
G Walker
Re: 1984 +8 wiring diagram and need electrical advice [Re: G Walker] #583106
30/06/19 12:52 PM
30/06/19 12:52 PM
United Kingdom
G Walker Offline OP
G Walker  Offline OP
United Kingdom
I now have some wiring diagrams from the factory, the appropriate one is very original as it is obviously hand drawn!
G Walker
Re: 1984 +8 wiring diagram and need electrical advice [Re: G Walker] #583308
01/07/19 07:10 PM
01/07/19 07:10 PM
East Harling, Norfolk UK
Richard Wood Offline
Not so much different voltages at earth points as much as missing/poor earth's allowing current to find a secondary route through something it shouldn't. Another light circuit for example leaving a false clue.
In order of faults you have:
Check green/blue wire from reversing light(s) goes to gearbox switch and nowhere else. Also check that other leg of light(s) has a good earth.
Check the common feed for gauge illumination red/white? wire connects to panel rheostat and that in turn is feed from common light switch bus via red/black? cable.
Voltmeter should be an easy fix. One leg to earth (black wire), other to switched feed from ignition switch (white wire), same feed as ignition coil.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Re: 1984 +8 wiring diagram and need electrical advice [Re: G Walker] #583349
02/07/19 06:49 AM
02/07/19 06:49 AM
Just to add I used used this wiring diagram as reference when offering above advice.
Apologies blush it should be green/brown wire you are looking for from gearbox switch to reverse light
Moderated by  Aeroman, Simon
