8 registered members (John Winn, Eurosystem0, TBM, Morph, +8Rich, thelastgizmo, kankeL, flyfisher), 155 guests, and 9 spiders.
John V6 436
+8Rich 409
TBM 243
Heinz 195
A Morgan meet?
by sospan. 02/06/20 10:58 AM
rands Foot Lockers-Any thoughts?
by Nostalgiajohn. 01/06/20 08:45 PM
Sidescreen restoration
by Phil4/4. 01/06/20 08:25 PM
Exhaust manifold temperatures - misfiring
by thelastgizmo. 01/06/20 06:15 PM
May be worth watching
by CooperMan. 01/06/20 05:27 PM
Morgan 4/4 1992 CVH efi
by Adrian Bott. 01/06/20 03:35 PM
393 km, from one end to the other.
Back of the Dragon near Tazewell VA
Auchindoir Church, Lumsden
Plus four Test Drive
Engine running!
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,389
Posts629,147
Members6,938
Most Online1,033
Dec 28th, 2019
DirkM
Hand brake cable 2006 car #592008
27/08/19 07:38 AM
27/08/19 07:38 AM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
The local garage has my car to fit a new cable. Does anyone know if this is a generic say Ford cable and off what car?
2006 Indigo Blue Roadster S1
Re: Hand brake cable 2006 car [Re: John V6] #592016
27/08/19 08:15 AM
27/08/19 08:15 AM
East Harling, Norfolk UK
Richard Wood Offline
Just a shot in the dark, but since so many MMC fitted components are Land Rover based could that be the case here. I know early LR's at least used a dedicated transmission drum brake with shortish cable.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Hand brake cable 2006 car [Re: John V6] #592043
27/08/19 11:29 AM
27/08/19 11:29 AM
London
MOG 615 Offline
MOG 615  Offline
London
I thought I had one in the garage but that turned out to be a throttle cable , not handbrake. As Richard points out that was a Rover part. However I doubt the handbrake cable is anything other than a bespoke item. Try Melvyn or Krazy Horse in your part of the world?
Andy G
1999 +8 , Indigo Blue.
Re: Hand brake cable 2006 car [Re: John V6] #592049
27/08/19 11:45 AM
27/08/19 11:45 AM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
The garage will look into it.
The have Uncle Melvyns details I am off to RSA Wed through Mon they have time but thanks for the replies
Re: Hand brake cable 2006 car [Re: John V6] #592058
27/08/19 12:15 PM
27/08/19 12:15 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
It's worth reminding everybody that the rubber protector sleeves which run a short distance from the backplates, can split and allow moisture to penetrate into the cable, which then rusts.
From underneath the tool tray you can access the compensator/cable split, and might be able to get some 3 in 1 down the holes.
Bumble was starting to show some cracking of the outer sheaths, and I wrapped both sides in electrical tape, after getting some oil down the cables.
It's a service check item...…..!!
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Hand brake cable 2006 car [Re: John V6] #592099
27/08/19 03:17 PM
27/08/19 03:17 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
These days I would have thought that the cable should have been stainless.
Re: Hand brake cable 2006 car [Re: John V6] #592108
27/08/19 03:53 PM
27/08/19 03:53 PM
howard Offline
howard  Offline
there are loads of classic car outfits that make bespke cables. And some yottie ones that do so in stainless.
Re: Hand brake cable 2006 car [Re: John V6] #592231
28/08/19 07:52 AM
28/08/19 07:52 AM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Dave, no obvious wear on the cable casing at all. BHM have told the garage there were 2 lengths one 2 inches longer than the other. It could be a short version was fitted & the routing caused a failure. I'll chase KH to see if I have any warranty as the cable is under 1 year old and the car had done 7 k since it was fitted.
Moderated by  Aeroman, Simon
