6 registered members (ChrisP, RB1, HalfFull, mphcarpaintings, JohnMat, Heinz), 210 guests, and 21 spiders.
John V6 430
+8Rich 412
TBM 238
Heinz 189
Cummings & Goings ;-)
by +8Rich. 03/06/20 08:20 PM
Novochock on TV
by Peter J. 03/06/20 05:43 PM
Happy Birthday
by CooperMan. 03/06/20 02:06 PM
Speedo issue...help!
by Perry. 03/06/20 12:57 PM
One for Rally & BMC fans
by CooperMan. 03/06/20 12:53 PM
Good News
by lowebird. 03/06/20 10:49 AM
Inherent danger with Three Wheelers
by TBM. 03/06/20 10:04 AM
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
Are There Any Keen Car Badge Collectors out there
Snow banks of Norway
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,410
Posts629,475
Members6,938
Most Online1,033
Dec 28th, 2019
No Birthdays
Best rust covering paint ? #600567
23/10/19 11:53 AM
23/10/19 11:53 AM
Staffordshire
IvorMog Offline OP
IvorMog  Offline OP
Staffordshire
While I've got my engine out I want to clean up some of the rusty brackets and crosshead ends etc.
I'm doing to give them a good wire brushing and was then going to use Hammerite paint.
But there might be something better at covering old metal because no matter how hard one works there will still be some contamination and some paints simply don't adhere well.
Any experience based thoughts please on how to finish "old metal" would be appreciated.
Thanks
Bob
1999 4/4 2 litre Zetec
Re: Best rust covering paint [Re: IvorMog] #600575
23/10/19 12:08 PM
23/10/19 12:08 PM
East Harling, Norfolk UK
Richard Wood Offline
I always use a rust inhibitor/remover first such as Kurust, also a Hammerite product. You can see the rust has gone then before you apply protective paint.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Best rust covering paint [Re: IvorMog] #600576
23/10/19 12:13 PM
23/10/19 12:13 PM
Northamptonshire UK
Stringers Best Mate Offline
Northamptonshire UK
I'm told that full fat Coca-Cola as a pre-soak is good, but I've never tried it..
Re: Best rust covering paint [Re: Stringers Best Mate] #600582
23/10/19 12:18 PM
23/10/19 12:18 PM
Yes that has phosphoric acid in it which will work wonders on your stomach rust wink
Re: Best rust covering paint [Re: IvorMog] #600583
23/10/19 12:20 PM
23/10/19 12:20 PM
Arwyn Williams Offline
See if you can get the engine bay steam cleaned the a good brushable synthetic enamel should do the trick.
My local paint factors does a litre for 18 quid.
Hammerite is i) expensive ii) pin holes very easily
Arwyn
Re: Best rust covering paint [Re: IvorMog] #600589
23/10/19 12:49 PM
23/10/19 12:49 PM
North London
KBMOG Offline
KBMOG  Offline
North London
I have always had good results with "Rustoleum" paint.
I have found it to be better than Hammerite because it is not so brittle when it dries and is therefor less likely to chip or flake off.
It is also available in a wide range of colours.
Re: Best rust covering paint [Re: IvorMog] #600592
23/10/19 12:58 PM
23/10/19 12:58 PM
Rovert Offline
Rovert  Offline
To clear the rust I would go with Bilt-Hamber Deox-C for the brackets, and Deox Gel for the crosshead, then B-H Electrox for the primer and finish off with Eastwoods extreme chassis black. I would personally avoid Hammerite.
Brian
Jersey and Spain
Re: Best rust covering paint [Re: IvorMog] #600604
23/10/19 01:53 PM
23/10/19 01:53 PM
Luddite Offline
Luddite  Offline
As Arwyn and Brian have suggested Hammerite is best avoided in terms of the hammered enamel finishes, the pin holing Arwyn mentioned is down to the chemicals used to create the Hammered effect which causes the paint to be very thin in places allowing corrosion easy access.... However I do use Hammerite PRODUCTS to resist rust and their "ordinary" enamel paints to protect metal. It is best to get rid of rust and down to the bare metal rather than try to "cure" it, though I appreciate that is not always possible.... Good luck with your choices.
Re: Best rust covering paint [Re: IvorMog] #600610
23/10/19 02:31 PM
23/10/19 02:31 PM
The frozen North
Jack The Lad Offline
Posting Desperado
Posting Desperado
The frozen North
AHHHH , Been in the paint trade since 1964 when paints had lead . one thing that gets us is 99% of public want an easy job with magic paint and its done in a flash . Well it won't work . The more you put into a job AND I MEAN MORE . The longer its going to last preparation preparation preparation is the main thing . You can pay through the nose and it make little difference .
Re: Best rust covering paint [Re: IvorMog] #600626
23/10/19 03:52 PM
23/10/19 03:52 PM
Forest of Dean
SteveT Offline
SteveT  Offline
Forest of Dean
I've never rated Hammerite..had much better results with old fashioned black iron gate paint from our local ironmongers. Frosts do one that might be worth checking out as its often recommended on the classic car forums.
110th +4 AM Chiltern Green
1939 Cammy Velo
1959 BSA GoldStar DBD34
LR 90 SW
1948 MG TC
Moderated by  Aeroman, Simon
