Morgan Aero 8
21 registered members (BLUE+4, JoeSpeetjens, MJF, Image, BertR, Hawki, +8Rich, DaveK, TBM, SFG, ewn, Gordon D, jbk, Mark H, Heinz, RobCol, Rudolf, Bitsobrits, madmax, Grumpy2, Eurosystem0), 149 guests, and 57 spiders.
+8Rich 424
John V6 421
TBM 235
Heinz 195
1981 +8 water pipes
by GARYMYNARD. 05/06/20 04:54 PM
Plus 4 Push Button Start?
by Nostalgiajohn. 05/06/20 02:45 PM
vdo speedo
by milliemollie. 05/06/20 12:50 PM
Interesting new hardtop
by +8Rich. 05/06/20 12:43 PM
the classic / collectors car market
by howard. 05/06/20 09:53 AM
ebay made me chuckle
by Grumpy2. 05/06/20 08:50 AM
How many grease nipples
by Philippo. 04/06/20 07:28 PM
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
Are There Any Keen Car Badge Collectors out there
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,422
Posts629,782
Members6,938
Most Online1,033
Dec 28th, 2019
Oldbill
High Beam Warning Light Aero +8 #589588
13/08/19 05:46 AM
13/08/19 05:46 AM
Taunton
deano Offline OP
deano  Offline OP
Taunton
Just noticed my high beam warning light is not working. The lights are working perfectly and no other faults are apparent. Looking behind the dash it appears to be an electronic module ie. No bulb to replace.
Has anyone else experienced this problem?
Martin (Deano)
Re: High Beam Warning Light Aero +8 [Re: deano] #589598
13/08/19 08:08 AM
13/08/19 08:08 AM
aerotaff Offline
aerotaff  Offline
I took my dash apart a while ago Deano to get a live feed for a map light it frightened me so much i screwed it back quick....
...,,,Em aerotaff.
Re: High Beam Warning Light Aero +8 [Re: deano] #589600
13/08/19 08:12 AM
13/08/19 08:12 AM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
Martin, yes, mine slowly failed, followed by the ABS and EBD lights. All the lights are part of a module. Williams changed it for me, from memory the new module was less than £100, which I felt was cheap for a Morgan electronics module!!!
After replacing it I noticed that the main beam warning light stays lit for a few seconds as part of the pre-start lights check.
Tarka the 'Otter Mog
2014 Plus 8
Re: High Beam Warning Light Aero +8 [Re: deano] #589605
13/08/19 08:52 AM
13/08/19 08:52 AM
Taunton
deano Offline OP
deano  Offline OP
Taunton
Thanks Peter
I might take the module out myself and see if its repairable.
Martin (Deano)
Re: High Beam Warning Light Aero +8 [Re: deano] #589762
14/08/19 07:36 AM
14/08/19 07:36 AM
Berkshire/Oxon & Devon
JB62 Offline
JB62  Offline
Peter - same with my hi beam light on start up.
V8 Speedster ( current)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
Re: High Beam Warning Light Aero +8 [Re: deano] #590703
19/08/19 05:03 PM
19/08/19 05:03 PM
Taunton
deano Offline OP
deano  Offline OP
Taunton
Quick update guys:
So it quite a job to get the circuit board out, but once out I did a quick check with a multimeter only to find no faults. So I re-soldered the joints either side of the LED and re-tested. Works perfectly, so nothing more than a dry joint.
All back together now and every thing back to normal.
Martin (Deano)
Moderated by  Aeroman, Simon
