Topics36,768
Posts594,766
Members6,777
Most Online723 Dec 5th, 2019
Moving the pedal box
#576597
15/05/19 01:24 AM
15/05/19 01:24 AM
Posts: 12 Logan, Ohio USA
Dutch
Logan, Ohio USA
Is there anyway to move the pedal box assembly in a 2012 left hand drive forward ? My legs are a little long and I can't seem to find a way to straighten them out and keeping my foot off the clutch.
Dutch Junge 194 Mound St Logan, OH USA 43138
Re: Moving the pedal box
[Re: Dutch]
#576598
15/05/19 01:46 AM
15/05/19 01:46 AM
Posts: 1,206 Southern Vermont
Michael H
Southern Vermont
No. If it is the 2012 configuration then it won't go.
It is asymmetric and works quite well on right handed drive so it will float quite easily in Britain.
Sad. One easy solution is to get a spacer for the steering wheel that extends the length of it about an inch or more. That helps tremendously.
[Re: Dutch]
#576605
15/05/19 05:48 AM
15/05/19 05:48 AM
Posts: 3,710 Austria, Vienna area
The Austrian
I improved leg space by elevating the front end of the lower seat cushion. For testing purpose you may put a piece of wood under the front end and check if that fits your needs.
[Re: Dutch]
#582275
20/06/19 05:38 PM
20/06/19 05:38 PM
Posts: 2 Belgium
Erwin G
Belgium
My pedels are moved more backwards because of my long legs but they had to install New attachments for the hydrolic pipes.
[Re: Dutch]
#582284
20/06/19 06:35 PM
20/06/19 06:35 PM
Posts: 760 New River Valley, VA
rcmatt
raising the seat (or adding a cushion) has the effect of moving you further back. I added a cushion because I am vertically challenged and as a result had to move my pedals as well or I could not reach them
[Re: Swedewheeler]
#583249
01/07/19 03:07 PM
01/07/19 03:07 PM
Posts: 1,380 West of Seattle, USA
LightSpeed
If only I knew how to post a picture...:-) It is a pretty steep learning curve. Saving the photos to your desktop or another folder (NOT IN THE PHOTO PROGRAM) and make sure when you save them they are not a large file size. THEN, transfer them to TM Images photo service. Once in there you can go to the bottom of each photo where the codes are located and find the BBcode and copy it. Then paste it into the Post you are using. About as simple as a blind man trying to ride a motorcycle.
Stephen 2019 M3W
[Re: Dutch]
#583251
01/07/19 03:28 PM
01/07/19 03:28 PM
rcmatt
as said by Saint Augustine, it is a "termendum mysterium"
