Morgan Aero 8
16 registered members (marshalben, Roady, Philippo, yobtaf, Chris Shilton, KennethM, Mikel, Robbie, Landy, TBM, Wirewheel, Rovert, RJW, Heinz, The Austrian, Morph), 170 guests, and 20 spiders.
John V6 419
+8Rich 419
TBM 235
Heinz 195
vdo speedo
by milliemollie. 05/06/20 12:50 PM
Interesting new hardtop
by +8Rich. 05/06/20 12:43 PM
the classic / collectors car market
by howard. 05/06/20 09:53 AM
ebay made me chuckle
by Grumpy2. 05/06/20 08:50 AM
How many grease nipples
by Philippo. 04/06/20 07:28 PM
Bressingham Steam Museum
by Graham, G4FUJ. 04/06/20 07:19 PM
Tank Man Tianaman square
by madmax. 04/06/20 04:19 PM
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
Are There Any Keen Car Badge Collectors out there
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,420
Posts629,730
Members6,938
Most Online1,033
Dec 28th, 2019
Oldbill
Structural Failures #600299
21/10/19 04:18 PM
21/10/19 04:18 PM
Salisbury, UK
Peter J Offline OP
Formerly known as Aldermog
Peter J  Offline OP
Salisbury, UK
I took Tarka in to Williams Morgan today for the annual service and some other, suspension related work"
1. New front uprights, only £600 or so easy, plus VAT - better than the original quoted price of £900 VAT each.
2. New front coil over units from SSL
3. New rear coil over units from SSL.
To fit the front suspension parts the front cowl, bonnet and both wings have to come off: I hung about and watched Stewart start to take things off.
This was the first surprise:
It is the alloy bracket that holds the front of the bonnet hinge to the bulkhead. The downward sloping upper part shouldn't be there.it should continue up to a flat plate that picks up the front of the bonnet. ...
It has snapped clean off.
The we found this:
The plates that are bonded to the inside of the front wing and which then hold the bottom edge of the wing to the chassis had failed: they had separated away from the bonding material, two on each wing and on both sides.
So the wings were not secured at the front in any meaningful way.
Tarka was built in the summer of 2013 and has run some 41,500 miles. The metal to metal adhesive has failed. The question is what was the root cause? Did the fractured upper bracket cause the adhesive to fail, or the reverse.
It is all fixable, but the failure of the adhesive is a bit of a worry, given the car is essentially glued together.....
It will be interesting to see what else comes to light!
Tarka the 'Otter Mog
2014 Plus 8
Re: Structural Failures [Re: Peter J] #600305
21/10/19 04:40 PM
21/10/19 04:40 PM
Co Wexford, Ireland
Robbie Online content
Robbie  Online Content
Co Wexford, Ireland
Sorry to see your woes, Peter. However, just as well they have been found as not fixing them could have made matters much worse. The thought of the bonnets flying up at the front and the following accident is ahorrible thought. No doubt the Williams boys will soon have Tarka back in fine fettle!
Robbie
2018 Plus4 - Snoopy
181-WX-3082
Re: Structural Failures [Re: Peter J] #600308
21/10/19 05:50 PM
21/10/19 05:50 PM
Newcastle Upon Tyne
James B W Offline
James B W  Offline
Newcastle Upon Tyne
quite surprised at the first bracket 'fail' Peter and ,like you I would be concerned as to the cause and possible future issues.It looks to be fairly heavy duty already confused2
In regard to the lower wing ,bonded plates - I have had this on my Aero, several times now sadly doh
Mark (Middleton) who does the servicing always checks them as they seem to be a regular problem.He generally uses 'Araldite' or similar to re-bond any that have come loose.
I made up a new top bracket for the N/S headlamp unit ( as the N/S unit does not have one as standard?) , which I had to bond to the underside of the wing.
After much head scratching I decided on JB-Weld / Marine Weld (which is the waterproof version).
Touch wood, it seems to have held up.......
