11 registered members (JonnyF, Marmota, Mogdavid, John07, SimonH, P Dron, Anthony4/4, IcePack, paddockman, Craig Jezz, Ken A), 101 guests, and 12 spiders.
+8Rich 258
Peter J 126
John V6 122
Hamwich 108
water in the oil of an air cooled engine???
by Phil Bleazey. 25/01/20 10:54 AM
Water free Coolant
by DaveK. 25/01/20 10:46 AM
Space saver at 90mph
by DaveW. 24/01/20 09:24 PM
Location
by Nostalgiajohn. 24/01/20 04:48 PM
The French want their words back!
by Gambalunga. 24/01/20 03:43 PM
ARP4 Info urgently needed
by NeilPom. 24/01/20 10:23 AM
How to sell my M3W?
by Chris M3W. 23/01/20 06:03 PM
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
Bevel box oil leak
Hogmanay Run
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,073
Posts601,556
Members6,812
Most Online1,033
Dec 28th, 2019
No Birthdays
Page 14 of 15 1 2 12 13 14 15
Re: Air Intake improvements [Re: sospan] #595864
19/09/19 09:31 PM
19/09/19 09:31 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
Originally Posted by sospan
A manufacturer tends to use a map that is a compromise for different climate regions. Hot climates and cold climates. There are variations they would put in sometimes for sufficient sales volumes or specific requests from dealers/customers. I once owned a Ford Focus that you could buy with two power output options. I researched it and concluded that it was simply different mapping. No component changes just map parameters modified. This ability to tweak mapping is the basis of the aftermarket chipping business. The true correct way is for a rewrite of the map under both static and on road driving. Small gains only in a normally aspirated engine but turbo allows more by increasing boost as well. Bigger power increases require new cams, valves, other component changes.
For the Plus8 I think the Tornado chip is a proven remap modification that can increase power and improve general running characteristics and cure some faults.
I agree. The MSD EFI has a MAP that is designed by the Computer based on the Driver's input and what the engine has to offer. (At least I think this is what makes it unique - not sure of anything). As I drive along the MSD EFI learns and remembers what I am asking of it. A EFI designed to regulate emissions and mpg does just that but it may sacrifice performance to achieve this. This is My suspicion of the Rover HotWire and GEMS system.
Button
Re: Air Intake improvements [Re: CooperMan] #595938
20/09/19 02:39 PM
20/09/19 02:39 PM
Colorado, USA
britmog Offline
britmog  Offline
Colorado, USA
Button: You are correct with the Hotwire ECU, however, if you replace the chip with a Tornado Chip you open up the system to be adaptive and learn. It makes a difference as long as you change the other components too allowing the engine to breath/fart and enjoy itself!!
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Air Intake improvements [Re: britmog] #595960
20/09/19 04:34 PM
20/09/19 04:34 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
Don't understand the "Tornado Chip" yet. But it must revise the MAP to something more suitable for a light Sports Car.
I have two modifications in My Mind to adapt My MSD TB EFI to insure it is supplied with cool, fresh air and not engine compartment air. 1. Build duct work from above the radiator to the big round carb type air filter. 2. Buy or fabricate a housing for the top of the MSD Unit and pipe it into the Rover Filter (sealing off the heat riser hole) and locate the Venturi Mouth just in front and above the rad. And then monitor the AIT Temp on the MSD handheld to ascertain how close this temp is to ambient temp.
Button
Re: Air Intake improvements [Re: CooperMan] #595983
20/09/19 06:54 PM
20/09/19 06:54 PM
Colorado, USA
britmog Offline
britmog  Offline
Colorado, USA
Button, you will find this interesting on re-chipping, etc.
http://www.v8engines.com/carbs-2.htm
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Air Intake improvements [Re: CooperMan] #596007
21/09/19 12:19 AM
21/09/19 12:19 AM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
Post an image by Button.
Here is My next to best remedy for the cold air caper. I will monitor My MSD Handheld and try to keep track of AIT (Air intake temp). I head for Flog Mog in Northern California tomorrow and will report enroute or when I get back to Seattle.
Re: Air Intake improvements [Re: CooperMan] #597423
30/09/19 12:29 PM
30/09/19 12:29 PM
Yorkshire
CooperMan Offline OP
Yorkshire
As the weather was so poor this weekend I decided I would finally add the side scoop to the Roadster airbox, this picks up air from the bonnet side louvers
Re: Air Intake improvements [Re: CooperMan] #597435
30/09/19 01:32 PM
30/09/19 01:32 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Neat, does it make a difference?
2006 Indigo Blue Roadster S1
Re: Air Intake improvements [Re: John V6] #597613
01/10/19 11:11 AM
01/10/19 11:11 AM
Yorkshire
Yorkshire
Not sure yet as the weather is awful oop north, the earlier front scoop & over engine hose feed, certainly help with engine temp
Re: Air Intake improvements [Re: Heinz] #597721
01/10/19 09:10 PM
01/10/19 09:10 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
2,500 miles. AIT 104F Eng temp 190F all + or - a bit. Ambient temp about 70F. Lots of rain to and from Northern Cal. Flog Mog dry and loads of fun. Tcherek was My Navigator.
Button
Re: Air Intake improvements [Re: CooperMan] #597731
01/10/19 11:53 PM
01/10/19 11:53 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
„I'm driving 2,500 miles on the side“... you're a hero, Button. BTW isn't such an exciting navigator at your side a much nicer experience than a conversation about hot air? thumbs
Moderated by  Aeroman, Simon
