6 registered members (skimog, Heinz, Rog, Player99, brian battersby, Taffmog), 123 guests, and 15 spiders.
+8Rich 305
John V6 199
lowebird 140
Hamwich 132
Mudguard Question
by ajsms999. 13/12/19 09:32 PM
Mx5 Gearbox Oil Level
by DaveW. 13/12/19 08:40 PM
3.0 Roadster oil sump
by mal. 13/12/19 08:18 PM
US Aero 8 S2 bring a trailer
by Alistair. 13/12/19 07:45 PM
How Many no longer Drink Alcohol?
by Peter J. 13/12/19 05:37 PM
High-output LED Brake light bulbs
by Hamwich. 13/12/19 02:29 PM
New Morgan Reviews on YouTube
by Fingles. 13/12/19 02:21 PM
Plus 4, narrow body, 1 off
HERO rally pics
Great Weather in Felixstowe
New M3W
Krazy Horse today
NeilPom, sprinter, Rod c, mgmog, lumpy
6780 Registered Users
Topics36,804
Posts595,703
Members6,780
Most Online723
Dec 5th, 2019
No Birthdays
Size 13 Feet #586326
20/07/19 12:26 PM
20/07/19 12:26 PM
Angus, UK
Bervie1 Offline OP
Bervie1  Offline OP
Angus, UK
Today an old friend of mine came down for a run in my 2009 +4 as he is contemplating joining the Morgan fraternity.
As he is over six feet he had concerns that the top of the windscreen would hamper is line of sight, that turned out to be no problem but his size 13 feet were rather short of room when changing from accelerator to brake.
In my car there is a cover over the steering column and this seemed to be the cause of the problem, I don’t remember that cover in my 4/4 but I could be wrong.
How do other large footed people manage? And/or is it possible to cut a bit off the bottom of the column cover?
Any advice appreciated.
Re: Size 13 Feet [Re: Bervie1] #586329
20/07/19 12:51 PM
20/07/19 12:51 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
I have size 11 & have had no issues. I guess cutting cover would work. Older cars did not have this refinement , it is purely cosmetic
2006 Indigo Blue Roadster S1
Being paid to breathe
Re: Size 13 Feet [Re: Bervie1] #586385
20/07/19 06:16 PM
20/07/19 06:16 PM
Seamill, Ayrshire
Max5 Offline
Max5  Offline
Seamill, Ayrshire
I remember this being a problem on some of my early Roadsters but it is not noticeable on the 4/4. Morgan may have changed the steering column cover in later cars. More annoying is the position of the drive-by-wire accelerator relative to the brake pedal as it is several inches closer to the bulkhead making heel-and-toe impossible.
Re: Size 13 Feet [Re: Bervie1] #586396
20/07/19 07:19 PM
20/07/19 07:19 PM
Angus, UK
Bervie1 Offline OP
Bervie1  Offline OP
Angus, UK
I guess the best thing for him to do will be to talk to a dealer if he sees a car he is interested in and try it out for size
Re: Size 13 Feet [Re: Bervie1] #586402
20/07/19 07:34 PM
20/07/19 07:34 PM
New Zealand
Randall Offline
Randall  Offline
New Zealand
Having size 14 feet ,when I initially looked at Morgan's I found that +4's were very tight for foot space. Then I tried a Roadster for size and found quite a difference in both legroom and foot space. :Having said that I have narrower feet as well and use narrow shoes. Size 13 feet if wide could still be an issue though.
Morgan Roadster 3.7 2012 Spruce Mica Green Saddle Brown Interior
Re: Size 13 Feet [Re: Bervie1] #586405
20/07/19 08:04 PM
20/07/19 08:04 PM
NE Scotland
ewn Offline
ewn  Offline
NE Scotland
I gave my son a go of my 4/4 recently, he has size 14 and he didn’t comment so I presume it’s fine. I have tiny size 11s and other than the annoying difference between the brake and throttle, as mentioned by Max5, it’s all fine.
You’d be welcome to come by and try my 4/4 anytime, if it’s one of those he’s interested in.
Re: Size 13 Feet [Re: Max5] #586412
20/07/19 08:33 PM
20/07/19 08:33 PM
nick w Offline
nick w  Offline
That's very easy to sort. If you look the pedal is fixed by two bolts. If you take out the lower bolt the pedal hinges upwards out of the way.
Then refit the bolt while the pedal is up. The bolt then sticks out and when you hinge the pedal back down it is slightly higher and positioned perfectly for heel and toe. It's also possible to turn the roller to the other side if you take the pedal off and turn it over before fixing it back with just the top bolt. It's clearer when you look at it.....for which you have to be on your back head in the footwell. Well worth doing though, makes an enormous difference.
Nick
Re: Size 13 Feet [Re: ewn] #586525
21/07/19 04:47 PM
21/07/19 04:47 PM
Angus, UK
Bervie1 Offline OP
Bervie1  Offline OP
Angus, UK
Cheer Ewn, if he decides he’d like to go down that route I’ll send you a PM
Moderated by  Aeroman, Simon
