24 registered members (Peter J, CooperMan, Alan Patterson, IcePack, Laurens, Edwin, griffo, RobNW, Mike D, Bluebricked, +8Rich, Bitsobrits, Rich Elson, planenut, ewn, DavidR, atalante83, paulmog, Budster, R1NGA, JB62, TBM, Landy, IvorMog), 186 guests, and 15 spiders.
John V6 424
+8Rich 414
TBM 238
Heinz 192
Tank Man Tianaman square
by madmax. 04/06/20 04:19 PM
Plus Four road test
by TimG. 04/06/20 03:42 PM
tempting fate maybe
by meabh. 04/06/20 01:22 PM
Cummings & Goings ;-)
by +8Rich. 03/06/20 08:20 PM
Novochock on TV
by Peter J. 03/06/20 05:43 PM
Happy Birthday
by CooperMan. 03/06/20 02:06 PM
Speedo issue...help!
by Perry. 03/06/20 12:57 PM
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
Are There Any Keen Car Badge Collectors out there
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,414
Posts629,579
Members6,938
Most Online1,033
Dec 28th, 2019
No Birthdays
Toe be or not toe be. #591386
23/08/19 04:18 PM
23/08/19 04:18 PM
Cornwall
griffo Online happy OP
griffo  Online Happy OP
Cornwall
Had a feeling the steering on my ex-GDI Plus 4 (now turboed Plus 4 Plus) Possum was a bit heavy. Greased the front suspension at even more frequent intervals, even increased front tyre pressures a smidgin (this is a technical term).
Either the steering was still too heavy or my aged arms were getting weaker. Finally dug out my old Dunlop optical tracking gauge. Have to admit I'd not checked the tracking since the car was bought new in 2014, 10K miles ago. The specs say toe-in should be
0 (ie parallel) to 3.2mm. I measured toe in at a good 5mm. Re-zeroed the gauge and checked again. Same result. Presumably set like this by the factory since I had not knowingly hit any potholes/kerbs. Since some of the racers even dial in a smidgin of toe OUT, to cut understeer and aid turn-in, I decided to set Possum at 0mm -- exactly parallel. Just driven a 40-mile test and the difference is marked. Steering feels much less heavy, car tracks well in a straight line but turns in much better. So, if your steering is heavy might be worth checking the tracking and go for a parallel setting.
Re: Toe be or not toe be. [Re: griffo] #591399
23/08/19 06:10 PM
23/08/19 06:10 PM
Yorkshire
CooperMan Online content
CooperMan  Online Content
Yorkshire
Griffo, sounds a good result for you
FYI, just looked at my 'post roadtest tracking sign off' sheet that the MMC use and it shows Toe 1mm per side (doesn't quote in or out), Camber -0.5
(was Furloughed - now Redundant)
Re: Toe be or not toe be. [Re: griffo] #591420
23/08/19 08:36 PM
23/08/19 08:36 PM
Cornwall
Cornwall
Hi Jon,
That will be a total of 2mm. Within the spec limita of 0-3.2.
Re: Toe be or not toe be. [Re: griffo] #591421
23/08/19 08:41 PM
23/08/19 08:41 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
I am re my 4/4 very happy with a camber of now -1.
Moderated by  Aeroman, Simon