James
Range Rover Evoque S
Smart Brabus Convertible
Re: Structural Failures [Re: Peter J] #600324
21/10/19 07:19 PM
21/10/19 07:19 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
The adhesive that SHOULD be used in the initial bonding during chassis build is not ordinary stuff. It is a stronger and more expensive adhesive than general off the shelf stuff. Typical variants are used in aerospace builds so you can imagine the requirements for the whole prep/application/curing process. Remember the Spaceshuttle tiles...
Your move to JB weld is better than ordinary Araldite though.
I have an aluminium rad and the top steadying bracket failed. It was welded to the top tank and the weld cracked and eventually fully failed. No leaks. The cause was a mis-alignment of the bracket to it’s mounting point on the cross brace bar, resulting in side strain putting stress into the weld. I used JB Weld to stick it back after thorough cleaning/prep plus elongated the mounting hole to re-align the fixing.but it started to separate again, obviously still causing a pull and vibration combination. I did look for the better adhesives but saw the ££££ ! I then made a replacement bracket to fit over the tank with padding to replace the original. This new one is not fixed to the rad but bends over the top and so no undue stress/strain imparted. It steadies the rad well.
Out of curiosity, do the dealers have these “super adhesives” available to do repairs?
Red Plus8
Re: Structural Failures [Re: Peter J] #600327
21/10/19 07:31 PM
21/10/19 07:31 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
PeterJ....looking closer at your pic of the broken bracket there seems to be some weld spatter on the top and the inner wing?
Has someone tried welding the bracket after early signs of impending failure/cracks? If so then has the metal been affected by heat?
The hole at the top of the bracket looks odd too. Possibly a crack initiated there and subsequently grew due to stresses. The fracture surface looks odd with a “line” running along it suggesting crack propagation and then sudden fracture. Two separate surfaces either side of the “line”.
Red Plus8
Re: Structural Failures [Re: Peter J] #600344
21/10/19 09:07 PM
21/10/19 09:07 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
I would not be too worried about the tub itself Peter. The ancillary parts are no doubt bonded on at the factory under less than ideal conditions whereas the tub is bonded together under much more controlled conditions and, if I recall correctly, baked in a hot chamber to cure the adhesive. It works for aircraft so it should be fine on Tarka smile
Re: Structural Failures [Re: Peter J] #600348
21/10/19 09:22 PM
21/10/19 09:22 PM
Northamptonshire UK
Stringers Best Mate Offline
Northamptonshire UK
I'm a bit shocked and surprised to read this, Peter.
I know Williams will sort you, but keep us in the loop if you can, please..
Re: Structural Failures [Re: Peter J] #600359
22/10/19 05:27 AM
22/10/19 05:27 AM
Taunton
deano Offline
deano  Offline
Taunton
Keep us in touch with the progress Peter.
Martin (Deano)
Re: Structural Failures [Re: sospan] #600372
22/10/19 07:21 AM
22/10/19 07:21 AM
howard Offline
howard  Offline
I can see what you are getting at but I think you are mistaken. It looks to me as if the T shape has been made by welding a piece of ally to a flat plate of ally and the line you see down the sticky out bit is where it has been sheared to shape. Difficult to be sure because the photo doesnt show the fracture site end on and there should be something there to indicate why it happened at that precise location. A photo of the mating part would be useful. But there is no indication of any prior repair where the failure has happened
Re: Structural Failures [Re: howard] #600378
22/10/19 08:22 AM
22/10/19 08:22 AM
Salisbury, UK
Peter J Offline OP
Peter J  Offline OP
Salisbury, UK
I had a good look at the faces of the bracket failure. There is a clear line or rib running down the centre of the broken face, with lines at about 60 degrees from the centre to the sides. It is almost like a birds feather, with the quill and vanes.
At the top, where the bracket joints the plate bolted to the car there are signs of hammer effect, probably due to the two parts of the bracket hitting each other.
So, is it a fatigue crack, or due to a flaw in the sheet material used to make the bracket?
I've asked Williams to replace the part, but even if MMC don't have one it would be easy enough to repair with a couple of fish plates, bolts and bonding material.
As to the "glue failure" Williams have seen this before and will clean up and re-glue. If it happens again a pair pf spotlights would be the answer, with a retaining bolt going through the wing into the fixing point on the chassis!
2014 Plus 8
Moderated by  Aeroman, Simon
