4 registered members (JohnMat, Royal Lichter, kankeL, Taffmog), 149 guests, and 27 spiders.
+8Rich 262
John V6 148
Driving tonneau cover for bad weather
by Landy. 14/10/19 06:43 PM
Your fave holiday/destination
by Bonesie. 14/10/19 06:10 PM
The Queen's speech
by pandy. 14/10/19 05:29 PM
4/4 Zetec engine swap
by IvorMog. 14/10/19 03:54 PM
Family of 3 riding a sidecar through europe
by Jens. 14/10/19 09:29 AM
Club Run - Auckland to the coast (Kaiaua, NZ) for
by MossyfromNZ. 14/10/19 08:57 AM
Electric all wheel drive three-wheeler
by Soleng. 13/10/19 08:44 PM
Denis
Autumn Sunshine
TURBO TRAD..?
London Morgan today.
Black or Silver?
ThomasR, Rob71, cmhagy, SeaTacTom, Ulfheden
6722 Registered Users
Topics36,412
Posts588,359
Members6,722
Most Online569
Sep 8th, 2019
atalante83, roa
Slowly increasing idling in 3L V6 #581734
16/06/19 08:46 PM
16/06/19 08:46 PM
Aerdenhout, The Netherlands
BertR Offline OP
BertR  Offline OP
Today I noticed that upon taking away my foot from the accelerator ( and pressing the clutch) the revs came down (as normal) but then gradually increased during a few seconds to about 2000 rpm This happened a few times. One time I saw that the rpm slowly came down again. Also, the normal idle was not exactly stable on one occasion. Engine was warm and running fine otherwise. This is on my 3.0 L 3V6 Roadster from 2009. I did not notice this behavior before. I was in traffic and could not experiment any further, also it occurred only a few times.
Any ideas why this happens?
Thx,
Bert
2009 Roadster, Lancia midnight blue, cinnamon upholstery.
Re: Slowly increasing idling in 3L V6 [Re: BertR] #581756
17/06/19 01:33 AM
17/06/19 01:33 AM
ChrisConvertible Offline
I had the exact same symptoms on my Nissan 180sx and I fixed it by replacing the plug on the wiring harness that connects to the throttle body position sensor.
I hope that helps.
Re: Slowly increasing idling in 3L V6 [Re: BertR] #581757
17/06/19 03:10 AM
17/06/19 03:10 AM
Calif, USA
Phil T Offline
Phil T  Offline
Calif, USA
Check the integrity of all the vacuum lines and fittings. A cracked hose can result in unpredictable idling.
regards,
Phil
Re: Slowly increasing idling in 3L V6 [Re: BertR] #581806
17/06/19 12:38 PM
17/06/19 12:38 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
I would start by gently cleaning the Mass Airflow Sensor in some solvent
Re: Slowly increasing idling in 3L V6 [Re: BertR] #581923
18/06/19 08:10 AM
18/06/19 08:10 AM
howard Offline
howard  Offline
The electronic throttle is the place to start. If cars arent used fairly intensively you get problems with the throttle position sensor.
Might sound daft but I'd be inclined to sit in the car in the garage engine off, and depress and release the throttle a hundred times just to make sure it was working as well as it can. On the Lotus there was a procedure for re-calibrating it which I think was no more than ignition on but engine not started and pressing the throttle fully open and fully realeased a couple of times. Ignition off then start the engine.
If the problem persists then garage and diagnosticks.
Re: Slowly increasing idling in 3L V6 [Re: BertR] #581929
18/06/19 09:26 AM
18/06/19 09:26 AM
East Harling, Norfolk UK
Richard Wood Offline
Throttle shaft partially seizing is another one. Usually triggers management light as well though.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Re: Slowly increasing idling in 3L V6 [Re: BertR] #581982
18/06/19 04:58 PM
18/06/19 04:58 PM
Aberdeen
Andy Offline
Andy  Offline
Aberdeen
I have the same problem on my 2011 Roadster. The throttle is still cable controlled on these models. Can anybody explain where to find the MAF sensor?
Re: Slowly increasing idling in 3L V6 [Re: Phil T] #582022
18/06/19 08:27 PM
18/06/19 08:27 PM
BertR Offline OP
BertR  Offline OP
regards,
Phil
Well, I thought that this would be an easy lead, so I checked the lines and found one with a kink in it and corrected it by loosening a near tie wrap. Today I took the Morgan to work for a test drive and I could not reproduce the error. So perhaps... this did the trick.
Thanks for all the follow up!
Bert
Moderated by  Aeroman, Simon
