18 registered members (RicHardy, chriswarren, JohnHarris, Brian G, Richard Wood, TBM, Heinz, AlyMatt, RedThree, BigSteve, bmgermany, Ray, mph, DaveW, teifistar, RJW, wigmog, Phil4/4), 182 guests, and 16 spiders.
John V6 374
+8Rich 214
TBM 153
Front suspension lubrication questions
by thelastgizmo. 25/10/20 07:46 PM
Half shaft problem and BTR axle.
by FrancisD. 25/10/20 05:48 PM
Fuel Tank Capacity. Again
by IvorMog. 25/10/20 04:55 PM
the definition of a classic sports car
by howard. 25/10/20 04:14 PM
Plastic steering column shroud
by SAE. 25/10/20 03:18 PM
My new Plus 8
by Gambalunga. 25/10/20 02:36 PM
OBD pinouts, wiring etc
by Cumbriankeith. 25/10/20 10:33 AM
Definition of a classic sports car
Another Lancastrian
For Sale: Luggage rack & front bumper
Malvern Show 2
Malvern Show 1
LOLO 04, sss6000, Dylan614, kbac, Gwyn D
7205 Registered Users
Topics39,673
Posts656,184
Members7,205
Most Online1,033
Dec 28th, 2019
Iancarey
Re: A Better Afternoon [Re: Fat Wolfie] #598850
10/10/19 01:21 PM
10/10/19 01:21 PM
North of Stamford, UK
HeadlessBlue Offline
Well done FW!!!!
I bet you have a huge sense of achievement 👍😆 and well deserved (wish I was as practical)
HB
Mogless, but prev 2019 P4 - “Florence”
2020 Tesla Model 3 AWD LR - “Ernie”
2016 A3 S Line
Re: A Better Afternoon [Re: Fat Wolfie] #599019
11/10/19 07:58 PM
11/10/19 07:58 PM
Chelmsford, UK
John190 Offline
John190  Offline
Chelmsford, UK
How easy it will be to get back on if I need to get to the spare I don’t know, I might check that out some time but not today.
I'm sure someone will correct me if I'm wrong but........if the spare wheel is needed, the central spindle should be removed and then the whole rack should hinge rearwards, away from the car and access to the spare is gained?? Bit awkward if actually being used for luggage!!
John W
2000 4/4 Indigo Blue
Re: A Better Afternoon [Re: Fat Wolfie] #599034
11/10/19 10:50 PM
11/10/19 10:50 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
Yes, that is correct. If you need to use the spare wheel then removing the small amount of luggage is a minor inconvenience!
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Re: A Better Afternoon [Re: John190] #599049
12/10/19 07:43 AM
12/10/19 07:43 AM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
Where are the hinges? Looking at your photos it looks just like mine. To get to the spare wheel, remove the spindle then lift the whole rack off its mounting pegs.
Inconvenient maybe but the least of your worries. Wait till you have to jack it up on the roadside to change wheels! This summer, I went to assist a fellow Morganeer with a wheel change and despite having the standard tool kit to hand, I found that he had secured his spare wheel against theft with a hefty bicycle wire whip and padlock. The lock was so corroded it would not release and the whip was too thick to cut without bolt croppers. So the AA had to be called. (Obviously, whoever does his annual service, does not bother to remove the wheel for inspection underneath!)
To put things in perspective, the chances that you will ever get a puncture are slim anyway.
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: A Better Afternoon [Re: Fat Wolfie] #599059
12/10/19 09:54 AM
12/10/19 09:54 AM
West Yorkshire
Fat Wolfie Offline OP
West Yorkshire
Yes, the rack is one that slides onto pins on the bumper mounting bracket then screws in through the spare wheel spindle.
My fear/worry isn’t so much having to take luggage off the rack to access the spare wheel, but how much tension the rack might be under which might make putting the spindle back through the spare wheel a bit tricky. (I don’t think it’s under that much tension but no doubt any puncture will be in the dark and rain, so ideal conditions to find out really innocent)
On a slightly different note, the “bad morning” thread also mentioned difficulties I was having greasing the king pins due to lack of axle stands etc.
This morning I went down to my friendly neighbourhood garage as arranged, to use their ramp and do the job myself. (I just need to see the guy “right” at Christmas...)
Car on ramp, no problem, access to nipples, no problem. Did one side then grease gun (Wanner with flexible attachment) decided it had run out of grease doh .
I literally live 100 yards away so walked home, refilled the gun, and finished the job. Having spoken to two different people who were passing the garage and wanted to know about the Morgan, adding a good 10 minutes to the job!
But the best thing of all is that despite the issues in doing these simple jobs, I do feel a real sense of achievement and have despite grumbling really enjoyed fettling the car.
Next on the list is a trolley jack and axle stands - I am welcome to use the ramp at any time but I don’t like to impose....plus the garage isn’t open Saturday pm or Sundays..
Re: A Better Afternoon [Re: Fat Wolfie] #599077
12/10/19 12:15 PM
12/10/19 12:15 PM
I
IcePack Offline
IcePack  Offline
I
Re the luggage rack. Be very careful lifting it off/on. A well known Morgan garage managed to damage the rear panel on my 4/4. Which required a full panel re-spray.
4/4 Ivory 4.1:1 axle, Jaguar XE R-Sport.
Re: A Better Afternoon [Re: Fat Wolfie] #599078
12/10/19 12:21 PM
12/10/19 12:21 PM
West Yorkshire
West Yorkshire
Good tip @ice pack, thanks
Hope your car has been fixed satisfactorily, very annoying for you
Re: A Better Afternoon [Re: Fat Wolfie] #599105
12/10/19 06:26 PM
12/10/19 06:26 PM
Well done (again FW)! Took a look at that link you provided on another thread-I think I recognised a lot of the roads the chap was driving his French cars on - they are all local. He seemed like a decent chap with quite a relaxed presenting style- thanks for posting (he does like his 2CVs doesn’t he)....
HB
2016 A3 S Line
Re: A Better Afternoon [Re: HeadlessBlue] #599109
12/10/19 06:53 PM
12/10/19 06:53 PM
West Yorkshire
West Yorkshire
Yes, I think he has a genuine enthusiasm for the mediocre :-)
The Project Invacar set is also pretty interesting
Trouble is watching his channel has rekindled a desire to have a 2CV in the stable.....but SWMBO isn’t keen as we have no more garage space. What she doesn’t know is I have feelers out for a lock up to rent in the local area. sherlock
Then once that’s rented I can move onto the next stage of acquisition (or divorce, depends how it goes rofl)
Hope the recovery is going well thumbs
Re: A Better Afternoon [Re: Fat Wolfie] #599284
14/10/19 08:38 AM
14/10/19 08:38 AM
Thanks FW. Chum of mine has acquired a v old 2CV over the last 12 months. Took some persuading of his Swmbo but he got there eventually.
One day I’m sure they will talk to each other again.... 🤣
Pain level reducing ta but feels like bit of a nerve trapped/being rubbed on by the plaster at certain angles. Could be a lot worse of course though 👍
Hope you find a lock up !!!
Will look elsewhere on TM to see if you watched the Morgan thingy with Christopher Timothy on Saturday -I guess that was somewhere near your patch....
Ciao for now old chap
HB
2016 A3 S Line
Moderated by  Aeroman, Simon
