13 registered members (AlyMatt, Alistair, M3W55, Richard Wood, Jeff D, SimonH, IcePack, Dab of oppo, LightSpeed, TheRabbit, P Dron, thelastgizmo, Kevcaster), 172 guests, and 12 spiders.
+8Rich 228
John V6 175
Peter J 128
Hamwich 120
Seat base construction- 4/4
by thelastgizmo. 27/02/20 08:51 PM
Show us your GPS / Phone mount
by Landy. 27/02/20 08:03 PM
Little red roadster...just got it home
by thelastgizmo. 27/02/20 01:45 PM
3D CAD - Fusion 360
by Hamwich. 27/02/20 10:02 AM
Wing Sidelight Fitting & Wiring
by Nostalgiajohn. 27/02/20 09:41 AM
Battery Cutoff
by DanT. 27/02/20 03:25 AM
New exhaust..
by TBM. 26/02/20 08:46 PM
Velsheda at Croabh
A day out at Ipswich docks
Garage art
near eccleston VA
FolkMog lunch
Tipracer, George Okuda, Alice, ahdguy, Colin725
6829 Registered Users
Topics37,341
Posts606,993
Members6,829
Most Online1,033
Dec 28th, 2019
Theo69
Rattling front left mudguard #594472
10/09/19 10:54 PM
10/09/19 10:54 PM
GPC1203 Offline OP
GPC1203  Offline OP
I’ve been hearing a rattle at idle and finally figured out where it’s coming from. Title says it all. It’s right side counterpart is quiet at idle and even when I bang on it with my hand with the engine off. All screws and bolts are tight on both. Any ideas?
Norwalk, CT, USA
'12 Morgan 3 Wheeler #401
‘15 Jeep Wrangler Sahara
'17 Triumph Bonneville T120 Black
Re: Rattling front left mudguard [Re: GPC1203] #594475
11/09/19 12:58 AM
11/09/19 12:58 AM
Taffmog Offline
Taffmog  Offline
The clearance between mudguard and tyre is tight, have you tried adjusting the mounting bolts or elongating the holes, assuming the welds etc. are all ok?
Re: Rattling front left mudguard [Re: GPC1203] #594492
11/09/19 06:51 AM
11/09/19 06:51 AM
Nr Watership Down UK
JMD Offline
JMD  Offline
Based on our experience, the link to the steering arm cracks then breaks giving increasing levels of rattle. More seriously, you can also experience progressive fracturing of the welds holding the mudguard together - this also gives rattles. Thus far, we re-weld it but the ultimate solution is something much lighter and more robust - for example the G56 carbon mudguards that we gather are now in use by a few players....
Re: Rattling front left mudguard [Re: JMD] #594494
11/09/19 07:04 AM
11/09/19 07:04 AM
Australia - NSW Mid North Coas...
OZ 4/4 Offline
OZ 4/4  Offline
Oh Dear, not more cracks.....
Re: Rattling front left mudguard [Re: GPC1203] #594513
11/09/19 08:03 AM
11/09/19 08:03 AM
Leicestershire, UK
Bunny Offline
Bunny  Offline
Leicestershire, UK
I'm not saying that this is your problem, but it's worth checking. Try rocking the mudguard back and forth (front to rear) of the car. There should be no movement, but if there is......
The mudguard bolts on to a thick silver anodised plate and this plate worked loose on a friend's car. Getting to the four black hex socket bolts to tighten it back up was a bit of a pain because the hub, brake caliper & disc have to be removed to gain access.
Good news is that since tightening the problem hasn't reoccurred.
Andy
Re: Rattling front left mudguard [Re: GPC1203] #594570
11/09/19 12:45 PM
11/09/19 12:45 PM
New River Valley, VA
rcmatt Offline
rcmatt  Offline
Nuts and bolts working loose on a vehicle with a V-twin engine? WOW, that is a first. laugh2
Rodger
2004 Plus 8 (wife's)
Re: Rattling front left mudguard [Re: rcmatt] #594575
11/09/19 01:24 PM
11/09/19 01:24 PM
West of Seattle, USA
LightSpeed Online content
LightSpeed  Online Content
Stephen
2019 M3W
Re: Rattling front left mudguard [Re: GPC1203] #594594
11/09/19 03:47 PM
11/09/19 03:47 PM
Lille
nestor59310 Offline
nestor59310  Offline
Lille
My mudguards have always broken multiple times because of Vtwin's vibrations.
I fixed the problem permanently by simply removing the mudguards
____________________________________
Lille - FRANCE
(2012) MTW #111
Re: Rattling front left mudguard [Re: GPC1203] #594596
11/09/19 03:49 PM
11/09/19 03:49 PM
Lille
nestor59310 Offline
nestor59310  Offline
Lille
The G56 mudguards must be fine but the price is excessively high.
I think to make a mini stainless steel fender by my Belgian manufacturer of exhausts, something very light and robust
Lille - FRANCE
(2012) MTW #111
Re: Rattling front left mudguard [Re: GPC1203] #594625
11/09/19 06:15 PM
11/09/19 06:15 PM
But then again, it is the shaking.
Your photo shows a failure point that maybe could be strengthened by using a metal sleeve over the original rather than bolting to a tang you would then have to bolt through a tube.
It might work :-)
Stephen
2019 M3W
Moderated by  Aeroman
