11 registered members (Gordon D, Graham, G4FUJ, jackmorini, HJP, Ian Wegg, Heinz, P964, griffo, drew, John07, kankeL), 153 guests, and 17 spiders.
+8Rich 295
John V6 144
DaveW 100
Buying a used M3W
by MOR404. 20/10/19 07:33 AM
Perfect
by Gambalunga. 19/10/19 10:13 PM
Higher insurance cost if LHD in UK?
by Marmota. 19/10/19 05:41 PM
That fast you can ride a 1929 BMW...
by Jens. 19/10/19 03:44 PM
Battery Drain Rate
by Peter J. 19/10/19 02:34 PM
A ride on the GWSR today
by Graham, G4FUJ. 19/10/19 02:14 PM
" vide poches "
by atalante83. 18/10/19 06:41 PM
Sport Blue
Le Mans Classic 2017 pics
Denis
Autumn Sunshine
TURBO TRAD..?
ThomasR, Rob71, cmhagy, SeaTacTom, Ulfheden
6722 Registered Users
Topics36,448
Posts589,049
Members6,722
Most Online569
Sep 8th, 2019
Fergie, JMC06
4/4 Kent xflow bonnet clearance? #584848
11/07/19 10:52 AM
11/07/19 10:52 AM
Brittany, France.
Pigiron Offline OP
Pigiron  Offline OP
Brittany, France.
Hello all,
My car, 1979 4/4 Ford crossflow is currently in a thousand pieces hence why I am unable to take the measurement I require;
Could some kind sole 'please' measure the clearance from the top of the carb plenum casting to the underside of the bonnet.
Thanks in advance.
Re: 4/4 Kent xflow bonnet clearance? [Re: Pigiron] #584867
11/07/19 12:33 PM
11/07/19 12:33 PM
Arwyn Williams Offline
Is your car a 2 seater or a 4 seater?
Can offer a measurement from a 1971 4/4 2 seater but this will be from the top carb flange as I run a K&N filter
Arwyn
Re: 4/4 Kent xflow bonnet clearance? [Re: Arwyn Williams] #584955
11/07/19 10:32 PM
11/07/19 10:32 PM
Brittany, France.
Pigiron Offline OP
Pigiron  Offline OP
Brittany, France.
Thanks for the reply.
The car is a 4 seater but I doubt there is any difference.
Re: 4/4 Kent xflow bonnet clearance? [Re: Pigiron] #584968
12/07/19 05:49 AM
12/07/19 05:49 AM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
I'm not so sure, the scuttle on a 4 seater is quite a bit higher and I would think the bonnet line is as well?
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: 4/4 Kent xflow bonnet clearance? [Re: Pigiron] #584974
12/07/19 06:47 AM
12/07/19 06:47 AM
Petersfield, Hampshire, UK
Ian Wegg Online content
Ian Wegg  Online Content
A 4-seater has enough room for a battery under the bonnet, which a 2-seater doesn't, so definitely more clearance.
I'm not sure how you measure it though?
1980 Royal Ivory 4/4 4-seater. B4771
Re: 4/4 Kent xflow bonnet clearance? [Re: Pigiron] #585006
12/07/19 09:50 AM
12/07/19 09:50 AM
By resting my rule on the part of the carb marked on the first picture and observing from the other side, the tape stretched to just over 5 1/8". Plus the 2 7/8" of the case that makes the clearance a whisker over 8".
Re: 4/4 Kent xflow bonnet clearance? [Re: Pigiron] #585092
12/07/19 07:58 PM
12/07/19 07:58 PM
Nice Conversion & Tuning manifold you have there Ian!!
Arwyn
Re: 4/4 Kent xflow bonnet clearance? [Re: Pigiron] #585118
13/07/19 06:12 AM
13/07/19 06:12 AM
Thanks, Arwyn but it's nothing I've done, as far as I'm aware it's exactly as it left the factory.
The 4/4 "Competition" model was fitted with twin Webers and I think by 1979 the standard version was no longer offered, so I'm assuming the OP's car is the same.
Re: 4/4 Kent xflow bonnet clearance? [Re: Pigiron] #585160
13/07/19 01:05 PM
13/07/19 01:05 PM
Brittany, France.
Pigiron Offline OP
Pigiron  Offline OP
Brittany, France.
Gentlemen, thank you for your replies and taking the time to help, very informative. The internal photo with the bonnet down is particularly helpful.
By sheer coincidence I have a Conversion and Tuning twin dcoe manifold in the cupboard although it is the longer one.
Regards.
John.
Re: 4/4 Kent xflow bonnet clearance? [Re: Pigiron] #585345
14/07/19 08:10 PM
14/07/19 08:10 PM
Vienna Austria
auster Offline
auster  Offline
Vienna Austria
Ian I though most of the competition models had the twin choke downdraught Weber, not twin side draught Webers. Obviously yours is the better option! It also seems that the short manifold and inlet trumpets allow the carbs to fit inside the cowling without the need for a cutout. Do you know the origins of this set-up i.e. the manifold and trumpets? I would be very interested in sourcing one for my 68 4/4. Kerry
1968 4/4 1600
1950 Auster J5B
Kitfox S5 Outback
Jodel D9
1988 Peugeot 205 GTI 1.9
Moderated by  Aeroman, Simon
