16 registered members (Rog G, TSCULL, Sir Percival, MJF, Landy, Alistair, brownbaker, IvorMog, Neptune, M3W55, +8Rich, Hamwich, John07, GKT, stumog, RobNW), 179 guests, and 20 spiders.
John V6 424
+8Rich 423
TBM 236
Heinz 195
Plus 4 Push Button Start?
by Nostalgiajohn. 05/06/20 02:45 PM
vdo speedo
by milliemollie. 05/06/20 12:50 PM
Interesting new hardtop
by +8Rich. 05/06/20 12:43 PM
the classic / collectors car market
by howard. 05/06/20 09:53 AM
ebay made me chuckle
by Grumpy2. 05/06/20 08:50 AM
How many grease nipples
by Philippo. 04/06/20 07:28 PM
Bressingham Steam Museum
by Graham, G4FUJ. 04/06/20 07:19 PM
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
Are There Any Keen Car Badge Collectors out there
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,421
Posts629,762
Members6,938
Most Online1,033
Dec 28th, 2019
Oldbill
can anyone tell me what this is called please? #595963
20/09/19 04:44 PM
20/09/19 04:44 PM
west cornwall
gavin Offline OP
gavin  Offline OP
west cornwall
i'm renewing the water hoses on my 1.6cvh engine 4/4 and i'm utterly stumped trying to find a replacement one of these.
can anyone tell me what its called please as no matter what search terms i try i cant find anything similar.
Re: can anyone tell me what this is called please? [Re: gavin] #595968
20/09/19 05:21 PM
20/09/19 05:21 PM
Gloucestershire, UK
Hamwich Online content
Hamwich  Online Content
Gloucestershire, UK
I've always called it a coolant crossover or bypass pipe. I believe it's to ensure hot water gets to the inlet manifold even when the heater is turned off. A simple job to solder one up from copper plumbing pipe, I don't think the angle is critical.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: can anyone tell me what this is called please? [Re: gavin] #595979
20/09/19 06:08 PM
20/09/19 06:08 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Uncle Melvyn will sell them.
2006 Indigo Blue Roadster S1
Re: can anyone tell me what this is called please? [Re: gavin] #596023
21/09/19 07:15 AM
21/09/19 07:15 AM
Luddite Offline
Luddite  Offline
Tim`s description works for me. I call it a heater by-pass. I know little to nothing of fluid dynamics but suspect the angle may well play a part in such calculations, given how much simpler it would be to manufacture the by-pass as a straight link..? Perhaps best to note the angle in relation to flow and return, or at least replace it in the same way it was removed, assuming it was fitted correctly in the first place..?
Yup a couple of "T" copper plumbing fittings would do the job to some degree and better than a leaking and corroded pipe, which the one on my +8 was... Had to clean it up a tad as Rutters had no stock in the recent past, but was seeking to have a batch made up in time.
I suspect if one was really stuck just joining the pipes straight through would keep you on the road, though best NOT to switch the heater isolation valve off as that would inhibit coolant circulation.... You may also need to bleed the system if you find that the heater does not warm up..?
Re: can anyone tell me what this is called please? [Re: gavin] #596031
21/09/19 08:14 AM
21/09/19 08:14 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Sifab would I am sure run one up in aluminium.
Re: can anyone tell me what this is called please? [Re: gavin] #596052
21/09/19 11:05 AM
21/09/19 11:05 AM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
You could try Burton Power, who are renowned Ford engine specialists
(was Furloughed - now Redundant)
Re: can anyone tell me what this is called please? [Re: gavin] #596068
21/09/19 02:48 PM
21/09/19 02:48 PM
cerealsurfer Offline
Re: can anyone tell me what this is called please? [Re: gavin] #596241
22/09/19 08:45 PM
22/09/19 08:45 PM
Durham, UK
smudger1 Offline
smudger1  Offline
Durham, UK
I’ll have a look in the garage, I think I have one
Cheers
1999 Morgan Plus 8. 3.9 ....
1961 Alvis TD21 Series1 3 Litre Auto....
Re: can anyone tell me what this is called please? [Re: gavin] #596305
23/09/19 10:00 AM
23/09/19 10:00 AM
west cornwall
gavin Offline OP
gavin  Offline OP
west cornwall
thanks for the replies, thats the part, yet again though i wish i had listened to my dad, he was a classic motorcycle chap of the old school, when he offered to teach me some metal work skills and to braze because i would find it so much more rewarding making one from some brass pipe than giving melvyn rutter the silly amount of cash he wants for a bit of pipe.
Re: can anyone tell me what this is called please? [Re: gavin] #596346
23/09/19 01:44 PM
23/09/19 01:44 PM
Oxfordshire UK
E
Eurosystem0 Offline
Eurosystem0  Offline
E
Oxfordshire UK
Bit of pipe? Its a bit more than that. Labour at circa £50 per hour (plumbers circa £60- £70 per hour), fabrication, welding etc etc. Does not seem bad to me.
Moderated by  Aeroman, Simon
