5 registered members (brian battersby, Clipper, PaulyG, AlanH, Ricardo), 159 guests, and 14 spiders.
John V6 425
+8Rich 414
TBM 237
Heinz 193
How many grease nipples
by Philippo. 04/06/20 07:28 PM
Bressingham Steam Museum
by Graham, G4FUJ. 04/06/20 07:19 PM
Tank Man Tianaman square
by madmax. 04/06/20 04:19 PM
Plus Four road test
by TimG. 04/06/20 03:42 PM
tempting fate maybe
by meabh. 04/06/20 01:22 PM
Cummings & Goings ;-)
by +8Rich. 03/06/20 08:20 PM
Novochock on TV
by Peter J. 03/06/20 05:43 PM
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
Are There Any Keen Car Badge Collectors out there
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,416
Posts629,629
Members6,938
Most Online1,033
Dec 28th, 2019
No Birthdays
Ford engine cover installed #595188
15/09/19 04:57 PM
15/09/19 04:57 PM
Norway
Soleng Offline OP
After having the spark plugs drowned in water twice, I got hold of a used Ford engine cover and installed it in my Plus 4 (Duratec engine). Time will tell if this solves the water ingress problem.
21 Comments
Re: Ford engine cover installed [Re: Soleng] #595520
17/09/19 06:51 PM
17/09/19 06:51 PM
Northern Germany
bmgermany Offline
bmgermany  Offline
Northern Germany
I wonder If this large cover accumulate the hot engine air.
But I have to save the plugs in the future
Re: Ford engine cover installed [Re: Soleng] #595581
18/09/19 08:19 AM
18/09/19 08:19 AM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Richard, nicely made thumbs
(was Furloughed - now Redundant)
Re: Ford engine cover installed [Re: DaveW] #595592
18/09/19 08:57 AM
18/09/19 08:57 AM
Buckinghamshire
RichB Offline
RichB  Offline
Buckinghamshire
Originally Posted by DaveW
Nice work Richard. Those two threaded holes on the offside are perfect!
Thanks DaveW. In fact it took a while to work out where best to mount the cover. Initially I was going to use the two large studs protruding from the front of the engine - but decided against that and looked to use the threads on some of the studs used to hold down the rocker cover shown in photo (as the Ford engine cover uses in the GDI Focus in the US).
But, despite trying many various nuts (metric, UNF, + various from my 'nut' tin etc) on these, I could not find any that would fit. Any idea what they are?
Just a note for anyone doing similar - bending tubes used were smaller than a 'standard' scaffold pole.
+4 GDI Connaught Green, 2014
Magnolia
Re: Ford engine cover installed [Re: bmgermany] #595600
18/09/19 09:24 AM
18/09/19 09:24 AM
Norway
Soleng Offline OP
Soleng  Offline OP
Norway
I don't think that the cover will pose a heat problem. After all, many ford models use such covers.
Harald
Re: Ford engine cover installed [Re: Soleng] #623288
16/03/20 10:49 AM
16/03/20 10:49 AM
Surrey
Kevcaster Offline
Kevcaster  Offline
Surrey
Following the lead above and inspired by DaveW's book I took the plunge. I made and fitted this cover made from 1.2mm sheet aluminium and some stainless steel stud/spacers. It seems to work although have few tools and no vice so it's not as pretty as some others on this forum. I post simply to say, if I can .... you can. it also seems to me that the lack of cover over such a vulnerable and essential area is something of an Achilles heel that should have been fixed at the outset - at minimum a Morgan upgrade part should be available ex factory.
Offside cover is fixed with 3x40mm studs into the empty cam cover threads - studs from a German supplier on eBay 40mm M6 male one end and M6 female the other - they work for both sides of the cover, both near and offsides
Nearside, secured by the same 40mm studs screwed down onto an available cam cover stud - I assume made available there for the Ford cover
The offside is secured with M6 hex bolts into the female thread of the 40mm studs - three in this case although 4 threads are available - space left for a suitable Morgan logo at some stage
At the front, it turns down shielding water ingress to the gulley that is home to the spark plugs
I re-routed the cable that disappears under the cover to go over the top, it has a tube shield over part of it but I'll keep an eye on this as it rubs on the heater pipe. I notice that others have fitted trim strip to the edges and I may consider this once I can locate it online.
Six months ago this kind of thing would have been unthinkable for me, this forum and your great advice has given me the confidence to approach this sort of work.
Kevin
2009 Morgan Plus 4 4 seater
Re: Ford engine cover installed [Re: Kevcaster] #623331
16/03/20 02:08 PM
16/03/20 02:08 PM
North of Stamford, UK
HeadlessBlue Offline
That looks like a cracking job you’ve done there Kevin.
I look on in envy-v well done
HB
Re: Ford engine cover installed [Re: Soleng] #623352
16/03/20 03:21 PM
16/03/20 03:21 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
+1. Well done.
2006 Indigo Blue Roadster S1
Re: Ford engine cover installed [Re: Soleng] #623356
16/03/20 03:29 PM
16/03/20 03:29 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Well done Kev...…..now what next??
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Ford engine cover installed [Re: Soleng] #623369
16/03/20 04:38 PM
16/03/20 04:38 PM
YORK
KEVFITZ Offline
KEVFITZ  Offline
YORK
Sell your book ?
Re: Ford engine cover installed [Re: RichB] #623416
16/03/20 07:33 PM
16/03/20 07:33 PM
Surrey
Kevcaster Offline
Kevcaster  Offline
Surrey
Originally Posted by RichB
[quote=DaveW]Nice work Richard. Those two threaded holes on the offside are perfect!
They are metric M6 studs
Kevin
Moderated by  Aeroman, Simon
