14 registered members (DCH, Gambalunga, Max, Bluebricked, Image, +8Rich, M3W55, miran, SeptemberWarrior, kankeL, Grumpy2, Dean-Royal, DaveW, Heinz), 180 guests, and 38 spiders.
+8Rich 305
John V6 199
lowebird 140
Hamwich 132
Mudguard Question
by ajsms999. 13/12/19 09:32 PM
Mx5 Gearbox Oil Level
by DaveW. 13/12/19 08:40 PM
3.0 Roadster oil sump
by mal. 13/12/19 08:18 PM
US Aero 8 S2 bring a trailer
by Alistair. 13/12/19 07:45 PM
How Many no longer Drink Alcohol?
by Peter J. 13/12/19 05:37 PM
High-output LED Brake light bulbs
by Hamwich. 13/12/19 02:29 PM
New Morgan Reviews on YouTube
by Fingles. 13/12/19 02:21 PM
Plus 4, narrow body, 1 off
HERO rally pics
Great Weather in Felixstowe
New M3W
Krazy Horse today
NeilPom, sprinter, Rod c, mgmog, lumpy
6780 Registered Users
Topics36,804
Posts595,695
Members6,780
Most Online723
Dec 5th, 2019
Digimap
Steering Arms Movement #586262
20/07/19 07:05 AM
20/07/19 07:05 AM
WarBird Offline OP
WW11 MOG
WarBird  Offline OP
WW11 MOG
I’m at Loton Park Hillclimb and ready to race today. When the scruitineer checked my car he pulled on each of the steering arms to check for any movement. There was a slight movement in the nearside steering arm. The offside arm was fine.
We pulled off the steering gaiter to have a look at the knuckle joint. All looked ok and upon further pulling of the steering arm the scruitineer thought that the movement may be within the steering rack. The scruitineer is ok with me racing this weekend, but it needs sorting for the next event.
The knuckle joint could be sorted with a shim washer, but the rack could be a more serious task
Has anyone on here had a similar issue?
Re: Steering Arms Movement [Re: WarBird] #586271
20/07/19 07:45 AM
20/07/19 07:45 AM
Hertfordshire
O
Obie Offline
Obie  Offline
O
Hertfordshire
Yes I've got exactly the same issue, its going to be looked at when the car has its first service, would ideally like a new rack!
I recently asked the same question and others have got the same problem.
http://www.talkmorgan.com/ubbthreads.php/topics/583001/steering-rack-knocking-noise#Post583001
Re: Steering Arms Movement [Re: WarBird] #586275
20/07/19 08:17 AM
20/07/19 08:17 AM
WarBird Offline OP
WW11 MOG
WarBird  Offline OP
WW11 MOG
Thanks Obie 👍
I’ll have a chat with the scruitineer
Re: Steering Arms Movement [Re: WarBird] #586278
20/07/19 08:32 AM
20/07/19 08:32 AM
Near Windsor Berkshire
Rog G Offline
Rog G  Offline
I would have thought that if there was play in the rack you would see it on both sides.
There is adjustment in the rack. Underneath the splined pinion which the steering column is attached to there is an adjustment screw unfortunately it is locked in place with both a large locknut and a tab washer. I can't see there is enough room to adjust this without taking the rack out.
2013 M3W
1971 4/4 2 Seater
1934 Sports
Re: Steering Arms Movement [Re: WarBird] #586303
20/07/19 10:26 AM
20/07/19 10:26 AM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
The play that I and others have in the rack seems to be only in the LH side (on RH drive cars) and is apparent when you pull vertically on the steering arm. I think the play is in the internal rack support bush. Adjusting the pinion engagement won't make a lot of difference to this, I would say but I have no experience of rack and pinion adjustments and could be wrong?
There doesn't seem to be any free play or backlash. It has been the same for the last 3 years and maybe before that as well, it gets no worse or better. I plan to try and find a steering rack specialist over the winter and see if there is anything that can be done as I don't have the warranty route option and I am guessing a new or exchange rack is not cheap.
Re: Steering Arms Movement [Re: planenut] #586311
20/07/19 11:12 AM
20/07/19 11:12 AM
Rog G Offline
Rog G  Offline
That sounds much more plausible, and if is the case then adjusting the rack won't make any difference. I have recently had my rack partially apart and there is only one support bush which is on the LH end of the rack housing on RH drive cars, the RH end is supported by the pinion and the rack adjuster screw.
2013 M3W
1971 4/4 2 Seater
1934 Sports
Re: Steering Arms Movement [Re: WarBird] #586446
21/07/19 06:54 AM
21/07/19 06:54 AM
Nr Watership Down UK
JMD Offline
JMD  Offline
Have just tried our rack/steering arms - LH side has small amount of vertical play at the rack end - no fore/aft play though - RH side is solid - there is no play in the steering when driving.
Conclusion per above is that bush @ left end of rack (on RH drive cars) is wearing with suspension movement - RH side must be better supported.
Will the bush be replaceable?
Re: Steering Arms Movement [Re: WarBird] #586462
21/07/19 08:22 AM
21/07/19 08:22 AM
M3W55 Online content
M3W55  Online Content
I have just replaced the LH bush, which was worn, but it has made no difference to the play. Despite c. a fifth of a turn of latitude, the tyres are wearing evenly.
Re: Steering Arms Movement [Re: WarBird] #586467
21/07/19 08:33 AM
21/07/19 08:33 AM
planenut Offline
planenut  Offline
Where did you get the LH internal support bush from and do you have any part numbers please M3W55? Easy enough job to do or not? I think the steering rack it a Quaife item and they are not very keen to supply any information about their Morgan products, at least not when you ask about the Bevel Gearbox.
Re: Steering Arms Movement [Re: WarBird] #586469
21/07/19 08:41 AM
21/07/19 08:41 AM
My local garage, who are classic car specialists, did it - I will ask them for the reference. They are not known for under-charging, but from the bill it looked like no more than 90 minutes' work.
Any guess as to why (albeit a small sample of) RHD owners seem to be reporting play on the left side only?
Moderated by  Aeroman
