11 registered members (PaulG, Gareth H, PaulV, Giles, Chris99, WilsonLaidlaw, Bunny, gazum, Grumpy2, brownbaker, teifistar), 107 guests, and 24 spiders.
+8Rich 282
John V6 179
CooperMan 102
LED bulbs
by Obie. 21/08/19 05:55 AM
The "idling engine fine"
by MDS61. 20/08/19 07:57 PM
TG review 110 edition +4
by Carrotious. 20/08/19 06:20 PM
Aero 8 investigating to buy.
by Lancman. 20/08/19 04:24 PM
What the brake pedal modification kit looks like
by WilsonLaidlaw. 20/08/19 10:48 AM
My Morgan related badges
North Coast 500
4/4 visiting the lighthouse at Närsholmen
My 65 Plus 4 Four Seater won a trophy
1978 450SL
Graeme1950, Trev55, Slacker, RogerT, tigertom
6640 Registered Users
Forums33
Topics35,922
Posts580,018
Members6,640
Most Online459
Aug 3rd, 2019
kingsley mkh
Swapping clock for oil gauge on my +4 #586295
20/07/19 09:47 AM
20/07/19 09:47 AM
SteveT Offline OP
SteveT  Offline OP
Had this on my mind to do for a while, so as its a wet morning I cracked on with it. Apologies for the photos not being in the correct order but i'm sure the sequence is obvious.
The clock quality is pretty grim, easy to remove by lowering the left hand under dash panel and carefully threading your hand up behind through the wiring unscrew the large plastic 'nut'. I used the power feed for the clock and the earth by removing the T block connector and ran the wire from the sender unit up through the existing grommet above the washer bottle.
Fitting the adaptor requires a bit of fiddling so that the hole for the sender is in the right place otherwise it fouls the block. PTFE tape a must and remember these are taper threads.
I also swapped the bezel for a V profile which was a closer match to the existing gauges. All sourced from Holdens.
And that's it..about an hour and a half which included stopping to look for a dropped washer!
+4 110th in AM Chiltern Green
1939 Velocette KSS
A Fellow of the Wild Mogs
Re: Swapping clock for oil gauge on my +4 [Re: SteveT] #586302
20/07/19 10:25 AM
20/07/19 10:25 AM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
thumbs
Nice work Steve.
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Re: Swapping clock for oil gauge on my +4 [Re: SteveT] #586308
20/07/19 11:09 AM
20/07/19 11:09 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
I think while I was there I would have moved over the speedo towards the driver.
Nice job though it looks lie a factory fitment.
2006 Indigo Blue Roadster S1
Re: Swapping clock for oil gauge on my +4 [Re: SteveT] #586314
20/07/19 11:31 AM
20/07/19 11:31 AM
north yorkshire
Lowflyer Offline
Lowflyer  Offline
north yorkshire
I take it that they've supplied you with correct pressure transmitter for the gauge, 2185 3000 8N10, which is a 0 to 100 psi transmitter. I was supplied with 2615 4000 8N16 which was 0 to 160 psi transmitter (or in Caerbont's terms 0 to 10 bar). Not sure about the accuracy of any of the stuff supplied by Caerbont.
Re: Swapping clock for oil gauge on my +4 [Re: Lowflyer] #586318
20/07/19 11:41 AM
20/07/19 11:41 AM
SteveT Offline OP
SteveT  Offline OP
Yes its 0-100 psi. I'm not sure how accurate either but figured its better than just the warning light.
John, not sure how much faff it is to switch speedo with rev counter, always reluctant to disturb too much of the electrickery stuff.
1939 Velocette KSS
Re: Swapping clock for oil gauge on my +4 [Re: SteveT] #586319
20/07/19 11:42 AM
20/07/19 11:42 AM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Steve, is that a heatsink on your oil filter canister ?
Re: Swapping clock for oil gauge on my +4 [Re: CooperMan] #586320
20/07/19 11:44 AM
20/07/19 11:44 AM
SteveT Offline OP
SteveT  Offline OP
Hi Jon, I wondered how long it would be before someone asked! Yes, no idea if it helps or not but it was a left over from my Harley Davidson days. Same size canister as the KN filter i use so thought why not..it was only gathering dust on my garage shelf.
1939 Velocette KSS
Moderated by  Aeroman, Simon
