18 registered members (Peter J, Robbie, AndyrIch, KEVFITZ, Neptune, RoyH, MOG 615, Sir Percival, Ian Wegg, westgardronning, Arwyn Williams, JMcL, RJW, Rovert, flyfisher, Mikealpha, brownbaker, PaulV), 100 guests, and 15 spiders.
John V6 443
+8Rich 422
Hawki 180
Another Auction
by Treesurveyor. 05/07/20 10:31 PM
Statues - worth a read
by recycled-teenager. 05/07/20 05:36 PM
Bought a couple of new Morgans..
by NickCW. 05/07/20 04:02 PM
Trivia
by nick w. 05/07/20 02:23 PM
Alternaive to Morgan..?
by Luddite. 05/07/20 11:40 AM
Immobiliser key fob code
by planenut. 05/07/20 10:31 AM
Ferrari Monaco recently
by ewn. 05/07/20 06:08 AM
Lots of Bread
My new Plus Four
Back from professional washing and waxing
A trip to Essex
Illuminated Morgan wings homemade
Sharpm, Wil, LouStar, J Mck, Per Mattsson
7039 Registered Users
Topics38,714
Posts636,188
Members7,039
Most Online1,033
Dec 28th, 2019
RonB
Page 3 of 4 1 2 3 4
Re: Advice sought re "1 shot lubrication" system [Re: +8Rich] #599589
16/10/19 08:04 AM
16/10/19 08:04 AM
North of Stamford, UK
HeadlessBlue Offline
+1 re Mr Button - v touching story and I echo Rich’s sentiment
HB
2019 110 Plus 4 - “Florence”
2020 Tesla Model 3 AWD LR - “Ernie”
2016 A3 S Line
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599590
16/10/19 08:21 AM
16/10/19 08:21 AM
auckland new zealand
waikiore Offline
waikiore  Offline
Though relatively new to this Morgan maintenance lark compared to some of you I believe that the factory fitted push button oiler and grease at lower can work fine if operated how Morgan advise, and I am aware that our local Morgan restoration man with many years of experience concurs.
If I was to change the kingpins in the future I am quite keen on trying 2205 pins with Vesconite bushes as I have lots of experience with this combination in aggressive marine situations.
99 plus 8 indigo
Re: Advice sought re "1 shot lubrication" system [Re: Button] #599606
16/10/19 11:13 AM
16/10/19 11:13 AM
Sunderland Uk
pickles Offline
pickles  Offline
Sunderland Uk
Hi always look for your input to the many posts I read.enjoy your engineers outlook to problems and positive outlook to life .A star.
Ha way the lads.Richard
Re: Advice sought re "1 shot lubrication" system [Re: waikiore] #599623
16/10/19 01:54 PM
16/10/19 01:54 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
I have used Vesconite and Chrome KP's for many years. The idea of Vesconite came from a Australian Mining Engineer.
Button
Re: Advice sought re "1 shot lubrication" system [Re: Button] #599685
16/10/19 08:29 PM
16/10/19 08:29 PM
Renfrewshire
BobtheTrain Offline
BobtheTrain  Offline
Renfrewshire
I thought it was from an American from Vesconsin.
Best Regards
Lang may yer lum reek
Re: Advice sought re "1 shot lubrication" system [Re: BobtheTrain] #599689
16/10/19 09:53 PM
16/10/19 09:53 PM
Seattle, USA
Button Offline
Button  Offline
Seattle, USA
No that was the Model T from Wishigan
Button
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599697
16/10/19 10:52 PM
16/10/19 10:52 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
Oh no! I Canuck take any more of these silly puns.
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599804
17/10/19 06:19 PM
17/10/19 06:19 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
I had the one-shot on my first car....1993.
If I was going to keep the car I would have removed it.
My current car has grease system and I grease at 1000 miles MAX intervals. If away on a weekender I grease again, irrespective of mileage lapse. I have hard chrome kingpins and done 30k+ miles and no signs of wear when doing the wheel shake test. When greasing I lever up the bronze plate and grease until some comes out from the gap,a tip from Phil at Allon White when buying my first Mog fromhim. A pneumatic greaser makes it easier.
Grease is cheap and greasing allows a quick check on the underside/hubs etc..
Just to add that the rear leaf springs should be treated too. The consensus is to spray chain lube on them as it penetrates between the leaves. Not as frequent as the front but about 4/6 times a year (7k+ annual mileage).
Red Plus8
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599854
18/10/19 01:21 AM
18/10/19 01:21 AM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
For what it is worth I removed the one shot oiler on both my 64 4/4 and 94 +8, why: because the oil can wash out the grease and does not actually do any real lubrication of the system. Also as happened in my +8 if you get a leak in the system you can rapidly lose oil (as its under pressure when engine running) which is not good for engine!!! Unless you have new Kingpins or have drilled out the old ones it is no use putting grease nipples in the top as the grease will not go down the pin. Just grease from the bottom every 1000 miles or seasonal oil change whichever is sooner, use gaiters too. On my 94 +8 I have over 75,000 miles and very little play in the original Kingpins.
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Advice sought re "1 shot lubrication" system [Re: CarMart] #599869
18/10/19 07:44 AM
18/10/19 07:44 AM
Bergen, Norway
Robbie Mathisen Offline
Bergen, Norway
Seems to be consensus that the one shot oiler is not very important (or unimportant) and can even be harmful if the oil is hot. And according to the gurus, fitting a grease nipple to the top of the KP is useless because the channel drilled down the KP is so thin that it doesn't permit grease to penetrate, just oil. So if one doesn't want to use the one shot oiler system, why can't one do just that? What is the purpose of dismantling the system as long as one keeps the KPs unchanged?
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Page 3 of 4 1 2 3 4
Moderated by  Aeroman, Simon
