14 registered members (Image, +8Rich, Alan Patterson, Phil1953, flyfisher, Robbie, dmh, Richard Wood, DavidR, LaserLes, SFG, M3W55, The Austrian, Hamwich), 118 guests, and 15 spiders.
John V6 421
+8Rich 415
TBM 234
Heinz 193
the classic / collectors car market
by howard. 05/06/20 09:53 AM
ebay made me chuckle
by Grumpy2. 05/06/20 08:50 AM
How many grease nipples
by Philippo. 04/06/20 07:28 PM
Bressingham Steam Museum
by Graham, G4FUJ. 04/06/20 07:19 PM
Tank Man Tianaman square
by madmax. 04/06/20 04:19 PM
Plus Four road test
by TimG. 04/06/20 03:42 PM
tempting fate maybe
by meabh. 04/06/20 01:22 PM
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
Are There Any Keen Car Badge Collectors out there
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,418
Posts629,688
Members6,938
Most Online1,033
Dec 28th, 2019
Oldbill
Creaking clutch - '93 +8 #595434
17/09/19 08:35 AM
17/09/19 08:35 AM
North Yorkshire
V
vbalddave Offline OP
V
North Yorkshire
Issue - when releasing the clutch, there is a loud creak from the bellhousing area. Depressing the clutch does not produce the creak - it's only on release. The creak on release is the same whether the car is being driven, or with the engine off.
The clutch works normally, bites in the right place, doesn't slip, and there is no loss of fluid. Before my ownership, the car had a new clutch master cylinder. The slave cylinder is firmly attached to the bellhousing. Before I put my head under the bonnet, I had assumed that the creak was from the clutch pedal pivot/linkage, but I've now eliminated that as the source.
Before going to the trouble of doing an engine out job, I'd thought I'd ask if anybody has had a similar problem, and if/how they resolved it.
Thanks in advance for your help!
Dave
vbalddave
Red 1993 +8 3.9
North Yorkshire
Re: Creaking clutch - '93 +8 [Re: vbalddave] #595460
17/09/19 02:46 PM
17/09/19 02:46 PM
East Harling, Norfolk UK
Richard Wood Online NoMood
It's not the return spring on the pedal box is it? Mine made a creaking/clicking noise until I applied a little spray grease.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Creaking clutch - '93 +8 [Re: vbalddave] #595545
17/09/19 09:45 PM
17/09/19 09:45 PM
Edenbridge, Kent, UK
N22MOG Offline
N22MOG  Offline
I have the same problem with my ‘96 Plus 8 so hope that someone can help.
Steve L.
1996 Plus 8
Re: Creaking clutch - '93 +8 [Re: vbalddave] #595626
18/09/19 01:01 PM
18/09/19 01:01 PM
PHZI Online content
PHZI  Online Content
I would certainly spray your suitable lubricant of choice all over the place before anything drastic like engine out!
Re: Creaking clutch - '93 +8 [Re: vbalddave] #595633
18/09/19 01:48 PM
18/09/19 01:48 PM
North Yorkshire
V
V
North Yorkshire
Thanks for the replies, all - I have indeed sprayed lubricant everywhere, and profusely, and was both surprised and disappointed that it wasn't the answer. Bottom line is that the noise is definitely coming from the bellhousing area....into which I have resisted squirting anything, though the temptation was there scared
@ Steve L - I will keep you posted if/when I make any progress
Dave
vbalddave
Red 1993 +8 3.9
North Yorkshire
Moderated by  Aeroman, Simon
