2 registered members (brian battersby, TBM), 227 guests, and 63 spiders.
+8Rich 258
John V6 122
Peter J 118
Hamwich 110
Wiper end caps
by David_E. 25/01/20 10:19 PM
Speedometer Calibration
by planenut. 25/01/20 09:02 PM
Easy-Up Hood stay
by Themorganeer. 25/01/20 07:37 PM
Aerial Fitting "HELP"
by Nostalgiajohn. 25/01/20 07:19 PM
Germany - an aera of MORGAN thieves?
by xc68anc. 25/01/20 02:01 PM
Visit to Silverstone Experience
by minikeefy. 25/01/20 01:25 PM
water in the oil of an air cooled engine???
by Phil Bleazey. 25/01/20 10:54 AM
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
Bevel box oil leak
Hogmanay Run
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,079
Posts601,650
Members6,812
Most Online1,033
Dec 28th, 2019
No Birthdays
Looking for Morgan early 60's Triumph or 1500 ford #567852
21/03/19 04:08 PM
21/03/19 04:08 PM
robert l Offline OP
robert l  Offline OP
Just wondering about owner opinions on the two engines. I am very familiar with the tr2 and three engines. Have no knowledge of the ford. I'm sure they are less powerful but how is mainenance and durability?
Re: Looking for Morgan early 60's Triumph or 1500 ford [Re: robert l] #568013
22/03/19 09:23 AM
22/03/19 09:23 AM
London
MOG 615 Offline
MOG 615  Offline
London
Robert
Don't just concentrate on the engines , the 1960s +4 and 4/4 are very different cars.
The TR engined +4 is more powerful , and the engine develops greater torque at lower revs , so it pulls well in most gears. The +4 is equipped with the Moss Gearbox , which has 4 speeds and no synchro on 1st. It is a delight to use when properly set up, but can be a real handful when worn (and most are these days), it will never have the rapid change of the Ford boxes in the 4/4. The rear axle ratio is normally 3.73:1 so cruising revs are lower than in the 4/4. It is also considerably heavier than the 4/4 so much less "chuckable" in the handling department. Today most parts are available for the engine (at some very high prices) the box (at eye-wateringly expensive prices) and even the axle.
The Ford engined 4/4 would be a 1340 or 1500cc non-cross-flow unit in the 60s . It will rev easily (more so than the +4) and enjoy a higher limit. The gearbox will be a delight to use (especially with the 2000E box) and encourage rapid changes. The rear axle would normally be 4.1:1 , (or possibly lower) so cruising will be at higher revs and can be wearing on long journeys. Being Ford derived the drive train parts are normally much less expensive and more freely available.
So in summary if you want a car with easy cruising and less nimble handling go for the +4 but be prepared that repair bills could be higher.
The 4/4 is much more nimble , lighter, enjoys easier handling, and likely to be less expensive to maintain but less good as a tourer.
As ever with Morgans always buy on condition alone , much better a really well sorted car with lots of miles and a good record of services and parts replaced than a garage queen that will take a walletfull of cash to sort back to roadworthy condition even though it might look the part.
Andy G
1999 +8 , Indigo Blue.
Re: Looking for Morgan early 60's Triumph or 1500 ford [Re: MOG 615] #568019
22/03/19 09:36 AM
22/03/19 09:36 AM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
Pre-2000E box will have that odd push/pull lever though Andy (can't remember when it finished though).
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Re: Looking for Morgan early 60's Triumph or 1500 ford [Re: robert l] #585055
12/07/19 03:47 PM
12/07/19 03:47 PM
Switzerland
Bodger Offline
Bodger  Offline
Switzerland
Remote gearchange was available for a surcharge of (if memory serves me) 25£ in 1967 when I bought my 4/4. My agent advised to keep the push/pull to keep thieves and lady drivers away - those were the times...
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
Re: Looking for Morgan early 60's Triumph or 1500 ford [Re: robert l] #587629
29/07/19 06:21 AM
29/07/19 06:21 AM
UK
BuyBritish Offline
BuyBritish  Offline
UK
We have a 1956 TR powered plus 4 see photos here she was built from a pile of parts as you can see
[Linked Image]IMG_6440 by Robert & Ali Davies, on Flickr
click link below for more
https://flic.kr/s/aHsktCvhUq
Rob Davies
Morgan 3 Wheeler 1934 MX
Morgan Series 1 1947
Morgan +4 1956 TR4
Morgan +4 2000 T16 Rov
Re: Looking for Morgan early 60's Triumph or 1500 ford [Re: robert l] #587632
29/07/19 06:51 AM
29/07/19 06:51 AM
auckland new zealand
waikiore Offline
waikiore  Offline
I believe Andy G has summed it up very well, with his last sentence being key.
99 plus 8 indigo
Re: Looking for Morgan early 60's Triumph or 1500 ford [Re: robert l] #590169
16/08/19 10:59 AM
16/08/19 10:59 AM
Beaumont de Lomagne, France
Philippo Offline
Philippo  Offline
Hello Robert, if you don't mind my asking do you have a strong reason for not wanting to look at a Kent engined car? I mention it because I think you'll find they have a similar level of performance to a 60s Plus 4, but remain more checkable and of course spares are plentiful. Also providing you go for an early model no electronics.
The higher revs at cruise can be got around by fitting longer ratio rear crown and pinion that are available, though not cheap!
Cheers
Philip
Philip
4/4 4 seater 1974 (to be replaced soon by in-build 1985 +8 4 seater)
Malone F1000
Moderated by  Aeroman, Simon
