22 registered members (DaveW, TBM, Image, Fat Wolfie, Redfate, +8Rich, Laurens, Kevcaster, griffo, lowebird, DCH, RobCol, Spanner Juggler, Hamwich, John V6, Sir Percival, RJW, The Austrian, mutley, Stringers Best Mate, M3W55, RedThree), 171 guests, and 18 spiders.
John V6 443
+8Rich 403
TBM 241
Heinz 194
rands Foot Lockers-Any thoughts?
by Nostalgiajohn. 01/06/20 08:45 PM
Sidescreen restoration
by Phil4/4. 01/06/20 08:25 PM
Exhaust manifold temperatures - misfiring
by thelastgizmo. 01/06/20 06:15 PM
May be worth watching
by CooperMan. 01/06/20 05:27 PM
Morgan 4/4 1992 CVH efi
by Adrian Bott. 01/06/20 03:35 PM
No delivery from Scenic Car Tours
by Spanner Juggler. 01/06/20 09:37 AM
Virtual All Morgans' Day
by Frank 4x4. 01/06/20 08:30 AM
Back of the Dragon near Tazewell VA
Auchindoir Church, Lumsden
Plus four Test Drive
Engine running!
Slow progress
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,386
Posts629,078
Members6,938
Most Online1,033
Dec 28th, 2019
DirkM
Question on Roadster 3.0 engine #594480
11/09/19 06:06 AM
11/09/19 06:06 AM
Solingen, Germany
MarcelT Offline OP
MarcelT  Offline OP
Solingen, Germany
Not that it would change the fun I´m having with my Roadster, but out of interest and some discussion with the regulatory authorities I would like to know what engine type I have in my Roadster Sport, model year 2010.
Depending on where I look(official authority papers, delivery order, bill of sale from German Morgan dealer, David Wellings excellent book), I can choose if the engine has 204 / 220 / 226 / 231 HP. This also was up for discussion with the authorities, as per papers the car has a top speed of 250 km/h (no, it does definitely not), 230 HP and a vehicle payload of 80kg (well… this gives good reason to drive alone ;-) ). Anyway, concentrating on the engine:
The Roadster was delivered through a German Morgan dealer in July 2010, reportedly has the Ford Escape engine - but not sure if it´s a series 2 or 3, as it seems to fall exactly (as per David Wellings Journal) in the period of engine change, where power was increased again from 204HP to 226 (or what?).
Any way to find out about the type?
Thanks,
Marcel
Morgan Roadster Sport 3.0 (S3 - 2010)
Mazda MX5 (NA - 1997)
Re: Question on Roadster 3.0 engine [Re: MarcelT] #594481
11/09/19 06:12 AM
11/09/19 06:12 AM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
I think you can ask the factory for more details.
For more power there are a lot dealers in Britain for to cure the problem. A good thing is a membership in the Morgan Sports Car Club (the British - what else?) there get a great monthly magazine, also the Magazine MOG shows nice things.
Greets René
Re: Question on Roadster 3.0 engine [Re: MarcelT] #594518
11/09/19 08:20 AM
11/09/19 08:20 AM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Marcel, if you supply your unique engine number to Power Torque Engineering Ltd, in Coventry, UK, they should be able to give you an accurate answer as they are the OE supplier of Ford engines to the Factory
Good luck
(was Furloughed - now Redundant)
Re: Question on Roadster 3.0 engine [Re: MarcelT] #594530
11/09/19 09:21 AM
11/09/19 09:21 AM
Lancashire, England
Stewart S Offline
Stewart S  Offline
Lancashire, England
Marcel
I’m no massive authority but from what I know (I have the S2 Roadster 2008) the Roadster Sport was the launch model for the Series 3 engine in 2010
Same ‘Escape’ USA engine as the S2 but uprated in power
Other differences were slightly wider front axle and wider exhaust manifold
Re: Question on Roadster 3.0 engine [Re: MarcelT] #594563
11/09/19 12:34 PM
11/09/19 12:34 PM
southwest France
meabh Offline
meabh  Offline
southwest France
Marcel,
I think Stuart is right here. I have a Nov 2010 Escape engined car, S3.
Re: Question on Roadster 3.0 engine [Re: Stewart S] #594569
11/09/19 12:44 PM
11/09/19 12:44 PM
Lancashire, England
Stewart S Offline
Stewart S  Offline
Lancashire, England
Originally Posted by Stewart S
Marcel
So what I meant by this is, because yours is called the Roadster SPORT, it will be the S3
Re: Question on Roadster 3.0 engine [Re: MarcelT] #594580
11/09/19 02:16 PM
11/09/19 02:16 PM
Solingen, Germany
MarcelT Offline OP
MarcelT  Offline OP
Solingen, Germany
Thanks guys, that helps a lot...! And exactly the information you can't read anywhere...
Re: Question on Roadster 3.0 engine [Re: MarcelT] #594582
11/09/19 02:37 PM
11/09/19 02:37 PM
South Yorkshire
DaveW Online content
DaveW  Online Content
South Yorkshire
Yeah Stewart is on the money.
The wider front frame and Roadster Sport are the key. The first Roadster Sport was at the Buxton Mog in 2010.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Question on Roadster 3.0 engine [Re: MarcelT] #594605
11/09/19 04:55 PM
11/09/19 04:55 PM
southwest France
meabh Offline
meabh  Offline
southwest France
Remember Marcel, moving the air intake over the radiator is good for 12bhp extra -so they say.
Re: Question on Roadster 3.0 engine [Re: MarcelT] #594606
11/09/19 05:05 PM
11/09/19 05:05 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
The Roadster Sport was claimed to deliver 230 HP due to bigger diameter manifold pipes than the S2 model with 204 HP. Also the Sport never had the rev hang issue and another mapping than the S2 model. Re my Roadster Sport it helped to lead the intake hose above the radiator. The radiator is sealed with a kind of rubber lip between radiator and upper cowl area. I bent this rubber lip down a bit and fastened it with a cable tie so that cold air can flow through this new gap and is reaching the air pipe. The difference in the liveliness of the engine is noticeable. With some Roadster Sport the air hose that leads to the airbox hangs simply only downward which is not so optimal.
meabh, funnily I had not seen that you write about the same issue:)
Moderated by  Aeroman, Simon
