19 registered members (Bitsobrits, TV5R, Spanner Juggler, RJW, Krod, simonjrw, Ragnar, LightSpeed, Image, Hamwich, M3W55, Paul F, Jens, Sinbad, John Winn, Jacques, auster, Richard Wood, kar120c), 351 guests, and 108 spiders.
+8Rich 260
Peter J 126
John V6 123
Hamwich 108
Location
by Nostalgiajohn. 24/01/20 04:48 PM
The French want their words back!
by Gambalunga. 24/01/20 03:43 PM
ARP4 Info urgently needed
by NeilPom. 24/01/20 10:23 AM
How to sell my M3W?
by Chris M3W. 23/01/20 06:03 PM
Bonnet Stays & Qtr Panel Protectors
by Nostalgiajohn. 23/01/20 03:33 PM
Replace Hazard switch
by Anthony4/4. 23/01/20 03:13 PM
WA13FWY - does anyone know this car?
by jackmorini. 23/01/20 12:07 PM
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
Bevel box oil leak
Hogmanay Run
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,070
Posts601,514
Members6,812
Most Online1,033
Dec 28th, 2019
No Birthdays
Re: What a morning! [Re: Fat Wolfie] #599159
13/10/19 08:05 AM
13/10/19 08:05 AM
East Harling, Norfolk UK
Richard Wood Online NoMood
Originally Posted by Fat Wolfie
........First mini frustration was removing the over riders from the fixings. Having established the right sized socket, I then found there wasn’t enough room for my ratchet lever to fit, so back to the tool box and used a suitable open ended spanner.
However they are still fixed at the bottom by a cross head screw. After much faffing around I found the right sized screwdriver head and then found the screwdriver handle was not working, a ratchet style handle that now seems to only want to screw things in and will just spin in the “lock” or “undo” position. More ferreting around found a suitable substitute handle and the over riders came off.
Those lower rear overrider screws are described as socket button M6 x 20 in the parts manual. It seems in recent years MMC have been fitting cross head screws though, requiring very short screwdriver, so poor purchase. When I finally got mine off I replaced with stainless socket button screws allowing simple removal with allen key.
2018 Roadster - Red/Magnolia - "Morton"
1967 Land Rover series 2a SWB
1960 Velocette Venom
Re: What a morning! [Re: Richard Wood] #599164
13/10/19 08:30 AM
13/10/19 08:30 AM
West Yorkshire
Fat Wolfie Offline OP
West Yorkshire
That’s a good idea Richard. Might do the same..
Re: What a morning! [Re: Richard Wood] #599189
13/10/19 01:12 PM
13/10/19 01:12 PM
Costock, South Nottinghamshire...
Paul F Online happy
Paul F  Online Happy
I managed to remove mine by jacking the car up (and placing it on axle stands). I could then use an impact driver which required very little force. Now replaced with stainless socket screws.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: What a morning! [Re: Paul F] #599237
13/10/19 07:28 PM
13/10/19 07:28 PM
Cheshire
Themorganeer Offline
Cheshire
This is exactly how I replaced the overrider screws. Without an impact driver those screws were stuck fast and going nowhere! Stainless sockets from Screwfix / Toolstation.
Chris
2015 Plus4
Re: What a morning! [Re: Fat Wolfie] #599283
14/10/19 08:36 AM
14/10/19 08:36 AM
Just to continue this slight thread drift. I purchased both metric and imperial 1/4" square drive Allen (hex) key sets. Ball end versions are available that work at modest angles. These are particularly useful where an access hole is not aligned with the bolt head. I'm thinking of course of the overrider lower screw innocent
Either type make work on socket head bolts so much easier though.
Re: What a morning! [Re: Felix42] #599436
15/10/19 08:41 AM
15/10/19 08:41 AM
Hill Head, Hampshire, Uk
Frank 4x4 Offline
Green & Grown Up
Frank 4x4  Offline
Green & Grown Up
Originally Posted by Felix42
Remote greasing kit is extremely helpful:
https://www.wolfperformance.co.uk/remote-greasing.html
Highly recommended. - Fitted mine before my Coast Road Trip and with Greasing every three days, wherever, it was a doddle to do.
And with Dave W's Bump Spring Gaiters fitted, just a quick check & occasional wipe around the base edge and Job Done.
Moderated by  Aeroman, Simon
