16 registered members (EddieB, Ragnar, SimonH, Heinz, Mkiss, milligoon, +8Rich, Fuel.inj, paulmog, Image, TBM, RobCol, Peter J, 60Yards, Gerhard, Alistair), 146 guests, and 24 spiders.
+8Rich 306
John V6 202
lowebird 140
Hamwich 132
Most practical.
by Alistair. 14/12/19 08:49 PM
Replacement fog light unit 2009 plus 4
by Kevcaster. 14/12/19 04:25 PM
MORGAN MODEL
by KEVFITZ. 14/12/19 03:58 PM
thermal onesie
by Phil Bleazey. 14/12/19 01:30 PM
Mudguard Question
by ajsms999. 13/12/19 09:32 PM
Mx5 Gearbox Oil Level
by DaveW. 13/12/19 08:40 PM
3.0 Roadster oil sump
by mal. 13/12/19 08:18 PM
Plus 4, narrow body, 1 off
HERO rally pics
Great Weather in Felixstowe
New M3W
Krazy Horse today
NeilPom, sprinter, Rod c, mgmog, lumpy
6780 Registered Users
Topics36,809
Posts595,839
Members6,780
Most Online723
Dec 5th, 2019
No Birthdays
Page 5 of 5 1 2 3 4 5
Re: A reason why M3Ws leak oil… [Re: 3Gs] #589704
13/08/19 06:44 PM
13/08/19 06:44 PM
Oxon
PaulV Offline
PaulV  Offline
Oxon
Originally Posted by 3Gs
"nobody complains about Morgans leaking oil." ...
... in 1919.
In 2019 its a different story. Hope Morgan can survive with that attitude to 2029!
Re: A reason why M3Ws leak oil… [Re: 3Gs] #589719
13/08/19 08:02 PM
13/08/19 08:02 PM
West of Seattle, USA
LightSpeed Offline
LightSpeed  Offline
Thanks 3Gs. My leak is on the other end of the crank, the pinion seal on the belt that drives the cams. It leaks and spreads oil on the underside of the machine as well as leaving a few drops in a pan that I have on the floor.
Stephen
2019 M3W
Re: A reason why M3Ws leak oil… [Re: LightSpeed] #589721
13/08/19 08:19 PM
13/08/19 08:19 PM
Oxon
PaulV Offline
PaulV  Offline
Oxon
Yep - my oil seal is being done too (as well as the fuel tanks)... funny how this has all happened 8ths after warranty expired!
Re: A reason why M3Ws leak oil… [Re: 3Gs] #599805
17/10/19 06:25 PM
17/10/19 06:25 PM
Lancaster
Phil Bleazey Offline
Lancaster
Following a recent customer’s oil leakage problem, I have, with great cooperation from that customer, done some investigating in the area of the crankshaft oil seal.
It seems that there are two problems. Firstly, the oil seal is an imperial sized item with a 2” bore and it is designed to run on a 2” shaft - the shaft protruding from the Centa rotor, on which the seal runs, is only 50mm. therefore, 0.8mm undersize or 0.032” if you prefer. SKF, who produce this type of oil seal, recommend a much tighter tolerance in the region of plus 0 minus 0.01mm. The second problem is the surface finish of the shaft - as already pointed out on these pages - the finish is much too rough and in some cases badly damaged due to clumsy manufacture.
I have identified a cure for the problem for those wishing to use a standard Centa component. SKF produce a repair sleeve which can be pushed over a damaged shaft to bring the surface back to a useable state. Luckily for us it also increases the shaft diameter by 0.56mm bringing it much closer to the required 2 inches. The sleeves also have a surface finish designed specifically to promote good sealing and also good seal life. For reference if you are fitting one the seal lip and therefore the middle of the sleeve should be 15mm from the flywheel end of the shaft. The sleeve can be fitted complete after the alternator is bolted to the Centa rotor or, if you prefer, the flange can easily be removed from the sleeve and the alternator rotor fitted afterwards but be careful not to scratch the sleeve.
The old seals which I have examined after being used on the standard Centa shaft are all worn flat and need to be replaced at the same tome as the sleeve is installed - not expensive so no point in not replacing it.
A stunning virtual bevel box which demonstrates all this and also the very simple method of fitting using the tool supplied with he sleeve, can be seen here :- https://www.youtube.com/watch?v=wsIklI3xtME
SKF spec :-
Part Number: 99196
Type: Speedi-Sleeve And Tool Kit
Part Information:
• Flange Diameter: 2.2440 in
• Shaft: 1.9690 in
• Shaft From: 1.965 in
• Shaft To: 1.971 in
I hope this helps sort the problem for people. I have posted it as a new post and on the end of the thread about the problem
Good luck,
Phil
2013 M3W www.bleazey.co.uk - Builder of upgrade kits for the Centa coupling and BB mounts for M3W
Re: A reason why M3Ws leak oil… [Re: 3Gs] #599883
18/10/19 08:47 AM
18/10/19 08:47 AM
Lancaster
Lancaster
Just another little tip - if you decide to fit one of these sleeves over a shaft which has the chuck jaw marks present then make sure you file them down before fitting the sleeve. The sleeves are thin and any bumps underneath will show up as ripples in the surface of the sleeve.
Moderated by  Aeroman
