2 registered members (RobNW, Georgetoad), 110 guests, and 14 spiders.
John V6 425
+8Rich 414
TBM 237
Heinz 193
How many grease nipples
by Philippo. 04/06/20 07:28 PM
Bressingham Steam Museum
by Graham, G4FUJ. 04/06/20 07:19 PM
Tank Man Tianaman square
by madmax. 04/06/20 04:19 PM
Plus Four road test
by TimG. 04/06/20 03:42 PM
tempting fate maybe
by meabh. 04/06/20 01:22 PM
Cummings & Goings ;-)
by +8Rich. 03/06/20 08:20 PM
Novochock on TV
by Peter J. 03/06/20 05:43 PM
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
Are There Any Keen Car Badge Collectors out there
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,416
Posts629,630
Members6,938
Most Online1,033
Dec 28th, 2019
Oldbill
Can the water temp. gauge be rewired to read oil? #592892
01/09/19 09:28 AM
01/09/19 09:28 AM
Somerset, UK
PaulJ Offline OP
PaulJ  Offline OP
Somerset, UK
On mine and other Plus 4's the water temperature gauge is supplement by a digital readout in the speedo. and it seems to be a waste of instruments for there to be two readouts of the same thing, so, how about using a suitable sender in the sump and rewiring the original water temp. gauge to read oil temperature?
The only problem is how. At first I thought it was simply a matter of pulling off the plug in the water rail and diverting it to an oil sender, but the ECU didn't like that one bit, has anyone else done this or even thought about it, if so, how to do it?
[Beginning to get the best out of the ARP4]
Re: Can the water temp. gauge be rewired to read oil? [Re: PaulJ] #592897
01/09/19 09:36 AM
01/09/19 09:36 AM
Cornwall
griffo Offline
griffo  Offline
Cornwall
You might be better off with an oil pressure gauge. I just inserted a Stack instrument in the dash of my 2014 Plus 4 with a power feed from the back of the accessory plug and a sensor above the oil filter.
Re: Can the water temp. gauge be rewired to read oil? [Re: PaulJ] #592949
01/09/19 05:21 PM
01/09/19 05:21 PM
East Harling, Norfolk UK
Richard Wood Offline
I think it very unlikely the sensors for coolant temp and oil pressure have the same resistivity range. Add to that ECU compatibility and it's nearly certain an impossibility. Even swapping like for like ECU controlled devices you often have to re-register them before the replacement is accepted.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Can the water temp. gauge be rewired to read oil? [Re: PaulJ] #593064
02/09/19 03:20 PM
02/09/19 03:20 PM
Somerset, UK
PaulJ Offline OP
PaulJ  Offline OP
Somerset, UK
Thanks for the replies Peter and Richard. They were my feelings too, but I thought I would ask in case anyone had managed to sort it out.
Re: Can the water temp. gauge be rewired to read oil? [Re: PaulJ] #593447
04/09/19 09:18 AM
04/09/19 09:18 AM
north yorkshire
Lowflyer Offline
Lowflyer  Offline
north yorkshire
I installed an oil pressure gauge on my Plus 4, got caerbont to make me a 50mm gauge with oil symbol instead of water, they did it within a couple of weeks can't remember the price, not expensive and it matches the rest of the instrumentation. It does utilise the same resistance value transmitter, obviously oil and water temps are not too dissimilar. On my Plus 4 i cut a hole in the dash to the right of the steering wheel. I installed 2 transmitters, one in the Raceline alloy sump and one in the oil filter outlet, i use the sump temp normally, oil runs at around 90C. Its a nice addition. By the way i have standard Smiths (Caerbont now) instrumentation including thier transmitters, if you've got Stack you need to verify input range, can't see it being anything too special as I've got it on my elise and exige and over the years have replaced one of the transmitters with one sourced from Eliseparts.
Re: Can the water temp. gauge be rewired to read oil? [Re: PaulJ] #593599
05/09/19 07:34 AM
05/09/19 07:34 AM
north yorkshire
Lowflyer Offline
Lowflyer  Offline
north yorkshire
Oops sorry guys.......i'm not safe out of the home!...... i meant to say i installed an Oil Temperature gauge.
Apologies
Moderated by  Aeroman, Simon
