18 registered members (nippymog, DirkM, +8Rich, Graham, G4FUJ, DaveW, planenut, TBM, KEVFITZ, rossocorsa, Spanner Juggler, Fuel.inj, DCH, MJF, Tresco, Deejay, Phil T, Jon G4LJW, teifistar), 152 guests, and 14 spiders.
John V6 440
+8Rich 405
TBM 245
Heinz 198
Morgan 4/4 1992 CVH efi
by Adrian Bott. 01/06/20 03:35 PM
No delivery from Scenic Car Tours
by Spanner Juggler. 01/06/20 09:37 AM
Virtual All Morgans' Day
by Frank 4x4. 01/06/20 08:30 AM
Water Hose Heater Bypass TR4 Engine
by BuyBritish. 01/06/20 05:20 AM
The lubrication button
by Mc Black. 31/05/20 05:21 PM
Hood frame rattle
by Viper. 31/05/20 04:16 PM
Lockdown Fettling
by Budster. 31/05/20 03:33 PM
Back of the Dragon near Tazewell VA
Auchindoir Church, Lumsden
Plus four Test Drive
Engine running!
Slow progress
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,382
Posts628,994
Members6,938
Most Online1,033
Dec 28th, 2019
AlexH, Marian
Re: Do you always leave your roof up or down [Re: ChrisConvertible] #594381
10/09/19 01:42 PM
10/09/19 01:42 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
I have the studded hood not easy-up.If fitted then it is left up in tension to keep shape.
If not in use then folded to keep the clear plastic sections flat.
Red Plus8
Re: Do you always leave your roof up or down [Re: ChrisConvertible] #594388
10/09/19 02:39 PM
10/09/19 02:39 PM
Somerset, UK
PaulJ Offline
PaulJ  Offline
Somerset, UK
I think the general recommendation is for a convertible roof to be left up and probably tensioned when not being used for periods, but to stop my back window creasing when down - most of the summer - I use a length of foam pipe insulation folded into the window, it's worked so far, but the car is only 3 years old, so I'll let you all know at its' 10th anniversary if it really is a good idea.
[Beginning to get the best out of the ARP4]
Re: Do you always leave your roof up or down [Re: ChrisConvertible] #594729
12/09/19 10:56 AM
12/09/19 10:56 AM
PHZI Offline
PHZI  Offline
I wouldn'teave the hood down for even 5 mins when the car is put away, even for the night.. Always under tension. I wouldn't like to be left all crumpled up. Wouldn't do the joints any good!
Also, having the old style roof, I can roll it up and leave attached at the rear when driving with the roof down. That way the windows don't crease and it is well positioned to put up in a hurry should there be a thunder plump.
Re: Do you always leave your roof up or down [Re: ChrisConvertible] #594730
12/09/19 11:03 AM
12/09/19 11:03 AM
South Yorkshire
DaveW Online content
DaveW  Online Content
South Yorkshire
The PVC hood is more prone to shrinking in cold weather.
The first couple of summers I left my (Mohair) Roadster hood down for long periods and it survived OK.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Do you always leave your roof up or down [Re: ChrisConvertible] #594748
12/09/19 01:17 PM
12/09/19 01:17 PM
Brussels, Belgium
Giles Offline
Giles  Offline
Brussels, Belgium
The PVC hood does indeed shrink in cold weather & is a pain to put up after having been stowed away for a while.
For that reason, as well as the fact that Belgian weather is more often worse than the British one, I keep the hood up most of the time, but without fitting the doors.
I only drive topless if the weather forecast indicates at least 3 days without rain...
owner of a 1989 4/4 2 seater, AKA "Bubbles"
Re: Do you always leave your roof up or down [Re: DaveW] #594767
12/09/19 02:51 PM
12/09/19 02:51 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
+1 ---- Still do. It is down at the moment.
Re: Do you always leave your roof up or down [Re: ChrisConvertible] #594783
12/09/19 05:00 PM
12/09/19 05:00 PM
Petersfield, Hampshire
Ian Wegg Offline
Ian Wegg  Offline
I left my hood down for about 7 years and mice chewed some sizable chunks out of it. After glueing home-made vinyl patches over the holes it has been perfectly servicable since.
1980 Royal Ivory 4/4 4-seater. B4771
Re: Do you always leave your roof up or down [Re: Gambalunga] #594787
12/09/19 05:09 PM
12/09/19 05:09 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Agreed mine is the poverty model PVC that responds better to a good stretch.
2006 Indigo Blue Roadster S1
Re: Do you always leave your roof up or down [Re: Giles] #594811
12/09/19 07:41 PM
12/09/19 07:41 PM
pete757 Offline
pete757  Offline
You would never drive in the UK if you did that!
Dark Red 4/4 80th Anniversary
Re: Do you always leave your roof up or down [Re: ChrisConvertible] #594815
12/09/19 07:54 PM
12/09/19 07:54 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
I always close the roof, easy up PVC. When the car was in the workshop for six months last year due to the wildlife accident, the roof was not stretched. Ok the car stood luxuriously parked in a heated hall. But it took two months until the roof was so relaxed again that I didn't have to fear a crack in the window. The shrinkage was so strong.
Moderated by  Aeroman, Simon
