15 registered members (RedThree, Bervie1, Chris99, SimonH, CooperMan, Peter J, Snowden, John V6, dmh, Camelot, LightSpeed, +8Rich, M3W55, Tresco, sprinty), 104 guests, and 15 spiders.
+8Rich 446
John V6 443
Hawki 169
by rainbowj. 04/07/20 09:14 AM
Panhard Conundrum
by Grumpy2. 03/07/20 08:11 PM
Morgan Bell End
by TBM. 03/07/20 03:37 PM
Travel restriction
by aerotaff. 03/07/20 01:57 PM
Wheel balance
by CooperMan. 03/07/20 01:17 PM
1934 Pedal car
by brownbaker. 03/07/20 12:36 PM
FOR SALE MINILITE 7X15
by Pemlar. 03/07/20 09:22 AM
Lots of Bread
My new Plus Four
Back from professional washing and waxing
A trip to Essex
Illuminated Morgan wings homemade
Sharpm, Wil, LouStar, J Mck, Per Mattsson
7039 Registered Users
Topics38,699
Posts635,840
Members7,039
Most Online1,033
Dec 28th, 2019
2211, Anders, Bayne
Re: Stuck rear brake? [Re: kar120c] #598284
06/10/19 07:26 AM
06/10/19 07:26 AM
Vspec Offline
Vspec  Offline
Sounds familiar, see my experience here:
http://www.talkmorgan.com/ubbthreads.php/ubb/showflat/Number/395315/Searchpage/7/Main/27043/Words/%2BBrake/Search/true/they-all-do-that-sir-rear-brake-cylinder#Post395315
Re: Stuck rear brake? [Re: kar120c] #598295
06/10/19 09:37 AM
06/10/19 09:37 AM
Aberdeenshire
TimG Offline
TimG  Offline
Aberdeenshire
Phil you could try giving the rear brake a hard whack with a rubber mallet to see if it will loosen any sticking shoes. At my recent service they found the piston in the cylinder for the trailing shoe had siezed though it still got an MOT with it. Its a frequent failure on Morgan rear brakes even with fluid changes. Parts £79 & 2 hours labour to remove, clean, replace cylinder & refit.
Re: Stuck rear brake? [Re: kar120c] #598304
06/10/19 11:23 AM
06/10/19 11:23 AM
Port Orchard, WA.
LightSpeed Online content
LightSpeed  Online Content
Port Orchard, WA.
Are there better alternate cylinders available from a different manufacturer?
Stephen
2019 M3W piling on the Covid miles
Re: Stuck rear brake? [Re: LightSpeed] #598305
06/10/19 11:32 AM
06/10/19 11:32 AM
Devonshire
+8Rich Online content
+8Rich  Online Content
Devonshire
Not as far as I know but some people get the cylinders lined with stainless steel which resolves the issue permanently, a few people on TM have had this done on trads.
Regards Richard
1994 Connaught Green +8 prev
Re: Stuck rear brake? [Re: LightSpeed] #598316
06/10/19 01:16 PM
06/10/19 01:16 PM
Leicestershire, UK
Bunny Offline
Bunny  Offline
Leicestershire, UK
The problem with these cylinders is corrosion. If you peel back the rubber gaitor and smear a little 'Red Rubber' grease around the bore then the cylinder will probably last indefinately.
If the cylinder is too far gone, you can have it reworked with a stainless steel liner but this will cost significantly more than replacing it with a new item. PastParts in Bury St Edmunds can do the re-sleeving.
Andy
Re: Stuck rear brake? [Re: kar120c] #598331
06/10/19 02:37 PM
06/10/19 02:37 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
Planenut: Could you advise on the procedure for bleeding the clutch, I have located the "black nut" but can't see a bleed nipple?
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Stuck rear brake? [Re: britmog] #598338
06/10/19 04:19 PM
06/10/19 04:19 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
Not all the M3W's are the same as some have a Volvo internal clutch slave cylinder but the parts manual shows an external (Mazda?) type as well. I have the internal one and it's the only type I have seen. On my car the clutch bleed nipple is on a black plastic fitting on the top of the gearbox bellhousing, directly below the oil tank, it has a braided supply hose and a bleed nipple connected to the fitting. Be very careful with the plastic fitting, you don't want to damage it as it is an engine out job to replace it. Just bleed the clutch in the same way as you would bleed the brakes. I use an Ezibleed kit connected to the reservoir and change the clutch and brake fluid at the same time. The clutch fluid gets surprisingly black and dirty looking, even though it gets changed every other year.
Re: Stuck rear brake? [Re: kar120c] #598343
06/10/19 04:51 PM
06/10/19 04:51 PM
Leicestershire, UK
Bunny Offline
Bunny  Offline
Leicestershire, UK
The only thing I would add to that is that the bleed nipple (on mine anyway) needs to be undone a surprising amount before it will let the fluid through.
Also, space is limited under the oil tank so I hack sawed off an old 11mm spanner to make it 70mm long. Much easier to turn!
Andy
Re: Stuck rear brake? [Re: kar120c] #598453
07/10/19 02:06 PM
07/10/19 02:06 PM
britmog Offline
britmog  Offline
Thanks, will have another look.
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Moderated by  Aeroman
