15 registered members (Taffmog, lord-richfield, Elcyd, Pigiron, HeadlessBlue, Themorganeer, Ricardo, Zallium, spooner, Spanner Juggler, AlyMatt, hugo, Marmota, GARYMYNARD, RobCol), 262 guests, and 92 spiders.
+8Rich 256
Hamwich 120
Peter J 114
John V6 107
Classic Le Mans 2020
by chocadoodledoo. 28/01/20 07:34 PM
New water leak.
by Viper. 28/01/20 04:18 PM
Rear leaf springs - 1967 Plus 6
by Pat L. 28/01/20 03:48 PM
North coast 500 welcomes you
by Morgan110. 28/01/20 03:28 PM
2016 Plus 4 Underdash
by DaveW. 28/01/20 01:31 PM
2011 Plus 4 Brakes
by Jon G4LJW. 28/01/20 10:51 AM
Airborn Supersport
by Rovert. 28/01/20 10:11 AM
Two Tone Plus 6
Avonwood Developments Box
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,097
Posts602,018
Members6,812
Most Online1,033
Dec 28th, 2019
Hiwex
Page 13 of 14 1 2 11 12 13 14
Re: More worries - cracked gas tank. [Re: DocNik] #595034
14/09/19 12:58 PM
14/09/19 12:58 PM
West of Seattle, USA
LightSpeed Offline
LightSpeed  Offline
Thanks for the info 3Gs.
Did the shocks make a noticeable difference in ride?
Stephen
2019 M3W
Re: More worries - cracked gas tank. [Re: LightSpeed] #595108
15/09/19 05:15 AM
15/09/19 05:15 AM
Seattle, WA.
3Gs Offline
3Gs  Offline
Seattle, WA.
I bought my M3W with the Suplex so no comparison to go on, but I have the stock shocks in a box.
Re: More worries - cracked gas tank. [Re: DocNik] #595152
15/09/19 11:43 AM
15/09/19 11:43 AM
LightSpeed Offline
LightSpeed  Offline
I wonder if the previous owner changed them because of the ride quality or they thought that it would make them go faster in the corners😊. The Spax that are on mine oem seem to work fine the way I drive it. Admittedly I don’t race it and don’t plan to do so since I know my mini coopers would run circles around this loosely associated bag of bolts.
I was looking at how the gas tank straps go around some square box tubing and how they use the corners of the tube as a pulley. Creative to say the least but MMC decided that only part of the strap needed to go around a smooth corner and the last maybe half inch of it goes around a sharp edge that doesn’t even appear to be filed smooth! Both straps are like that; someone should be spanked for that!
Stephen
2019 M3W
Re: More worries - cracked gas tank. [Re: LightSpeed] #595179
15/09/19 03:40 PM
15/09/19 03:40 PM
Rio Del Mar, CA
kankeL Offline
kankeL  Offline
Rio Del Mar, CA
You can also adjust the ride height with the new shocks, my rear was very low while traveling with a passenger and luggage.
I put a piece of a fuel hose around that square bracket and it feel much more secure now smile
2016 M3W, Army Green Matte/Tan Leather, 12k miles
Re: More worries - cracked gas tank. [Re: DocNik] #595207
15/09/19 06:54 PM
15/09/19 06:54 PM
Near Chicago, USA
HalfFull Offline
HalfFull  Offline
Near Chicago, USA
For those of you with far more experience than I...what is the best way to visualize this area? When seats are out, there is the aluminum panel behind that appears riveted...easily removed? With all the nooks and crannies in this beast, thinking of getting a small endoscopic camera for continued inspection purposes...
Aka Joejoe
Re: More worries - cracked gas tank. [Re: DocNik] #595213
15/09/19 07:18 PM
15/09/19 07:18 PM
LightSpeed Offline
LightSpeed  Offline
The first photo shows the strap in question and the second is looking straight down from the top where the box tube is bevel cut and the strap wraps around that cut, sadly.
KankeL, I thought about doing something like that, with maybe teflon or PTFE to armor that sharp corner to protect the strap.
Stephen
2019 M3W
Re: More worries - cracked gas tank. [Re: DocNik] #595223
15/09/19 08:48 PM
15/09/19 08:48 PM
Near Chicago, USA
HalfFull Offline
HalfFull  Offline
Near Chicago, USA
Nice photos, LightSpeed. Was able to get back there and found a loose belt on the left side. Of course you need a deep socket to reach (13 mm) but was able to tighten. As was previously mentioned, there is not much length left on the bolt and no clue how tight to make the belt. As I left it, I can elevate the top of the belt mid-tank with a finger, but not get my finger very far under (these back-of-the-envelope tolerances we use!). Hopefully that is enough, as I also thought to shim with some rubber against the tank. Curious how tight others have made theirs.
Aka Joejoe
Re: More worries - cracked gas tank. [Re: DocNik] #595239
15/09/19 11:35 PM
15/09/19 11:35 PM
LightSpeed Offline
LightSpeed  Offline
Then tension is a good question, and something I know not.
Rubber shims, maybe but the belt won’t slide over them but a plywood shin would allow the belt to slip over it for tensioning.
Stephen
2019 M3W
Re: More worries - cracked gas tank. [Re: DocNik] #595245
16/09/19 05:08 AM
16/09/19 05:08 AM
Rio Del Mar, CA
kankeL Offline
kankeL  Offline
Rio Del Mar, CA
Be careful with the adjuster - it’s made out of cheese and would snap easily. Loosen the belt and use some shims and then re-tighten.
Re: More worries - cracked gas tank. [Re: DocNik] #595294
16/09/19 11:50 AM
16/09/19 11:50 AM
New River Valley, VA
rcmatt Offline
rcmatt  Offline
at that cost I hope they at least warmed up the KY jelly before sticking it to you
Rodger
2004 Plus 8 (wife's)
Moderated by  Aeroman
