16 registered members (Stringers Best Mate, Morph, How, Jeff D, Ian Wegg, BigSteve, Roady, TBM, John07, JB62, Heinz, Phil4/4, planenut, ajg141, Riggsy, Phil T), 156 guests, and 13 spiders.
John V6 438
+8Rich 408
TBM 239
Heinz 195
4/4 1.8 Duratec oil pressure lowish
by Riggsy. 02/06/20 03:30 PM
A Morgan meet?
by sospan. 02/06/20 10:58 AM
rands Foot Lockers-Any thoughts?
by Nostalgiajohn. 01/06/20 08:45 PM
Sidescreen restoration
by Phil4/4. 01/06/20 08:25 PM
Exhaust manifold temperatures - misfiring
by thelastgizmo. 01/06/20 06:15 PM
May be worth watching
by CooperMan. 01/06/20 05:27 PM
393 km, from one end to the other.
Back of the Dragon near Tazewell VA
Auchindoir Church, Lumsden
Plus four Test Drive
Engine running!
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,390
Posts629,157
Members6,938
Most Online1,033
Dec 28th, 2019
DirkM
Salisbury 7HA Diff gasket #595533
17/09/19 08:10 PM
17/09/19 08:10 PM
BigLes Offline OP
BigLes  Offline OP
Mine is dripping oil, so assuming it's the gasket thats failed, is it possible to replace the gasket on one of these with the rear axle in situ?
And does anything else need to be removed to get the cover plate off - handbrake rods, brake pipes, etc?
Plus 4 4 seater Fiat TC 2ltr
Re: Salisbury 7HA Diff gasket [Re: BigLes] #595539
17/09/19 08:49 PM
17/09/19 08:49 PM
Powick
tmg513 Offline
tmg513  Offline
Powick
I don't remember having any trouble doing it, it was quite straightforward. I certainly did it with the axle in situ on mine.
1972 4/4 2 Seater
Re: Salisbury 7HA Diff gasket [Re: BigLes] #595549
17/09/19 10:01 PM
17/09/19 10:01 PM
Arwyn Williams Offline
It should be possible to change the gasket in situ.
Before you change it though, just check the drain/fill plugs and if possible treat them to a bit of PTFE tape or other thread sealant.
The other thing to check is the pinion shaft seal, if they leak they do tend to track oil back. If it needs replacing, it can be done in situ, but don't expect it to come out in one piece. There are three versions so make sure you get the right one!
Kind regards
Arwyn
Re: Salisbury 7HA Diff gasket [Re: BigLes] #595564
18/09/19 07:01 AM
18/09/19 07:01 AM
Chester, UK
Grumpy2 Offline
Grumpy2  Offline
Chester, UK
I'd second this. Mine was dripping so I bought a couple of gaskets, turned out the leak was from the fill plug. PTFE tape seems to have cured it. I now have a couple of gaskets I don't need!
94 plus 8 in Westminster Green - I think!
Re: Salisbury 7HA Diff gasket [Re: BigLes] #595569
18/09/19 07:34 AM
18/09/19 07:34 AM
BigLes Offline OP
BigLes  Offline OP
Thanks for the tips. A closer inspection is needed before any work is started!
Re: Salisbury 7HA Diff gasket [Re: BigLes] #595590
18/09/19 08:51 AM
18/09/19 08:51 AM
London
MOG 615 Offline
MOG 615  Offline
London
First I would check that it is actually the gasket.
If the vents are blocked , the axle casing can be pressurised , and the oil will travel along the underside and drip off the lowest point (the diff casing) making it look like the gasket has gone.
They are normally found on the axle tubes next to the brake back plates at the rear of the tube about halfway down. They face rearwards to avoid collecting road grime, but can still suffer from it in that location.
Andy G
1999 +8 , Indigo Blue.
Re: Salisbury 7HA Diff gasket [Re: BigLes] #595616
18/09/19 12:27 PM
18/09/19 12:27 PM
If as Andy suggests, the diff vent hole is blocked (and it's a tiny 1/8" hole), it would be a good idea to pop the rear drums off and check the oil hasn't worked its way past the oil seals onto the brake shoes!
Arwyn
Re: Salisbury 7HA Diff gasket [Re: BigLes] #595679
18/09/19 06:54 PM
18/09/19 06:54 PM
BigLes Offline OP
BigLes  Offline OP
Thanks for the heads up on the vent holes, I'll certainly check them.
Moderated by  Aeroman, Simon
