25 registered members (KennethM, JMcL, deano, Bonesie, Paul F, Dougie, ChrisP, John Winn, Gordon D, Alistair, AZJowett, DavidR, +8Rich, DaveW, OZ 4/4, Hawki, bilibib, TBM, LightSpeed, andymot, Neptune, jrt, GIB, M3W55, PeterG), 184 guests, and 21 spiders.
John V6 463
+8Rich 395
TBM 240
Heinz 196
Wearing Face Masks
by Peter J. 30/05/20 06:03 PM
New toy
by Bonesie. 30/05/20 05:31 PM
Interested in a Morgan/Motorcycle Ride VA/WV
by 2Sharp. 30/05/20 05:06 PM
Please help me find my first Morgan
by Roady. 30/05/20 04:04 PM
How to social distance
by John V6. 30/05/20 11:56 AM
Morgan 100 Programme 9 - The Aeromax
by Hotwells. 30/05/20 10:25 AM
Fuel tank
by Spanner Juggler. 30/05/20 10:03 AM
Plus four Test Drive
Engine running!
Slow progress
Social distancing
Somewhere in Scotland?
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,365
Posts628,669
Members6,938
Most Online1,033
Dec 28th, 2019
No Birthdays
Page 2 of 5 1 2 3 4 5
Re: Rectifier issue? [Re: GPC1203] #579624
04/06/19 02:19 PM
04/06/19 02:19 PM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
Due to repeated bobbin failure , I have had my CE unit hard bolted to the mounting plate for about 4 years with no problem.
I simply substituted the bobbins for bolts, with spacers to make it stand away from the plate surface.
Re: Rectifier issue? [Re: nippymog] #579757
05/06/19 09:12 AM
05/06/19 09:12 AM
GPC1203 Offline OP
GPC1203  Offline OP
Fantastic. That gives me reassurance! What type of spacers did you use?
Norwalk, CT, USA
'12 Morgan 3 Wheeler #401
‘15 Jeep Wrangler Sahara
'17 Triumph Bonneville T120 Black
Re: Rectifier issue? [Re: GPC1203] #579760
05/06/19 09:35 AM
05/06/19 09:35 AM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
Simple cylinders of aluminium approx half the length of the original bobbin , drilled clearance size for the bolt. I am sure a few washers would achieve the same effect , but be harder to assemble and not be as elegant.
Similar to this : https://www.ebay.co.uk/itm/M6-x-18mm-OD-Aluminium-Spacer-Standoff-Stand-Off-Collars-Spacers-Bar-Turned/271655485504?var=570488342701&hash=item3f3fedc040:m:m4IQDm792HPvwFm4mM-pDQw&frcectupt=true
Re: Rectifier issue? [Re: nippymog] #580534
09/06/19 12:07 PM
09/06/19 12:07 PM
GPC1203 Offline OP
GPC1203  Offline OP
Thank you for the tip! I’ll try this out if and when my bobbins fail. My new rectifier is on now and it was a pain to put on so I’m hoping I won’t have to mess with it again for some time now.
Thanks all for the help!
Norwalk, CT, USA
Re: Rectifier issue? [Re: GPC1203] #590322
17/08/19 12:00 PM
17/08/19 12:00 PM
Berlin, Germany
thono Offline
thono  Offline
Berlin, Germany
similar problem here now - so I measured the voltage coming from the generator. There we three phases , two of them has around 20Volts against ground, one has 5 V - ist that normal? or do I have an generator issue ?
Thanks Thorsten
Re: Rectifier issue? [Re: GPC1203] #590326
17/08/19 12:22 PM
17/08/19 12:22 PM
Berlin, Germany
thono Offline
thono  Offline
Berlin, Germany
uups sorry my mistake - it was wrong to measure against ground ...
To verify a 3 phase stator : (phase 1,2,3)
1.) verify that phase 1,2,3 has no connection to ground
2.) verify that 1-2, 2-3, 1-3 has the same resistance (0,04 Ohm in my case)
3.) run the engine, rectifier unplugged and verify that: 1-2, 2-3, 1-3 has the same voltage, in my case around 18V when idling
so my stator is o.k. - seems I need a new rectifier following the hints before - Thanks!
Re: Rectifier issue? [Re: GPC1203] #590343
17/08/19 01:55 PM
17/08/19 01:55 PM
Berkshire, England
Mark H Offline
Mark H  Offline
Berkshire, England
Thono- The harley replacement is your way forward and far more reliable providing the connections are fully home and engaged and the long terminal lead ring is changed at the bulkhead connector end. Do not in line splice - run the full lead with the loom & connect at the bulkhead connector. Easier to change a rectifier than a generator.
The main harley connector is identical to the morgan one. Planenut has the master parts list for your replacement part number.
Good luck
Mark
Re: Rectifier issue? [Re: GPC1203] #590395
17/08/19 06:35 PM
17/08/19 06:35 PM
Berlin, Germany
thono Offline
thono  Offline
Berlin, Germany
Hi Mark,
the new harley replacement rectifier is always ordered (69€ ;-) ) Made a testdrive today evening and found that sometimes the old rectifier ist charging - most of time not.
So it seems to be a loose connection ... however I will replace it and everything should be o.k - until the next problem ;-)
Re: Rectifier issue? [Re: GPC1203] #590400
17/08/19 07:04 PM
17/08/19 07:04 PM
Furry Boots City
RedThree Offline
RedThree  Offline
Furry Boots City
Could be a loose connection or poor earth but can also be short circuits along the +ve wire as the insulation breaks up.
Re: Rectifier issue? [Re: RedThree] #590409
17/08/19 08:14 PM
17/08/19 08:14 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
Check the 4 pin plug connection is good and not burnt out. The pins have been known to push back and have a high resistance that leads to heat and the plug melting. If the plug and/or socket has melted then the part numbers are in the alternative parts list here:
https://www.dropbox.com/s/cvo7sehb6o4q9la/Updated%20List%2011%20June%202019.pdf?dl=0
Top of Page 6.
Check the earth connection. The HD rectifier (74540-01) seems to be far more reliable than the standard CE 601 unit.
Moderated by  Aeroman
