17 registered members (Bluesman, DaveW, lord-richfield, DickJ, DaveK, Themorganeer, madmax, Esprit, Richard Wood, Jeff D, TBM, IcePack, M3W55, Image, sbarracl, Ivo, Heinz), 198 guests, and 15 spiders.
+8Rich 230
John V6 163
Peter J 128
Hamwich 127
New wheel option for Roadster
by Richard Wood. 26/02/20 05:44 PM
Radiator Leak
by PaulyG. 26/02/20 05:18 PM
Rear turn signals/brake light
by kankeL. 26/02/20 02:49 PM
Which fuel injection pressure gauge
by Ricardo. 26/02/20 09:43 AM
Man maths at its finest..2012 M3W advice
by NickCW. 25/02/20 08:53 PM
Minikeefy Contact?
by Nostalgiajohn. 25/02/20 08:08 PM
Just what makes a sports car?
by Gambalunga. 25/02/20 06:30 PM
Velsheda at Croabh
A day out at Ipswich docks
Garage art
near eccleston VA
FolkMog lunch
Tipracer, George Okuda, Alice, ahdguy, Colin725
6829 Registered Users
Topics37,333
Posts606,775
Members6,829
Most Online1,033
Dec 28th, 2019
Ian Wegg
Front number plate - a warning ! #598729
09/10/19 04:39 PM
09/10/19 04:39 PM
Cheshire, UK
nippymog Offline OP
nippymog  Offline OP
Cheshire, UK
Went for the mogs annual MOT today and got an MOT warning ( i.e. fix it for next time ) off the tester that it should really have a front number plate as its a class 4.
In class 4 number plates are mandatory.
It cant be a class 3 where front plates are exempt because its too heavy - i.e. over 500KG.
Now genuinely thought it was a class three, so I fished out the V5 doc which I happened to have with me showing this.
The V5 also shows its operational weight at 550, so class 4.
Now I know this is old ground discussed long ago. I only raise it as I removed the front number plate early on as I think it looks better without, and have had three previous pass tests, at the same test station, all without the plate.
The only difference this time was there was a new tester, a youngish chap ( clearly keen), while the old hand was on holiday.
So my take is it is down to the inspector's discretion how to interpret this.
He did say while he expected it to be on next year, it's up to the owner what they do with the car once it's driven off(obviously).
My interpretation is I take it next year, with some tie wraps and see what happens!
Re: Front number plate - a warning ! [Re: nippymog] #598736
09/10/19 05:34 PM
09/10/19 05:34 PM
East Sussex, ENGLAND
andymot Offline
andymot  Offline
"Three-wheeled vehicles that do not have a body type which is characteristic of the body of a four-wheeled vehicle do not require a front number plate. All other vehicles, including quadricycles, must be fitted with front and rear registration plates, which must both be checked to ensure the registration number displayed is the same."
I quote the above from the testers manual for class 4 vehicles - which is correct for the Morgan 3 wheeler. Writing as an MOT tester and centre manager I'd conclude that in fact you do not need a front plate on your Morgan 3 wheeler. Nippymog is correct about it being how the tester interprets this. To me its clear - not required, I'd not want to suggest that the tester reads the manual as it may offend, but clearly it would be a good idea! Biggest mistake all testers make - young and old - is to assume they know what the manual says.
Re: Front number plate - a warning ! [Re: nippymog] #598741
09/10/19 05:50 PM
09/10/19 05:50 PM
Gods own county! Oop north
Dab of oppo Offline
Dab of oppo  Offline
As per Andymot, it all depends on the tester on the day.
Mine thankfully has years of experience and lots of common sense.
Re: Front number plate - a warning ! [Re: nippymog] #598772
09/10/19 10:44 PM
09/10/19 10:44 PM
East Harling, Norfolk UK
Richard Wood Online NoMood
During my M3W ownership I checked up when this subject was last under discussion. This is an excerpt from DVLA V796 concerning vehicle registration plates.
There are separate provisions for motorcycles and tricycles. Basically motorcycles registered after 1.9.2001 must only display a number plate at the rear of the vehicle. Motorcycles registered before 1.9.2001 can display a number plate at the front but are not required to. Tricycles derived from four wheeled bodies i.e. saloon cars must meet the normal requirements above whereas tricycles derived from motorcycles must meet the requirements for motorcycles.
Whilst the wording is clumsy I've seen reference elsewhere the definition refers to tricycles with enclosed bodywork and steering wheel.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Re: Front number plate - a warning ! [Re: Richard Wood] #598803
10/10/19 08:15 AM
10/10/19 08:15 AM
Cheshire, UK
nippymog Offline OP
nippymog  Offline OP
Cheshire, UK
While that is true and still current, unfortunately, it doesn't cross-reference to the MOT class system, so in the mind of the MOT tester doubt will still exist.
I think a link between the two would solve this.
This is a link to the current V796 document, which includes your quote :
https://assets.publishing.service.g...ion-numbers-and_number-plates-inf104.pdf
Re: Front number plate - a warning ! [Re: nippymog] #598810
10/10/19 08:33 AM
10/10/19 08:33 AM
Aberdeenshire
TimG Offline
TimG  Offline
Aberdeenshire
I had a Piaggio MP3 scooter with 2 close coupled front wheels, in the V5 it said bicycle but an MOT bike tester refused as he said they did not test tricyles. Took it elsewhere, so interpretation of the rules can vary. Piaggio produced a version with wider track & a foot operated brake so it could be ridden on a car licence.
Re: Front number plate - a warning ! [Re: nippymog] #598855
10/10/19 01:41 PM
10/10/19 01:41 PM
Hants
andyjazz Offline
andyjazz  Offline
Hants
Perhaps the interpretation of "derived from four-wheeled bodies" means that if you sit IN it rather than ON it the requirement is that you sport a front numberplate..?
2017 MTW Graphite Blue
Re: Front number plate - a warning ! [Re: nippymog] #598857
10/10/19 01:50 PM
10/10/19 01:50 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
However, the M3W is derived from a 1930's design Three Wheeler.
I run without a front number plate but do put one on for the MOT just to avoid any issues.
Red Leader drive
Re: Front number plate - a warning ! [Re: Chris99] #598861
10/10/19 02:07 PM
10/10/19 02:07 PM
Furry Boots City
RedThree Offline
RedThree  Offline
Furry Boots City
+1 same for me though thinking about it, the number plate was in my garage, about 100 miles from the car during its last MOT!
Two screws for the mounting plate then Velcro to hold the number plate itself on.
Moderated by  Aeroman
