24 registered members (PaulV, LightSpeed, bilibib, Sportster, Ian Wegg, MDS61, ChrisP, Phil4/4, Fuel.inj, HalfFull, bmgermany, marshalben, Gerhard, David_E, madmax, Themorganeer, Spanner Juggler, AZJowett, Heinz, RedThree, Paul F, M3W55, Ruut Bianchi, Robbie Mathisen), 166 guests, and 13 spiders.
+8Rich 438
John V6 432
TBM 235
Heinz 189
One in a million catch.
by Sportster. 06/06/20 09:30 PM
F1 Quiz
by hugo. 06/06/20 07:30 PM
Homemade Side Screen bag
by MartinNico. 06/06/20 12:43 PM
First trip, first break down
by Marmota. 06/06/20 12:24 PM
Fabulous Aeromax
by +8Rich. 06/06/20 08:29 AM
Sidescreens for 96 +4 2 seater
by Mogdriver. 06/06/20 08:07 AM
Steeriing gaiter split
by Mats. 06/06/20 07:38 AM
Drive out before the rain
Hard Top Badge
Glove box net
sump/crossmember guard
The great escape
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,433
Posts630,060
Members6,938
Most Online1,033
Dec 28th, 2019
DaveK, James Nolan
Page 1 of 4 1 2 3 4
Advice sought re "1 shot lubrication" system #599192
13/10/19 01:45 PM
13/10/19 01:45 PM
CarMart Offline OP
CarMart  Offline OP
Hi
As a recent purchaser of a 1989 Plus Four I'm a bit confused by the conflicting advice I've been given about front suspension lubrication. My car still has the 1 shot lubrication system fitted and the handbook recommends operating this every 200 miles; as well as greasing periodically (because the grease 'helps to retain the oil'?).
Some owners I've spoken to advocate this approach. But several have been vehemently opposed to using the one shot oiler at all; and say it's unnecessary as long as suspension is regularly greased via grease nipple.
What do others think? I'm erring towards the greasing only approach. The Gomog site suggests this is done every 1500 miles?
Views welcomed; and apologies if this debate has been done to death elsewhere!
Martin
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599196
13/10/19 02:00 PM
13/10/19 02:00 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
After doing lots of reading, I removed my system. Fitted grease nipples to the top of the kingpins (although never use them at the top, it's just to keep the crap out) and blanking plugs at the outlets at the 'plunger', Tend to grease the lowers about every 500 miles.
Eventually I'll remove the plunger completely and run a reinforced braided hose from the engine to oil pressure sender.
1972 4/4 4 seater
Too many ratty motorbikes
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599197
13/10/19 02:02 PM
13/10/19 02:02 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
Most of the fittings are 1/8 BSP
1972 4/4 4 seater
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599199
13/10/19 02:05 PM
13/10/19 02:05 PM
East Harling, Norfolk UK
Richard Wood Offline
Having read many opinions on front suspension greasing I chose every 1000 mile or so. I was finding the electric steering motor whining though as I approached this interval. Fresh grease cured this, suggesting the steering was stiffening up a tad prior. Now greasing at 700 mile intervals.
FWIW zero wear found on kingpins after 8000+ miles from new during recent strip down to fit SSL kit, so I can't be doing too much wrong.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599200
13/10/19 02:05 PM
13/10/19 02:05 PM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
IF you use the one-shot oiler, only do it on a cold start - warm/hot oil can wash the grease out.
Grease at a maximum of around 1000 miles. I usually do it earlier.
Like Phil I have removed the oiler pipes and replaced with grease nipples on top of the king pins.
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Re: Advice sought re "1 shot lubrication" system [Re: Richard Wood] #599204
13/10/19 02:42 PM
13/10/19 02:42 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
This is very interesting and something I had not heard of in the past. On all 3 of My Morgans the One Shot Oiler has been removed for almost 20 years. GOMOG has the best write up IMO.
Button
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599209
13/10/19 03:44 PM
13/10/19 03:44 PM
Devon
Moggo Offline
Moggo  Offline
Devon
I use copious quantities of grease at 500 mile intervals to both top and bottom nipples, until grease emerges from the bottom thrust bearing, being careful to wipe away excess spill before and after. At 28,000 miles I changed the pillars for chromed hard ones which have now reached over 40,000 miles in service with NO discernable signs of wear.
By greasing often I feel the steering is very much improved. My assumption is that this is because the caster angle is quite small and requires friction here to be minimal. I don't know if this makes sense but the more mechanically minded will hopefully shed more light on the subject.
Graham
1.8 4/4 Ivory.
Toyota Yarris
Volvo V70
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599211
13/10/19 03:52 PM
13/10/19 03:52 PM
Derby
PhilRoyle Offline
PhilRoyle  Offline
Derby
I grease every 1000 miles - I have hard chrome kingpins and phosphor bronze bushes. No problems so far.
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599214
13/10/19 04:40 PM
13/10/19 04:40 PM
It will also extend kingpin life if you if you fit a form of gaiter to the lower, rebound, spring. Keep the worst of the road crud out which can cause faster wear...
'07 MINI Cooper
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599243
13/10/19 07:43 PM
13/10/19 07:43 PM
South Yorkshire
Tonyh157 Offline
Tonyh157  Offline
South Yorkshire
I’m glad someone else is confused! I’ve a 94 plus 4 and I too am unsure how and to lubricate the front suspension. I like the sound of getting rid of the oiler and reverting to grease nipples. My question is whether anyone does a kit to enable the swop including nipples, braided hoses etc? Instructions would also help!
Tony
1994 Connaught Green plus 4
Page 1 of 4 1 2 3 4
Moderated by  Aeroman, Simon
