4 registered members (Mogdavid, Dan_Lockwood, peterd, LightSpeed), 159 guests, and 13 spiders.
+8Rich 236
John V6 135
Hamwich 127
Image 116
Loving my Jolly Mog
by Landy. 22/02/20 08:30 PM
Omaha in Kingswear today.
by +8Rich. 22/02/20 07:57 PM
Bolt Sizes??
by Nostalgiajohn. 22/02/20 05:44 PM
Pre-season prep
by CooperMan. 22/02/20 04:15 PM
Petrol & Diesel Ban Feedback
by Stringers Best Mate. 22/02/20 03:20 PM
Spring is on it's way
by CooperMan. 22/02/20 12:55 PM
Not just China
by Gambalunga. 22/02/20 09:28 AM
near eccleston VA
FolkMog lunch
well..
Today at Krazy Horse
Mild winter en Provence
Tipracer, George Okuda, Alice, ahdguy, Colin725
6829 Registered Users
Topics37,303
Posts606,180
Members6,829
Most Online1,033
Dec 28th, 2019
Bob17, NickM, Paul Hurst
Rear suspension hanger. Safety watchpoint #594571
11/09/19 12:45 PM
11/09/19 12:45 PM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
On my Roadster the rear offside suspension hanger failed last year in Italy and was welded up.
It has just gone again after c 10k miles!
So I had Krazy Horse order me a new one. You can see how much beefier this is and how MMC have bent the plate to resist the torsional forces.
When it fails you still have damping form one side and the shock absorber rests on the chassis rail & exhaust so at first it isn't so obvious.. In my case on sharp right handers or bouncy roads I could then hear something touching.
If both were to fail I guess it could be more serious.
My advice would be to check both sides. It is obvious in the case of total failure as shock floats free of the brake drum but as it goes it tears along the bolt holes.
Graham when you are next at the factory can you let me know if the passenger side also has this upgrade or if the plate is flat. if upgraded I am tempted to replace that side also.
2006 Indigo Blue Roadster S1
Re: Rear suspension hanger. Safety watchpoint [Re: John V6] #594578
11/09/19 01:51 PM
11/09/19 01:51 PM
London
MOG 615 Offline
MOG 615  Offline
London
I have had one fail in exactly the same spot on my +8 John.
It was found at a service , but goodness knows how long it had been in that state. It is far from obvious when looking from above through the luggage shelf access panel.
From memory it was on the passenger side though.
Andy G
1999 +8 , Indigo Blue.
Re: Rear suspension hanger. Safety watchpoint [Re: John V6] #594585
11/09/19 02:46 PM
11/09/19 02:46 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Had one fail on the previous Roadster, thankfully Dave W helped out with a used one for a quick fix, eventually I replaced both with the beefed up version, with the brake drum off it's quite easy
They don't take a huge load it's just the shocker, but they fracture across the hole as it's the weak point as per John V6's photos
Re: Rear suspension hanger. Safety watchpoint [Re: John V6] #594603
11/09/19 04:26 PM
11/09/19 04:26 PM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Jon,
do you have to take of the brake shoes or can you get at the nuts with the shoes in place?
Re: Rear suspension hanger. Safety watchpoint [Re: John V6] #594619
11/09/19 05:59 PM
11/09/19 05:59 PM
Norway
Geir Karlsen Offline
Norway
It also failed on my 4/4.[img]http://https://tm-img.com/image/exbIn https://tm-img.com/image/exHz4 https://tm-img.com/image/exqMc[/img]
They seem to last a bit longer ith stock useless shock absorbers. I would recommend everyone to replace them at the annual service.
I managed to replace mine with the brake shoes in place just undoing the clamps holding them to the shield. The idea of undoing the clamps an all the springs was not tempting.
4/4 2 seater 2001 model
Re: Rear suspension hanger. Safety watchpoint [Re: John V6] #594632
11/09/19 06:37 PM
11/09/19 06:37 PM
Sumerset
Rog Offline
Rog  Offline
Sumerset
Might the failure be symptomatic of an unconstrained rear suspension allowing the damper to bottom out? Perhaps exasperated with the extra load when traveling with luggage?
Roger
Re: Rear suspension hanger. Safety watchpoint [Re: Rog] #594636
11/09/19 07:23 PM
11/09/19 07:23 PM
Aerdenhout, The Netherlands
BertR Offline
BertR  Offline
I think it is (again) a flawed design. The new model shown by John V6, seems more robust. In any “normal” car this would be a recall... but we morganeers, get it proactively replaced in the next service at our own cost. We must just love our cars.
2009 Roadster, Lancia midnight blue, cinnamon upholstery.
Re: Rear suspension hanger. Safety watchpoint [Re: John V6] #594669
12/09/19 12:22 AM
12/09/19 12:22 AM
Taffmog Offline
Taffmog  Offline
Broke one on my plus 8 too, just a crashing noise at the rear offside.
Not an uncommon failure apparently....
Re: Rear suspension hanger. Safety watchpoint [Re: John V6] #594702
12/09/19 08:47 AM
12/09/19 08:47 AM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Passenger side bracket now on order. The other one might be fine but I decided to upgrade fully & will also fit some of Roger's bump stops.
Re: Rear suspension hanger. Safety watchpoint [Re: John V6] #594768
12/09/19 02:56 PM
12/09/19 02:56 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Mine failed in Kent the year the Mog was there, and I didn't know until we got home.
Access is OK without removing the shoes.
Scroll right down for images http://www.talkmorgan.com/ubbthreads.php/topics/150843/1
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Moderated by  Aeroman, Simon
